[SOLVED] Transcoding failing, due to tmp file being missing
Rumbles
Post Sun Sep 02, 2012 5:33 pm
Re: Transcoding failing every time due to tmp file being mis
will wrote:You would know if you had set it via serviio.sh
It's not even showing an error code from ffmpeg which suggests ffmpeg isn't being called at all. Try setting ffmpeg.location to explicitly point to ffmpeg, otherwise point it at a script that simply writes to a file to check that it is being called.
Yep thanks, I should have thought before I replied, added the path in to the serviio.sh, trying again now
Rumbles
Post Sun Sep 02, 2012 5:39 pm
YESYEYYEYSYEYSYEYS!!! It's Working!!! :D :D :D Thanks muchly for the advice, I'll gladly put this al up on your wiki, if it stops anyone else form pulling their hair out it will be worthwhile :)
Post Sun Sep 02, 2012 5:41 pm
What was wrong?
Rumbles
Post Sun Sep 02, 2012 6:12 pm
will wrote:What was wrong?
Once I had added the -Dffmpeg.location in the serviio.sh it worked straight away, just writing the wiki article for the whole process.
Rumbles
Post Sun Sep 02, 2012 6:19 pm
I have added my experiences to this wiki article, I hope it helps those going before me :)
http://wiki.serviio.org/doku.php?id=howto:linux:install:centos
Post Sun Sep 02, 2012 6:45 pm
Thanks, remove ffmpeg from the prerequisites you don't use the one from yum.
Rumbles
Post Sun Sep 02, 2012 6:47 pm
the first yum command removes ffmpeg and x264 so you can build them later
Post Sun Sep 02, 2012 6:49 pm
Edit, nevermind, I'll update it. Thanks for writing it up and glad you got it working.
ned.ashley
Post Mon May 13, 2013 9:53 pm
Re: [SOLVED] Transcoding failing, due to tmp file being miss
I found that installing faac, faac-devel, lame, lame-devel helped when configuring ffmpeg. So:
yum install faac faac-devel lame lame-devel
Previous
