Wimp.com
appiem
Post Wed Oct 05, 2011 10:50 am
Wimp.com
gujju1973 wrote:I would like to request a plugin for wimp.com videos. The site has a link for rss feed but when you add it to Serviio, it does not shows any videos, but when you enter the same link in a browser, you get a list of videos.
WimpCom.groovy
(1.94 KiB) Downloaded 1068 times
gujju1973
Post Wed Oct 05, 2011 3:46 pm
Re: Wimp.com plugin
I installed the plugin and then add the feed http://www.wimp.com/rss but still do not see any videos. Am I doing anything wrong? Please advise.
Post Wed Oct 05, 2011 7:27 pm
Re: Wimp.com plugin
gujju1973 wrote:I installed the plugin and then add the feed http://www.wimp.com/rss but still do not see any videos. Am I doing anything wrong? Please advise.
are these LIVE videos?
gujju1973
Post Thu Oct 06, 2011 2:15 pm
Re: Wimp.com plugin
No, these are not LIVE feeds....just a collection of vides files.
appiem
Post Thu Oct 06, 2011 5:56 pm
Re: Wimp.com plugin
For me it works, look at serviio.log for entry:
INFO [PluginCompilerThread] Added plugin WimpCom (WimpCom.groovy)
or errors
gujju1973
Post Sat Oct 08, 2011 2:07 pm
Re: Wimp.com plugin
Yes I see the plugin load properly but when I add in the feed to the online sources, I don't see any video files.
appiem
Post Fri Dec 30, 2011 2:58 pm
Re: Wimp.com plugin
Adjusted plugin for.
Source Url: http://www.wimp.com/rss
WimpCom v1.1.groovy
(1.96 KiB) Downloaded 1015 times
iheartninjas
Post Fri Dec 30, 2011 3:55 pm
Re: Wimp.com
was the previous poster's issue ever resolved. i am having the same issue. plugin installed however no videos show in online feeds folder.have tried the first plugin and the one that was just updated.
Post Fri Dec 30, 2011 3:59 pm
Re: Wimp.com
iheartninjas wrote:was the previous poster's issue ever resolved. i am having the same issue. plugin installed however no videos show in online feeds folder.have tried the first plugin and the one that was just updated.
Do the files appear if you use AV media controler form intel tools ?
iheartninjas
Post Fri Dec 30, 2011 4:29 pm
Re: Wimp.com
yes the files appear in av media controller
Post Fri Dec 30, 2011 4:37 pm
Re: Wimp.com
then its not a plugin issue but a profile issue.
iheartninjas
Post Fri Dec 30, 2011 4:47 pm
Re: Wimp.com
forgive me but i dont fully understand your reply. what do you mean a profile issue? this is my first time attempting to use the plugins so the terminology is still somewhat new for me. i have made an attempt to use six plugins including youtube, discovery, dogtoons, wimp, etc. the only one that is not showing any videos is wimp.
Post Fri Dec 30, 2011 4:49 pm
Re: Wimp.com
profile.xml contains rules for transcoding of online files aswell as local files. please start a topic in the relevant support forum for your device and supply information on file that wont play/appear on your device.
iheartninjas
Post Fri Dec 30, 2011 7:55 pm
Re: Wimp.com
ok if anyone is willing to deal with my ignorance on this please instruct me how to use ffmpeg -i to "supply information on file that wont play/appear" on my device. i know how to use ffmpeg just unsure how to provide the video file details since they don't appear. thanx
updating my post. i installed latest static build of ffmpeg. this seems to have taken care of the issue that i was having. the video files from http://www.wimp.com/rss now show in feeds folder. update is here:
http://wiki.serviio.org/doku.php?id=win_ffmpeg
arunciks
Post Sat Feb 18, 2012 10:41 pm
Re: Wimp.com
replaced ffmpeg... but no solution getting this error:
2012-02-17 20:33:30,889 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://rom.wimp.com/videosnull. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:273)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:208)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:101)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:344)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:87)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:255)
... 2 more
grolschie
Post Sat Sep 08, 2012 9:06 am
Re: Wimp.com
I also get a similar message:
2012-09-08 18:31:43,078 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://rom.wimp.com/videosnull. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:291)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:382)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:86)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:124)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:268)
   ... 2 more
I think the plugin may no longer work.
Return to Available plugins
Users browsing this forum: No registered users and 139 guests
