Update profile request for 46WL863
Hi all,
I'd like to ask if there could be an update starting from the REGZA generic profile for my 46WL863 .
Shortly; I was trying to see an .mkv, my notebook has the latest Serviio version available and I'm using the generic REGZA profile enabling Transcoding capabilities.
I had some problems, which might be related to the wifi connection and/or processor performance (i5, with 8 GB of RAM... possible?)... after the first minutes, the video started to scatter and lag, so does the audio. I've tried with multiple settings, no way, the file is unwatchable.
Tried also to disable Transcoding; as expected, the video is not playable anymore ("Media Playback error").
But...
I copied the mkv file on an USB pen and tried to access directly inserting the device on an USB port of the TV; it worked flawlessly. So I'm assuming, my 46WL863 set *does* support natively mkv container but the REGZA profile doesn't.
Is there any chance to get a precise profile based on specific configuration?
Thanks in advance
But...
Thanks in advance
