Bravia not showing online streams
Arrowhawk
Post Sun Sep 09, 2012 4:00 pm
I am having a problem with both my 2010 (32EX403) and 2011 (32EX723) Bravias, where they will not show an online stream from Serviio.
The online option is there in the media menu, however the stream does not show up when added as either an RSS file or a live stream. Serviio is obviously processing the stream correctly as it works fine from the '8player lite' app on my iPhone, so I presume this is an issue with the Bravia profile?
Can anyone help?
The stream is
rtmp://213.163.67.59:443/liverepeater/1up6thsep_18828 playpath=1up6thsep_18828 swfUrl=http://static.4shared.com/flash/player/5.6/player.swf pageUrl=http://foxsportslatam.com/embed.php?id=1up6thsep_18828 tcUrl=rtmp://213.163.67.59:443/liverepeater live=1
And output from ffmpeg -i is
g-config
  author
  copyright
  description
  keywords
  rating
  title
  presetname            Custom
  creationdate          Sun Sep 09 12:24:04 2012
  videodevice           WDM 2860 Capture
  framerate             25.00
  width                 500.00
  height                280.00
  videocodecid          avc1
  videodatarate         500.00
  avclevel              31.00
  avcprofile            77.00
  videokeyframe_frequency5.00
  audiodevice           Microphone (Realtek High Defini
  audiosamplerate       22050.00
  audiochannels         2.00
  audioinputvolume      75.00
  audiocodecid          .mp3
  audiodatarate         48.00
[flv @ 013FC240] Estimating duration from bitrate, this may be inaccurate
Input #0, flv, from 'rtmp://213.163.67.59:443/liverepeater/1up6thsep_18828 playp
.163.67.59:443/liverepeater live=1':
    author          :
    copyright       :
    description     :
    keywords        :
    rating          :
    title           :
    presetname      : Custom
    creationdate    : Sun Sep 09 12:24:04 2012
    videodevice     : WDM 2860 Capture
    avclevel        : 31
    avcprofile      : 77
    videokeyframe_frequency: 5
    audiodevice     : Microphone (Realtek High Defini
    audiochannels   : 2
    audioinputvolume: 75
  Duration: N/A, start: 0.000000, bitrate: 560 kb/s
    Stream #0:0: Video: h264 (Main), yuv420p, 500x280 [SAR 1:1 DAR 25:14], 512 k
b/s, 25 tbr, 1k tbn, 50 tbc
    Stream #0:1: Audio: mp3, 22050 Hz, stereo, s16, 48 kb/s
Post Tue Sep 11, 2012 12:58 pm
Re: Bravia not showing online streams
which profiles are you using?
Post Tue Sep 11, 2012 2:02 pm
and could you enable detailed logging and extract the ffmpeg command line used to transcode this stream ?
Arrowhawk
Post Fri Sep 21, 2012 4:21 pm
Apologies for late reply, the stream went offline so I was unable to check again. It has now come back on, changed to the following -
rtmp://72.46.132.98:443/liverepeater/1c19thsept_19135 app=liverepeater playPath=1c19thsept_19135 swfUrl=http://static.foxsportslatam.com/player.swf pageUrl=http://foxsportslatam.com/embed.php?id=1c19thsept_19135 tcUrl=rtmp://72.46.132.98:443/liverepeater swfVfy=1 live=1
but this still has the same result, it does not show at all on my TV, despite the movies etc. in my library showing and playing fine.
I have tried both the Generic DLNA profile, and the Bravia 2011 profiles and both give the same result.
I cannot get the ffmpeg command used to transcode the stream as the TV does not even give me the option to start playing and so I don't think it will even be starting ffmepg. Is the ffmpeg command used to transcode for playing on another device any use?
Arrowhawk
Post Fri Sep 21, 2012 5:38 pm
Hi again, I have checked the detailed log when playing the stream using '8player lite' on my iPhone and the result is -
2012-09-21 18:30:02,920 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -i rtmp://72.46.132.98:443/liverepeater/1c19thsept_19135 app=liverepeater playPath=1c19thsept_19135 swfUrl=http://static.foxsportslatam.com/player.swf pageUrl=http://foxsportslatam.com/embed.php?id=1c19thsept_19135 tcUrl=rtmp://72.46.132.98:443/liverepeater swfVfy=1 live=1 -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a ac3 -b:a 384k -ar 48000 -ac 2 -map 0:0 -map 0:1 -sn -f mpegts pipe:
2012-09-21 18:30:06,422 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file rtmp://72.46.132.98:443/liverepeater/1c19thsept_19135 app=liverepeater playPath=1c19thsept_19135 swfUrl=http://static.foxsportslatam.com/player.swf pageUrl=http://foxsportslatam.com/embed.php?id=1c19thsept_19135 tcUrl=rtmp://72.46.132.98:443/liverepeater swfVfy=1 live=1: AVC_TS_MP_SD_AC3_ISO
The iPhone is using the Generic DLNA Device profile. I have also tried the stream playing on my Xbox 360 and it works fine on that using the Xbox profile.
