No Files with v1.1
kirkm
Post Mon Aug 27, 2012 3:29 am
No Files with v1.1
Just installed version 1.1 and after connecting to Panasonic TH-P55ST30Z I can only see files in one of my
library folders. The Folder names are there but no entries... it was OK with previous version .06 (?).
Also, does anyone know if Serviio will work with m2ts files? Seems they just don't show up (even if
you change the extension to .avi).
Thanks for any assistance.
Post Mon Aug 27, 2012 2:05 pm
Re: No Files with v1.1
kirkm wrote:Hi,
no problem wih m2ts file, serviio support this.
Do you enable the device permission access on serviio console? (this is a new feature)
kirkm
Post Wed Aug 29, 2012 10:16 am
OK, cool but there must be a switch? I can put an m2ts file into a folder ans serviio shows the other files (avi.divx)
but not the m2ts one.
Is this the 'Device Allowed' tickbox when you right click a name in the status window? Yes they are ticked.
I have found that a Blu Ray player in games room connected to SD TV does show all the files/folders but the main TV
in another room does not. they are both on the same LAN and see tjs (same) serviio server.
Post Wed Aug 29, 2012 6:28 pm
What is the profile selected on serviio console for your Pana TV ?
kirkm
Post Fri Aug 31, 2012 2:23 am
I've tried both Panasonic Viera and Generic DLNA. Didn't seem to make any difference.
Post Tue Sep 11, 2012 12:17 pm
post ffmpeg -i for the m2ts file.
Also check if the file is really not there by running AV Media Controller from Intel tools (link in my signaure) or looking at MediaBrowser.
sugarmilktea
Post Sat Jan 19, 2013 2:12 am
I'm having the same problem. I just upgraded to the newer version 1.1, and now I cannot see any of my folders/files. It was working fine until now. I was able to determine that it's some sort of issue related to folder permissions, but I'm not able to edit the permissions on my external hard drive where I store most of my media. This is truly annoying.
sugarmilktea
Post Sat Jan 19, 2013 2:28 am
And if it helps, I'm on max os x 10.7.5
My external hard drive is formatted ExFAT.
Return to Panasonic
