Trouble downloading pro
• Page 1 of 1
I bought pro but when they sent me the link it was not an executable file to download. Do I need to go someplace else?
Re: Trouble downloading pro
Download the file included in the email (and save a copy somewhere as the link only works for a week), then open up the console, go to the about tab, and select upload licence.
Thanks for the reply. When i received the link, I downloaded it but it is just information and not an executable file. So I can not even load it. I loaded the regular version but would like to load the Pro. I tried email but they dont answer. Weak support by them. Any ideas?
There isn't a separate download, instead the email contains a licence file. Serviio will read it an unlock the Pro version. You install the normal version, then open the console, click on the about tab, select upload licence, then pick the licence file from the email.
http://www.serviio.org/buy-pro explains the process.
jhawk wrote:Thanks for the reply. When i received the link, I downloaded it but it is just information and not an executable file. So I can not even load it. I loaded the regular version but would like to load the Pro. I tried email but they dont answer. Weak support by them. Any ideas?
Sorry, was away from the country for the weekend. You should have your file by now, and as already mentioned, read the instructions on how to apply it.
Petr
Help translate Serviio
• Page 1 of 1
Users browsing this forum: Google [Bot] and 37 guests
