Tunein radio plugin
• Page 1 of 1
Can somebody who knowa what they are doing look at the tunein plugin and make it work with the latest version of serviio?
Re: Tunein radio plugin
Does this one work?
viewtopic.php?f=20&t=5096&hilit=tunein#p35842
NO - the original plugin works great on earlier version...the 1.01 release with that plugin says there is no playable file....
the plugin has been updated ... works great..
Thank You zip
Thank You zip
hi
Could someone pls tell me what i am doing wrong..
i have downloaded the plug-in and add the following link as web resource
http://tunein.com/radio/United-Arab-Emi ... 435/?qlc=1
radio i am looking is hit 96.7
but no luck ..nothing is showing under Audio->online
thanks
thanks
• Page 1 of 1
