SMP-N200 not working with 1.0.1
mystycs
Post Mon Sep 10, 2012 7:26 am
So apprently my SMP-N200 doesnt seem to recognize or see serviio online as of update 1.0.1 but it works fine with 1.0. I tried reinstalling it only works for the first time on 1.0.1 but after a restart it just doesnt see the device as online and the device shows the server offline. But on 1.0 it works fine.
Is it possible 1.0.1 changed somethign with this device? I had to go back to 1.0
Post Mon Sep 10, 2012 7:29 am
Re: SMP-N200 not working with 1.0.1
Do you fix all devices IP address ?
When you make a serviio update, I suggest to:
- Open serviio console device list:
- Remove all devices
- Save
- Restart serviio services
- Open serviio console and refresh device list
- Save
mystycs
Post Mon Sep 10, 2012 7:31 am
Yeah i tried everything it just seems to be 1.0.1 for me. Unless its something corrupt in some file of mine somewhere?
mystycs
Post Mon Sep 10, 2012 7:32 am
Pretty much the second i installed version 1.0 i saw it. But if i have 1.0.1 it seems to dissapear after a restart and i can never see the servio server online on my smp n200. Maybe i need more testing well see how version 1 does.
Post Mon Sep 10, 2012 7:36 am
Do you have a PRO version ?
http://www.serviio.org/buy-pro/10-uncat ... ree-vs-pro
Do you enable "Controlling access to shared content" feature ? http://www.serviio.org/buy-pro/10-uncat ... tion-rules
mystycs
Post Mon Sep 10, 2012 7:38 am
I did not look at this. I will try to update and update here if this works. I think i had free not sure :o
