REMOTE access
iciolozzo
Post Tue Sep 04, 2012 1:39 pm
REMOTE access
I have Serviio server on a Mac Lion machine.
Everything perfect in my house lan.
But If I try to log outside I can't.
I forwarded 8895TCP and 1900UDP, then tried different DLNA/UPNP clients on iPhone with no success.
I typed "http://myip" or do I have to type "http://myip:8895"?
By the way http mediaplayer on port 23424 work perfectly with port forwarding!
Thanks in advance.
Post Sun Sep 09, 2012 10:20 pm
Re: REMOTE access
MediaBrowser is the only way (along with apps like ServiiGo) how to access Serviio remotely, unless you set up VPN - the client and the server have to be on the same subnet.
