1.0.1 - SONY 2011 - MPEGTS-h264-dts won't play
soundcheck
Post Fri Sep 07, 2012 2:00 pm
Re: 1.0.1 - SONY 2011 - MPEGTS-h264-dts won't play
will wrote:Just to re-itterate what Illico said. Having spaces in the path is NOT a problem. When Serviio runs ffmpeg it puts quotes around the path automatically, however, these quotes aren't shown in the log so when using a command from a log, you need to add the quotes yourself. There is no need to move/rename files/directories to removes spaces from the path.
Just did it and it worked.
There was no other explanation for earlier reported failure. You guys wanted me to check permissions, disk space asf. But everything was OK on that side.
So I tried removing spaces.
Post Fri Sep 07, 2012 2:03 pm
soundcheck wrote:Below my profile diff.
Could you confirm that comment that line solved the problem ?
<Matches container="mpegts" vCodec="h264" aCodec="dca" />
So now, your file is delivered in native format ? Could you confirm by checking the detailed serviio log file ?
soundcheck
Post Fri Sep 07, 2012 2:39 pm
I'll do it tomorrow. I finshed my hacking and testing marathon for today. ;)
I also took the chance to clean up my installation. It was a kind of pretty basic
as done according to the Wiki.
The Linux/Ubuntu installation wiki IMO needs quite a revision. I spent quite some hours
to get it all installed ( incl. ffmpeg compiliation). It's really getting time that there is a
fully functional package being made avialable.
Cheers
Post Fri Sep 07, 2012 7:41 pm
soundcheck wrote:The Linux/Ubuntu installation wiki IMO needs quite a revision. I spent quite some hours
The wiki is "open", you can contribute if you want.
soundcheck
Post Sat Sep 08, 2012 12:33 pm
Yep. I considered it. But for now -- considering that I spent a couple of days -- to get going.
I'm a bit exhausted and ran out of time. ( I do have several similar projects ongoing)
Though I think I'll add some stuff.
Previous
