DTS Streaming
patters
Post Sun Jun 03, 2012 5:48 pm
Re: DTS Streaming
@Zip - one of the FFmpeg guys would like to know why Serviio's remix FFmpeg command line contains -async 1 and -copyts. I'm not sure.
https://ffmpeg.org/trac/ffmpeg/ticket/1398
ayush_x
Post Sun Aug 19, 2012 10:24 am
Re: DTS Streaming
Even I got the same problem. I am using samsung D series TV along which Denon amp.
Earlier I was able to stream DTS audio(diff streamer) but now its sending lpcm!!
Please help. can the issue be solved by making some changes in profiles.xml??
Post Sun Aug 19, 2012 10:54 am
Re: DTS Streaming
Make sure you're using the Samsung c/d/e profile.
ayush_x
Post Mon Aug 20, 2012 5:14 am
Re: DTS Streaming
yep is samsung c/d/e profile. Detected it automatically. I have read similar problems is other threads also.
Post Mon Aug 27, 2012 9:46 pm
Re: DTS Streaming
Is it video file? If yes it never transcodes to lpcm. Check the player setting on whether it sends bitstream or lpcm.
ayush_x
Post Thu Aug 30, 2012 2:58 pm
Re: DTS Streaming
Yes it is a video file. I may be wrong abt lpcm but its not dts either cauz my denon will then recognize the source as dts and then decode accordingly(plus the dts indicator will light up).
I did not understand as to where I can check the player setting. My TV transfers the audio data as it is without any conversion.
Post Thu Sep 06, 2012 7:28 pm
Re: DTS Streaming
you can post detailed log of playing the file, it should show us if the file is transcoded or not
lover
Post Mon Feb 25, 2013 10:37 pm
Re: DTS Streaming
hi, any more news after you posted the ticket? i'm still hoping this issue gets resolved.
thanks.
patters
Post Mon Feb 25, 2013 11:50 pm
Re: DTS Streaming
No one has worked on it sadly.
lover
Post Tue Feb 26, 2013 11:24 pm
Re: DTS Streaming
i find it strange that 9 months later no one has done anything on their side. it must be a major fix if that is the case.
it's been so long that i can't remember how to remux using TSMuxer. i have been settling with dolby digital for the past 9 months. *sigh, such a mediocre life i live.
thank you for your effort.
Previous
