New LG Profile Requiring Testers. (2012 Models ONLY)
zzchess
Post Sun May 20, 2012 4:32 pm
Re: New LG Profile Requiring Testers. (2012 Models ONLY)
Using this profile I cannot fast forward/rewind and videos. It's the same with the default LG profile.
dreamlayers
Post Mon May 21, 2012 4:04 pm
You cannot fast forward or rewind when the video is being transcoded. It seems LG devices can only seek based on offests in the file, and that's not possible when transcoding.
LG Media Link, using Plex Media Server, can seek in transcoded files. However, Plex Media Server has several bugs which make it unusable for transcoding during plaback.
FishHo
Post Fri May 25, 2012 2:22 am
Hi All , well I'm the proud new parent of a LG 42LM6200 , 2012 model down here in NZ ( LM620T in the UK ). So far the new profile works great, no problems , plays everything I've thrown at it including VOB's with DTS. Had a small problem last night with an SRT file , changed the SRT and AVI to both 8.3 format and that fixed it. Downloaded a few trailers and its all good so far. Fast forward doesn't work but you can do small jumps forward and back with the remote. I'll have go at trying to break it if you can point me to some source video.
strug
Post Fri Jun 08, 2012 7:13 am
I have just bought a new BP620 player after ditching ps3 for good. 2 catastrophic failures in 4 years is not good enough sony. I have also switched to Serviio from PS3 media server. Thanks for this profile, everything I have tried so far is working apart from some .avi files.
I have a folder with avi files and every now and again the Player reports - 'cannot play file type'. I have looked into the files and all the files that wont play are encoded with the Microsoft Mpeg v2 non standard codec, ID MP42. I have tried the following without success
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" >
<Matches container="avi" vCodec="mp42"/>
Post Fri Jun 08, 2012 8:03 am
strug wrote:I have just bought a new BP620 player after ditching ps3 for good. 2 catastrophic failures in 4 years is not good enough sony. I have also switched to Serviio from PS3 media server. Thanks for this profile, everything I have tried so far is working apart from some .avi files.
I suppose "LG"Profile is selected on serviio console?
Could you provide "ffmpeg -i <your avi file>" result ?
strug
Post Fri Jun 08, 2012 8:28 am
C:\Program Files\Serviio\lib>ffmpeg -i "D:\shares\Videos\Series\Whose Line is it
Anyway\Season 1\Whose Line US - 1x10 (show 117).avi"
nfig
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
Input #0, avi, from 'D:\shares\Videos\Series\Whose Line is it Anyway\Season 1\Wh
ose Line US - 1x10 (show 117).avi':
Duration: 00:21:42.67, start: 0.000000, bitrate: 668 kb/s
Stream #0:0: Video: msmpeg4v2 (MP42 / 0x3234504D), yuv420p, 640x480, 29.97 t
br, 29.97 tbn, 29.97 tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 44100 Hz, stereo, s16, 96 kb/
s
Post Sat Jun 09, 2012 8:19 am
try to change it to
<Matches container="avi" vCodec="msmpeg4"/>
strug
Post Sat Jun 09, 2012 8:58 am
Thank you, that has fixed the problem :) - Loving Serviio
casper
Post Sat Sep 01, 2012 7:17 am
Some online streams (not all) are shown with wrong aspect ratio (4:3 instead of 16:9). Here is one example
http://77.51.249.86:8001
which shows squeezed from the sides.
This one here is shown correctly
http://77.51.249.86:8101
memog
Post Tue Sep 04, 2012 8:28 pm
Hello Everyone. I just bought the LG 55LM5800 and some of the videos That wouldnt play wiith the old profile now play with this profile but not all of them.
