[SOLVED] MKV Problem with diffrent OS
TRMxDEVIL
Post Sun Sep 09, 2012 11:45 am
first: please excuse my bad english i'm from germany...
I've a problem with mkv files on sony renderer with serviio as server on different OS.
On my notebook (Win7 x64) serviio (0.6.2) runs well and mkv files are played without any problems.
On my Server Ubuntu (12.04 LTS x64) serviio (1.0.1) runs great as well only mkv files (same as notebook) can't played on the TV or the BDV-System.
On the TV the error message is: "Server zugriff nicht möglich. Erneut versuchen" -> "Can not Acces Server. Try again."
On the BDV-System error message is: "Datei beschädigt oder verfläscht." -> "File is damaged or corrupted".
TV: Sony-KDL32EX500 profile on both machines (Sony TV 2010)
BDV: Sony-BDV390 profile on both machines (Sony BD Player / SMP)
FFMPEG -i returns:
ffmpeg version 0.8.3-4:0.8.3-0ubuntu0.12.04.1, Copyright (c) 2000-2012 the Libav developers
built on Jun 12 2012 16:52:09 with gcc 4.6.3
[matroska,webm @ 0x217e9a0] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from 'FILENAME_HIDDEN':
Duration: 01:53:05.73, start: 0.000000, bitrate: 2176 kb/s
Chapter #0.0: start 0.000000, end 745.203000
title : 00:00:00.000
Chapter #0.1: start 745.203000, end 1197.780000
title : 00:12:25.203
Chapter #0.2: start 1197.780000, end 1821.486000
title : 00:19:57.780
Chapter #0.3: start 1821.486000, end 2335.041000
title : 00:30:21.486
Chapter #0.4: start 2335.041000, end 2988.235000
title : 00:38:55.041
Chapter #0.5: start 2988.235000, end 3611.066000
title : 00:49:48.235
Chapter #0.6: start 3611.066000, end 4187.392000
title : 01:00:11.066
Chapter #0.7: start 4187.392000, end 4776.772000
title : 01:09:47.392
Chapter #0.8: start 4776.772000, end 5345.340000
title : 01:19:36.772
Chapter #0.9: start 5345.340000, end 5976.888000
title : 01:29:05.340
Chapter #0.10: start 5976.888000, end 6506.041000
title : 01:39:36.888
Chapter #0.11: start 6506.041000, end 6785.739000
title : 01:48:26.041
Stream #0.0(ger): Video: h264 (High), yuv420p, 1920x1080, PAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) (forced)
Stream #0.1(ger): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s (default) (forced)
Stream #0.2(eng): Audio: dca (DTS), 48000 Hz, 5.1, s16, 1536 kb/s
Stream #0.3(ger): Subtitle: dvdsub (default) (forced)
title : Forced VobSubs
Stream #0.4(ger): Subtitle: dvdsub
title : VobSubs komplett
Post Sun Sep 09, 2012 5:28 pm
Re: MKV Problem with diffrent OS
TRMxDEVIL wrote:ffmpeg version 0.8.3-4:0.8.3-0ubuntu0.12.04.1, Copyright (c) 2000-2012 the Libav developers
Need to update your ffmpeg version.
TRMxDEVIL
Post Sun Sep 09, 2012 6:10 pm
Hi thanks for promt answer,
I followed this Guide http://wiki.serviio.org/doku.php?id=howto:linux:install:ubuntu to setup. Perhaps should be Updated.
I now get ffmpeg from git like this Guide (https://ffmpeg.org/trac/ffmpeg/wiki/UbuntuCompilationGuide). And it runs =)
THANKS
Post Sun Sep 09, 2012 6:56 pm
TRMxDEVIL wrote:And it runs =)
THANKS
Enjoy it.
