1.0.1 - SONY 2011 - MPEGTS-h264-dts won't play
I upgraded to 1.0.1.
Now my SONY 2011 - won't play MPEG2TS-h264-dts anymore.
What went potentially wrong ???
Any hint is appreciated.
THX
ffmpeg version git-2012-08-27-60924df Copyright (c) 2000-2012 the FFmpeg developers
built on Aug 27 2012 16:25:28 with gcc 4.6 (Ubuntu/Linaro 4.6.3-1ubuntu5)
configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid
libavutil 51. 70.100 / 51. 70.100
libavcodec 54. 54.100 / 54. 54.100
libavformat 54. 25.104 / 54. 25.104
libavdevice 54. 2.100 / 54. 2.100
libavfilter 3. 13.101 / 3. 13.101
libswscale 2. 1.101 / 2. 1.101
[mpegts @ 0x27c6280] max_analyze_duration 5000000 reached at 5004000
[mpegts @ 0x27c6280] Could not find codec parameters for stream 2 (Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[NULL @ 0x27cb300] start time is not set in estimate_timings_from_pts
Input #0, mpegts, from '00006.m2ts':
Duration: 02:16:54.23, start: 4197.958300, bitrate: 25169 kb/s
Program 1
Stream #0:0[0x1011]: Video: h264 (High) (HDMV / 0x564D4448), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc
Stream #0:1[0x1100]: Audio: dts (DTS-HD MA) ([134][0][0][0] / 0x0086), 48000 Hz, 5.1(side), s16, 1536 kb/s
Stream #0:2[0x1200]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
2012-09-06 21:00:05,184 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.26
2012-09-06 21:00:05,185 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.0.26, Profile=Sony Bravia TV (2011)'
2012-09-06 21:00:05,185 DEBUG [ResourceDeliveryProcessor] Request for resource 38 and type 'MEDIA_ITEM' received
2012-09-06 21:00:05,185 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 38 (local)
2012-09-06 21:00:05,185 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 38)
2012-09-06 21:00:05,186 DEBUG [VideoDAOImpl] Reading a Video (id = 38)
2012-09-06 21:00:05,186 DEBUG [VideoDeliveryEngine] Delivering item '38' for client 'IPAddress=/192.168.0.26, Profile=Sony Bravia TV (2011)'
2012-09-06 21:00:05,186 DEBUG [VideoDeliveryEngine] Delivering file '00006.m2ts' using transcoding
2012-09-06 21:00:05,187 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-11-sony2011-ORIGINAL.stf', will stop the job
2012-09-06 21:00:05,187 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-11-sony2011-ORIGINAL.stf'
2012-09-06 21:00:05,187 DEBUG [TranscodingJobListener] Deleted temp file '/media/music/Serviio/transcoding-temp-11-sony2011-ORIGINAL.stf': false
2012-09-06 21:00:05,187 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.0.26, Profile=Sony Bravia TV (2011)'
2012-09-06 21:00:05,188 DEBUG [MediaItemDAOImpl] Getting file of media item 38
2012-09-06 21:00:05,188 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /media/video/video/Test/BDMV/STREAM/00006.m2ts
2012-09-06 21:00:05,189 DEBUG [ProcessExecutor] Starting ffmpeg -i /media/video/video/Test/BDMV/STREAM/00006.m2ts -y -threads 4 -copyts -c:v mpeg2video -b:v 17000k -maxrate:v 17000k -bufsize:v 17000k -r 24000/1001 -g 15 -c:a ac3 -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /media/music/Serviio/transcoding-temp-38-sony2011-ORIGINAL.stf
2012-09-06 21:00:05,211 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error.
2012-09-06 21:00:05,211 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2012-09-06 21:00:12,693 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/media/music/Serviio/transcoding-temp-38-sony2011-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/media/music/Serviio/transcoding-temp-38-sony2011-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:45)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:125)
Illico wrote:Could you enable detailed logging and extract the ffmpeg command line used for transcoding ?
Illico wrote:Thanks for file info, but I need the detailed logging...Illico wrote:Could you enable detailed logging and extract the ffmpeg command line used for transcoding ?
soundcheck wrote:2nd log post = detailed debug log ???
soundcheck wrote:1. When running above from command line ffmpeg didn't like spaces in the directory name.
soundcheck wrote:Now. What to do about it??
Yesterday I managed to get around the issue when changing profile.xml. ( Result was the earlier posted ffmpeg commandline). What would be the best setting / workaround ???
soundcheck wrote:And still there seems o be a problem that Serviio has an issue with the path?!?!? Otherwise there wouldn't be the related message in the log !?!?!
Because the path message remained even when I changed the profile.xml which led to the working transcoding line.
*** profiles.xml.test 2012-09-07 11:52:11.929282996 +0200
--- profiles.xml.orig 2012-09-06 19:30:22.631264333 +0200
*** 602,608 ****
<Matches container="mpegts" vCodec="vc1" />
- <Matches container="mpegts" vCodec="h264" aCodec="dca" />
<Matches container="asf" vCodec="vc1" aCodec="wmapro" />
Users browsing this forum: No registered users and 51 guests
