Newbie - truncated music files
RoyS
Post Sat Sep 01, 2012 3:43 pm
Hi - I am a newbie to Serviio and would welcome help with the following problem.
A few months ago, I installed Serviio to play the music stored on my NAS to my Samsung TV. The music files are all FLAC. I was able to access Serviio from the TV and play the music successfully.
I have now upgraded Serviio to 1.0.1 and replaced the TV with a Samsung UE32ES5500. As before, I can access and play the music BUT, no matter how large the files, the track length is given as 1:25.02 and the music truncated after this time; the next track is played with the same result.
The same music copied to a USB hard drive attached directly to the TV plays OK (I was very surprised to find FLAC is a supported format for direct-attached files).
many thanks in advance - Roy
NB This problem was originally posted in the User Experiences sub-forum but has been re-entered after getting no response.
Post Sun Sep 09, 2012 11:33 pm
Re: Newbie - truncated music files
can you post detailed log of playing the file? Also ffmpeg -i of the file.
RoyS
Post Thu Sep 13, 2012 5:38 pm
Thanks for the response. As I said, I am new to this type of software and after more time spent on it I realise that, altho' there does appear to be a problem, it is not as I described. What appears to be happening is:
- I select Serviio as the source on my TV, either directly using Source or indirectly using Allshare and working thro'
- the first track (all are FLAC) that I select displays the correct length and plays through properly
- the second and subsequent tracks show a length of 1:25:02 (ie 1 hr 25 minutes 2 seconds), play properly to the end of the track and then show an error message
'The selected file is not currently supported'. After a pause of several seconds, the next track is selected and the same thing happens.
- this happens whether the tracks are in the same album or are single tracks from different albums (folders)
- also, it happens whether I am using Folders or Composers view
Hope this gives you enough info
best wishes - Roy Simpson