the ones are not playing are mkv with dts audio... I followed the "Provide details of a video file that doesn't play" link and I got this result:
g-config
[matroska,webm @ 0132BE80] Unsupported encoding typeUnsupported encoding typeUns
upported encoding typeInput #0, matroska,webm, from 'E:\Movies 1080\Video Movie BluRay REMUX 1080p AVC DTS-HD MA 5.1-\Video movie BluRay REMUX 1080p
 AVC DTS-HD MA 5.1-.mkv':
    creation_time   : 2012-08-21 21:49:00
  Duration: 02:22:54.90, start: 0.000000, bitrate: 28779 kb/s
    Chapter #0.0: start 0.000000, end 482.315000
      title           : 00:00:00.000
    Chapter #0.1: start 482.315000, end 709.167000
      title           : 00:08:02.315
    Chapter #0.2: start 709.167000, end 918.751000
      title           : 00:11:49.167
    Chapter #0.3: start 918.751000, end 1233.482000
      title           : 00:15:18.751
    Chapter #0.4: start 1233.482000, end 1384.258000
      title           : 00:20:33.482
    Chapter #0.5: start 1384.258000, end 1779.444000
      title           : 00:23:04.258
    Chapter #0.6: start 1779.444000, end 2243.992000
      title           : 00:29:39.444
    Chapter #0.7: start 2243.992000, end 2567.982000
      title           : 00:37:23.992
    Chapter #0.8: start 2567.982000, end 3022.269000
      title           : 00:42:47.982
    Chapter #0.9: start 3022.269000, end 3664.661000
      title           : 00:50:22.269
    Chapter #0.10: start 3664.661000, end 4445.107000
      title           : 01:01:04.661
    Chapter #0.11: start 4445.107000, end 5281.234000
      title           : 01:14:05.107
    Chapter #0.12: start 5281.234000, end 5900.561000
      title           : 01:28:01.234
    Chapter #0.13: start 5900.561000, end 6340.167000
      title           : 01:38:20.561
    Chapter #0.14: start 6340.167000, end 6675.085000
      title           : 01:45:40.167
    Chapter #0.15: start 6675.085000, end 7067.769000
      title           : 01:51:15.085
    Chapter #0.16: start 7067.769000, end 7478.680000
      title           : 01:57:47.769
    Chapter #0.17: start 7478.680000, end 7779.397000
      title           : 02:04:38.680
    Chapter #0.18: start 7779.397000, end 7990.691000
      title           : 02:09:39.397
    Chapter #0.19: start 7990.691000, end 8574.902000
      title           : 02:13:10.691
    Stream #0:0: Video: h264 (High), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 23.9
8 fps, 23.98 tbr, 1k tbn, 47.95 tbc
    Stream #0:1(eng): Audio: dts (DTS-HD MA), 48000 Hz, 5.1(side), s16, 1536 kb/
s (default)
    Stream #0:2(eng): Subtitle: hdmv_pgs_subtitle
    Stream #0:3(eng): Subtitle: hdmv_pgs_subtitle
    Stream #0:4(eng): Subtitle: hdmv_pgs_subtitle
Im VERY new at this so any help, tips, pointers would be awesome.
Media Info from the file im trying to play
Unique ID                                : 215134601301119514445276997928142007801 (0xA1D96AC53A6B6CB1A9E76867BB806DF9)
Complete name                            : E:\Movies 1080\Video Movie REMUX 1080p AVC DTS-HD MA 5.1-\Video Movie REMUX 1080p AVC DTS-HD MA 5.1-.mkv
File size                                : 28.7 GiB
Duration                                 : 2h 22mn
Overall bit rate                         : 28.8 Mbps
Encoded date                             : UTC 2012-08-21 21:49:00
Writing application                      : mkvmerge v5.7.0 ('The Whirlwind') built on Jul  8 2012 20:08:51
Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
Muxing mode                              : Container profile=Unknown@0.0
Duration                                 : 2h 22mn
Bit rate                                 : 24.3 Mbps
Maximum bit rate                         : 32.0 Mbps
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.488
Stream size                              : 24.2 GiB (84%)
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format profile                           : MA / Core
Codec ID                                 : A_DTS
Duration                                 : 2h 22mn
Bit rate                                 : 3 949 Kbps / 1 510 Kbps
Channel(s)                               : 8 channels / 6 channels
Channel positions                        : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Bit depth                                : 24 bits
Compression mode                         : Lossless / Lossy
Format                                   : PGS
Muxing mode                              : zlib
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : The same subtitle format used on BDs/HD-DVDs
Format                                   : PGS
Muxing mode                              : zlib
Format                                   : PGS
Muxing mode                              : zlib
Menu
00:00:00.000                             : en:00:00:00.000
00:08:02.315                             : en:00:08:02.315
00:11:49.167                             : en:00:11:49.167
00:15:18.751                             : en:00:15:18.751
00:20:33.482                             : en:00:20:33.482
00:23:04.258                             : en:00:23:04.258
00:29:39.444                             : en:00:29:39.444
00:37:23.992                             : en:00:37:23.992
00:42:47.982                             : en:00:42:47.982
00:50:22.269                             : en:00:50:22.269
01:01:04.661                             : en:01:01:04.661
01:14:05.107                             : en:01:14:05.107
01:28:01.234                             : en:01:28:01.234
01:38:20.561                             : en:01:38:20.561
01:45:40.167                             : en:01:45:40.167
01:51:15.085                             : en:01:51:15.085
01:57:47.769                             : en:01:57:47.769
02:04:38.680                             : en:02:04:38.680
02:09:39.397                             : en:02:09:39.397
02:13:10.691                             : en:02:13:10.691
Post Wed Sep 05, 2012 6:48 am
Thanks for information, your file seems good.
