Howto select Audio & Video in 0.5
tombert
Post Sat Dec 04, 2010 7:44 am
That's just an idea I would like to present here:
Imagine having two audio streams and two subtitle streams - as I read in other topics it was suggested to present all combinations of files in single folder i.e. this would mean serviio shows 6 files - all the same video but different audio and subtitle.
Why not having a "Control Folder" in the top hierarchy where you select the language and subtitle - serviio stores it. After that all you'r files play with that configuration. The advantage would be that when playing series or movies you need not to select audio and subtitle over and over again ... and of course having only one file presented. Just check PS3MS to see what I mean - it does this for video configuration but still presents all combinations of audio/subtitles in a single folder - it's not really comfortable to search through all the combinations ...
thx
patters
Post Tue Jan 25, 2011 12:37 pm
Re: Howto select Audio & Video in 0.5
From the examples I have on my hard disk, it seems like people who release movie rips generally do set the three letter language code of the audio streams and subs consistently. So a preference order (a la PS3 Media Server) would be good, and hopefully not a huge nightmare to add to the existing code. I think this could be in the Serviio console prefs personally.
Post Tue Jan 25, 2011 1:10 pm
I think in console as well, I don't want to clutter the browsing UI with controls.
There could be something like:
1) select preferred language
2) use DTS as primary audio stream (if available)
so if you have a file with 2 tracks, ac3 and dts, it's know it wants to map the DTS audio into the transcoding job, otherwise get the first available.
Ideas?
patters
Post Tue Jan 25, 2011 7:28 pm
I like that.
Zek
Post Tue Jan 25, 2011 11:40 pm
zip wrote:I think in console as well, I don't want to clutter the browsing UI with controls.
Ideas?
This would be awesome.
Sony Bravia KDL-55NX810 | Serviio 0.5 (rev. 975aa458693c) | Synology DS-1010+
hennys
Post Wed Jan 26, 2011 1:35 pm
Ideas?
I would prefer the browsing UI controls (although I would be already very happy if we could set it in the console.
The reason I would prefer the browsing UI controls is the fact that I have videos which the kids will want to view in dutch language, whereas I would like to see them in english. I would see no other way with the proposed solution than to go back to the Pc and switch the preferred language.
Perhaps a combination of both (e.g. 2 preferred languages, when both are present, then show them in the browsing ui ?
regards,
Hen
Post Wed Jan 26, 2011 1:52 pm
Also how about actually muxing in all streams and letting the renderers (which support it) give the option to the user?
tombert
Post Wed Jan 26, 2011 5:43 pm
Would this mean that the Renderen then selects the language as well? hmm ... would be interesting which TVs support that ... but I think thats where the future goes - they going to implement more and more features (hopefully) into the DLNA renderer ...
Post Wed Jan 26, 2011 9:38 pm
dalanik
Post Thu Jan 27, 2011 8:36 am
patters wrote:From the examples I have on my hard disk, it seems like people who release movie rips generally do set the three letter language code of the audio streams and subs consistently.
This is exactly what I do with subs and I was wondering whether this could be adressed. My movie structure is like this:
movies\
movies\Avatar\
Avatar.avi
Avatar_ser.sub
Avatar_eng.sub
So my Samsung C550 won't see the subs because they are not the same filename as the video file (avi). If Serviio could somehow "slip" the subtitles to DLNA player according to the language preferences so the TV sees it as "Avatar.sub" it would be great.
D.
hennys
Post Thu Jan 27, 2011 5:27 pm
zip wrote:Also how about actually muxing in all streams and letting the renderers (which support it) give the option to the user?
I don't think my samsung LE40C650 supports selecting audio tracks over dlna.
Probably only a few tv's do. In the future their numbers will problably increase but for now it would be nice to be able to select the language another way.
Kind regards,
Hen
Grimreaper666
Post Mon Feb 21, 2011 10:25 am
I like the ideas you have, especially as my LE40B750 allows no language selection of mkvs so far. What I liked was the implementation of the Wild Media Server (Single files can be chosen, one for each language). But it didn't work as well as Serviio does. I would also be in favor of setting the preferred language via a "settings" or "control" folder. Although it would also be nice to be able to make these settings via the console.
Anyway, Serviio definitely needs options to be able to select the language! :geek:
Grim
marcjero
Post Tue Mar 22, 2011 9:59 pm
Yes please it would be nice to be able to select the default audio track for mkv.
Pyros
Post Mon Jun 06, 2011 11:29 pm
yes
it could be greeat to sream the default track (wich can be easyly changed) instead of the first one.
    File 'hd-dr2_1080p.mkv': container: Matroska [duration:6019019000000]
    Track ID 1: video (V_MPEG4/ISO/AVC) [language:und track_name:Death\sRace\s2\s-\s1080p display_dimensions:1920x1080 default_track:1 forced_track:0 packetizer:mpeg4_p10_video]
    Track ID 2: audio (A_DTS) [language:eng track_name:DTS-US default_track:0 forced_track:0]
    Track ID 3: audio (A_DTS) [language:fre track_name:DTS-TRUEFR default_track:1 forced_track:0]
    Track ID 4: subtitles (S_TEXT/UTF8) [language:fre track_name:French\sSubs\sForced default_track:1 forced_track:0]
    Track ID 5: subtitles (S_TEXT/UTF8) [language:fre track_name:French\sSubs default_track:0 forced_track:0]
    Track ID 6: subtitles (S_TEXT/UTF8) [language:eng track_name:English\sSubs default_track:0 forced_track:0]
    Chapters: 20 entries
Should play with track Id 3 instead of 2
Return to Feature requests
Users browsing this forum: Baidu [Spider] and 13 guests
