PS3 - New Router Conundrum
seanhuggett
Post Sat Sep 01, 2012 12:16 pm
Hi all
First post as I've had a great Serviio experience to-date.
I've just moved to a Sky Sagemcom router from my old router as I've moved to Sky FTTC - so this iswould, at a guess, be a router related issue. My PC is connected by cable to the router and runs Serviio. The PS3 (connected by WiFi) cannot see Serviio on the PC (and vide versa) but other WiFi UPnP devices, such as my Smartphone, can see Serviio on my PC.
I've installed Serviio on my laptop (connected via WiFi) and the PS3 can see Serviio on the laptop (but still not on the PC). The PS3 can also see media servers on my Smartphone.
I've turned off the PC firewalls but no change, I've enabled UPnP on the PS3 and router. Im confused now as vereything sees everything except for the PS3 and the Seviio on the PS3 which can't see each other.
Any thoughts appreciated.
Thanks in advance.
Sean
NX3
Post Sat Sep 01, 2012 9:08 pm
Re: PS3 - New Router Conundrum
It sounds to me as if the PC is the issues as all other options work fine from what your saying. Have you tried another port on the router, just clutching at straws really....