Could you enable detailed logging (see signature link), then extract the ffmpeg command line used to transcode your file ? its probably due to ffmpeg DTS transcoding failure.
memog
Post Thu Sep 06, 2012 9:19 pm
Im note sure on how to do this... I enabled detal loggin and look at the looked at serviio.log and I see a lot of stuff.. I did a search for ffmpeg on that file and this is what i got... I hope is what you were asking for...
2012-09-06 16:02:00,113 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: E:\Movies 1080\Video Movie REMUX 1080p AVC DTS-HD MA 5.1-\Video Movie REMUX 1080p AVC DTS-HD MA 5.1-.mkv
2012-09-06 16:02:00,113 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -i E:\Movies 1080\Video Movie REMUX 1080p AVC DTS-HD MA 5.1-\Video Movie REMUX 1080p AVC DTS-HD MA 5.1-.mkv -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a ac3 -b:a 192k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-149-21-ORIGINAL.stf
2012-09-06 16:02:00,325 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2012-09-06 16:02:00,325 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2012-09-06 16:02:00,614 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
Post Fri Sep 07, 2012 10:25 am
FFmpeg crashed, but why ?!
Could you retry locallly in a windows terminal the same command line, then post the ffmpeg log result:
C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -i "E:\Movies 1080\Video Movie REMUX 1080p AVC DTS-HD MA 5.1-\Video Movie REMUX 1080p AVC DTS-HD MA 5.1-.mkv" -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a ac3 -b:a 192k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-149-21-ORIGINAL.stf
memog
Post Sat Sep 08, 2012 12:06 am
Here it is.
C:\Program Files\Serviio\lib>ffmpeg.exe -fflags +genpts -i "E:\Movies 1080\Video Movie REMUX 1080p AVC DTS-HD MA 5.1-\Video Movie REMU
g-config
[matroska,webm @ 0038F3C0] Unsupported encoding typeUnsupported encoding typeUns
upported encoding typeInput #0, matroska,webm, from 'E:\Movies 1080\Video Movie REMUX 1080p AVC DTS-HD MA 5.1-\Video Movie REMUX 1080p
s (default)
[graph 0 input from stream 0:1 @ 0038F320] tb:1/48000 samplefmt:s16 samplerate:4
8000 chlayout:0x60f
[auto-inserted resampler 0 @ 033AF8E0] chl:5.1(side) fmt:s16 r:48000Hz -> chl:st
ereo fmt:flt r:48000Hz
[mpegts @ 03A5D020] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every
40 pkts
Output #0, mpegts, to 'C:\Windows\TEMP\Serviio\transcoding-temp-149-21-ORIGINAL.
stf':
    encoder         : Lavf54.15.102
    Stream #0:0: Video: h264, yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 23.
98 fps, 90k tbn, 23.98 tbc
    Stream #0:1(eng): Audio: ac3, 48000 Hz, stereo, flt, 192 kb/s (default)
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
  Stream #0:1 -> #0:1 (dca -> ac3)
[mpegts @ 03A5D020] pts (3780) < dts (7444) in stream 0
av_interleaved_write_frame(): Invalid argument
Post Sat Sep 08, 2012 7:34 am
memog wrote: Stream #0:0: Video: h264, yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 23.98 fps, 90k tbn, 23.98 tbc
Stream mapping:
[mpegts @ 03A5D020] pts (3780) < dts (7444) in stream 0av_interleaved_write_frame(): Invalid argument
Your mkv seems wreaked.
I suggest to use mkvmerge tool to rebuild the mkv file (it's easy and speedy): http://www.videohelp.com/tools/MKVtoolnix
Or you can directly remux to mpegts with TsMuxer tool, but you'll lose subtitles...
bartek_75
Post Mon Dec 31, 2012 10:52 am
This profile plays flv files on my tv set just fine. While standard LG profile did not.
Tv LG 42LS570S
Adding
 <Matches container="rm" />
to the profile, enabled rmvb playback with Serviio 1.1.
Best regards,
Bartek
LG 42LS570S
chrsmrrtt
Post Wed Jan 30, 2013 8:58 pm
I have a LG 32LS570T-ZB Smart TV and transcoded FLAC audio files using this new profile result in an "invalid file" warning on the TV.
