TV Series Enumeration and Last watched notifier
SiegeX
Post Fri Dec 18, 2009 5:53 pm
I noticed that if I have a TV series with over 10 episodes that Serviio will not pad the first 9 with a zero. What this ends up looking like on the XBox is the following:
1. Episode 1 Title
11. Episode 11 Title
12. Episode 12 Title
2. Episode 2 Title
3. Episode 3 Title
and so on. I *think* if you pad the first 9 episodes with a zero (such as 01.) that it will show up in the correct order on the XBox360.
My second feature request is along the lines of how Netflix does this for the XBox and that is it automatically selects the next episode that I have yet to watch. It also shows the percent complete of the episodes I've watched. Now I don't expect either one of these as the solution, but It would be very cool if we can devise a method that will easily allow us to know what Episode we left off at. Perhaps adding "Last Watched" to the Title of the stream last played by Serviio.
Post Fri Dec 18, 2009 11:31 pm
Re: TV Series Enumeration and Last watched notifier
SiegeX wrote:I *think* if you pad the first 9 episodes with a zero (such as 01.) that it will show up in the correct order on the XBox360.
Yes, maybe. I can give it a try.
That's already there, right? We have 'Last viewed' folder that was requested by my beautiful French girlfriend just for this purpose :-)
SiegeX
Post Fri Dec 18, 2009 11:59 pm
Ahh, I'll have to give that a look when I get home, I didn't notice it. But question, does that folder have a "Last Viewed" on a Per-series basis or does it just hold the last video streamed by Serviio or perhaps its more like a history folder which holds a circular buffer of the last ~10 or so watched streams. What I'm looking for would be an at-a-glance method to see what episode you just watched on a per-series basis and then play the very next episode without having to jump between folders.
And tell your beautiful french girlfriend she has good ideas =)
Post Sat Dec 19, 2009 12:12 am
Yeah, it's the last 10 streamed videos. I was thinking about this 'next to watch' concept but cannot figure out any cool way how to do this. I mean I could add a container 'Next episode to watch' folder including list of series but how do I know if the last episode that has been streamed was watched completely or just few first seconds? Would I display the last streamed episode and all following (from that season)? ... I guess that could work.
I want to keep the browsing categories reasonably simple and also include an editor of what categories to serve and how they should be hierarchically designed in a future release. There are already some users complaining there are too many categories now, so this needs to be configurable.
SiegeX
Post Sat Dec 19, 2009 1:49 am
Rather than making a new category, can't you just alter the actual Title with either some sort of moniker to denote it was the last watched, perhaps make this user configurable. This has the all the benefits that I described above. You know instantly what file you just watched and thus which you should watch next, and more importantly you do not have to flip-flop folders to choose which episode to watch (presumably the next.)
For example: (using the new zero-padded feature :D )
01. Episode 1 Title
02. Episode 2 Title
03. Episode 3 Title**
04. Episode 4 Title
05. Episode 5 Title
Or
01. Episode 1 Title
02. Episode 2 Title
03. Episode 3 Title  =Last Watched=
04. Episode 4 Title
05. Episode 5 Title
As soon as Episode 3 is watched the moniker would then be moved to the Episode 4 title and be removed from Episode 3. I'll assume from you last statement that you do not (currently) maintain the percentage of a stream that was last watched. If that is the case I wouldn't be disappointed if viewing 1 second of Episode 4 would move the moniker. However, I would imagine the episodes duration is part of the meta data available online (or perhaps part of the file itself) so could you not start a timer when serviio starts streaming and then when it ends calculate 'streamed time / total episode time' to get the percentage watched and also have that available as a moniker that alters the title name. Perhaps this one could be persistent just like Netflix.
fizze
Post Sat Dec 19, 2009 8:34 am
That would be a nice feat, or to have some sort of folder structures for unwatched episodes.
In Swisscenter, you can toggle between showing all episodes, and just unwatched.
Which is awesome, because it allows you to keep track of episodes, and you can easily access the first unwatched episode.
Also, Swisscenter indicates the watched/unwatched status by a green / red icon. I reckon you could manage something similiar through the thumbnails? ;)
Intel SS4200 - Ubuntu Server 8.04
LG BD - 390
Post Sat Dec 19, 2009 1:51 pm
SiegeX wrote:
01. Episode 1 Title
02. Episode 2 Title
04. Episode 4 Title
05. Episode 5 Title
This is doable ;-)
Yes, how much has been streamed is not in my control (controlled by low level Java classes).
Post Sat Dec 19, 2009 1:53 pm
fizze wrote:In Swisscenter, you can toggle between showing all episodes, and just unwatched.
That's the device's controls, I only serve the content is a particular hierarchy.
This sounds cool, but not all devices could have any use from this (not all display the thumbnails, eg xbox).
SiegeX
Post Sat Dec 19, 2009 10:56 pm
zip wrote:This is doable ;-)
Awesome. I was thinking, maybe it would be better to put said moniker in the front of the Title because I don't know if it would be visible if the title were very long and it was on the end.
I see. I'm not a big OOP person but I'm assuming you mean this information is private data in lower-level classes that you can't get to? If the duration of each video file can be known (which I think it can from online db's), could you infer the percentage by calling something like gettimeofday() just before you make the call to the Java method which actually starts streaming the video file and then once that method returns call gettimeofday() again and subtract the two times for total play duration? This info plus the total video duration would give you the percentage. It may not be super accurate but within a few percent which is more detail than we (or at least I) care about anyway. I would be happy if we just knew in 25% increments of how far we were, any resolution better than that is just a plus.
Post Sun Dec 20, 2009 12:28 am
SiegeX wrote:Awesome. I was thinking, maybe it would be better to put said moniker in the front of the Title because I don't know if it would be visible if the title were very long and it was on the end.
I think this would screw up ordering on your xbox again ;-)
It's more like I just open a stream of data and let it do its work - the TV is consuming that stream. Some devices can also send different requests, e.g. give me all the stream, give me portion of the stream starting on byte xx and ending on byte yy, etc. Including FFWD and REW functions, this might be turn up as quite a big task... I might look at that in the future, but the first version of this will definitelly just mark the last episode of a season that has been streamed.
SiegeX
Post Sun Dec 20, 2009 3:47 am
zip wrote:I think this would screw up ordering on your xbox again ;-)
I was thinking more on the lines of:
01. Episode 1 Title
02. Episode 2 Title
03. **Episode 3 Title
04. Episode 4 Title
05. Episode 5 Title
Either that or if you want to keep it on the end you could use ellipses if the title is past a certain length (minus 2 for the **'s). For example if Episode 3 had a title of "Episode 3 really really really really long episode title"
03. Episode 3 really really really really lon...**
Ya, if this feature is non-trivial than I wouldn't put too much effort into it. Just knowing what Episode I watched last gets me 95% the way there.
fizze
Post Sun Dec 27, 2009 2:06 pm
I'd like that too. Oh, or maybe add the **'s for watched or unwatched episodes in general?
LG BD - 390
Return to Feature requests
Users browsing this forum: No registered users and 87 guests