Here's the debug:
2013-01-24 22:39:06,042 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.75, Profile=LG Smart TV (2012)'
2013-01-24 22:39:06,046 DEBUG [ResourceDeliveryProcessor] Request for resource 7190 and type 'MEDIA_ITEM' received
2013-01-24 22:39:06,046 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7190 (local)
2013-01-24 22:39:06,046 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7190)
2013-01-24 22:39:06,060 DEBUG [MusicTrackDAOImpl] Reading a MusicTrack (id = 7190)
2013-01-24 22:39:06,061 DEBUG [AudioDeliveryEngine] Retrieving resource information for item 7190, format LPCM16_44_STEREO and profile LG Smart TV (2012)
2013-01-24 22:39:06,062 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file 01 The Lemon Of Pink.flac
2013-01-24 22:39:06,062 DEBUG [AudioDeliveryEngine] Found Format profile for transcoded file 01 The Lemon Of Pink.flac: LPCM16_44_STEREO
2013-01-24 22:39:06,066 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 7190 (local)
2013-01-24 22:39:06,066 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7190)
2013-01-24 22:39:06,066 DEBUG [MusicTrackDAOImpl] Reading a MusicTrack (id = 7190)
2013-01-24 22:39:06,067 DEBUG [AudioDeliveryEngine] Delivering item '7190' for client 'IPAddress=/192.168.1.75, Profile=LG Smart TV (2012)'
2013-01-24 22:39:06,067 DEBUG [AudioDeliveryEngine] Delivering file '01 The Lemon Of Pink.flac' using transcoding
2013-01-24 22:39:06,067 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.75, Profile=LG Smart TV (2012)'
2013-01-24 22:39:06,068 DEBUG [MediaItemDAOImpl] Getting file of media item 7190
2013-01-24 22:39:06,069 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode audio file: E:\Music\Albums\FLAC\Artist Albums\Books\[2003] The Lemon Of Pink\01 The Lemon Of Pink.flac
2013-01-24 22:39:06,070 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i E:\Music\Albums\FLAC\Artist Albums\Books\[2003] The Lemon Of Pink\01 The Lemon Of Pink.flac -y -ar 44100 -ac 2 -vn -f s16be C:\transcoded\Serviio\transcoding-temp-7190-21-ORIGINAL.stf
2013-01-24 22:39:06,572 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-01-24 22:39:06,574 DEBUG [AudioDeliveryEngine] Found Format profile for transcoded file 01 The Lemon Of Pink.flac: LPCM16_44_STEREO
2013-01-24 22:39:06,574 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 7190) as read
2013-01-24 22:39:06,582 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-01-24 22:39:06,583 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 900000000
2013-01-24 22:39:06,583 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-01-24 22:39:06,583 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-01-24 22:39:06,583 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: audio/L16;rate=44100;channels=2,Date: Thu, 24 Jan 2013 22:39:06 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-01-24 22:39:07,314 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2013-01-24 22:39:12,200 DEBUG [WebServer] Incoming connection from /192.168.1.75:39023
2013-01-24 22:39:12,213 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
If you need any more information, let me know.
Thanks,
Chris.
Post Thu Jan 31, 2013 8:49 pm
try to change the targetACodec to mp3
chrsmrrtt
Post Sat Feb 02, 2013 9:21 pm
Hello zip,
Thanks for your suggestion. Since I was tweaking the audio tag I changed the targetContainer to mp3 rather than adding a targetACodec as you suggested.
Therefore the profile now looks like this:
<Profile id="21" name="LG Smart TV (2012)" extendsProfileId="1">
      <Detection>
           <UPnPSearch>
              <FriendlyName>(.*LW98.*)|(.*LW65.*)|(.*LW55.*)|(.*PZ9.*)|(.*PZ57.*)|(.*LS57.*)</FriendlyName>
              <Manufacturer>LG Electronics</Manufacturer>
           </UPnPSearch>
      </Detection>
           <!-- Transcode h264 videos with profile level > 4.1 to mpegts with ac3 audio -->
              <Matches container="avi" vCodec="h264" profile="high" levelGreaterThan="4.2" />
              <Matches container="avi" vCodec="h264" profile="main" levelGreaterThan="4.2" />
              <Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.2" />
              <Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.2" />
            <!-- remux unsupported audio codecs in MKV into AC3 -->
           <Video targetContainer="mpegts" targetACodec="ac3" >
              <Matches container="matroska" vCodec="h264" aCodec="dca" />
           <!-- Remux WTV files to MPEG-PS with no transcoding-->
              <Matches container="wtv" />
           <!-- transcode unsupported video codecs into mpeg-ts, mpeg2video and ac3 audio -->
              <Matches container="asf" />
              <Matches container="flv" />
              <Matches container="ogg" />
           <!-- unsupported audio will be transcoded into lpcm audio -->
           <Audio targetContainer="mp3">
              <Matches container="flac" />
              <Matches container="adts" />
           </Audio>
However, now when playing on the TV the music is garbaged - almost like it's playing at x2 speed, but without it's pitch being raised.
Post Mon Feb 04, 2013 6:29 pm
try to force the aBitrate too to a value (eg 384, 192, ..)
Return to LG
