[SOLVED]How to make video playlist work on Sony Bravia EX520
Solos
Post Mon Sep 10, 2012 6:05 pm
I've created video playlist from several short videos for my daughter. When I open Servio ---> Playlists on my TV menu, I can see the playlist name as a regular folder. When I enter that playlist I can see list of video files and when I hit play on one of the videos, only that video is played. It works like playing single file from a folder, not like playlist. I tried with different playlist types: pls, m3u etc. Nothing works. Can somebody help me solve this problem and make playlists work? I'd be grateful.
Solos
Post Mon Sep 10, 2012 6:15 pm
Re: How to make video playlist work on Sony Bravia EX520?
Do you enable on Sony Bravia option :
HOME -> Serviio -> OPTIONS remote button : Playback option -> Playback Target : All clips
Solos
Post Mon Sep 10, 2012 7:49 pm
No, I wasn't aware of that option :) Thx.
Post Tue Sep 11, 2012 7:00 am
Solos wrote:No, I wasn't aware of that option :) Thx.
Does that solves your problem?
Solos
Post Tue Sep 11, 2012 7:14 am
Yes, now it works perfectly :) Once again, thank You.
Nutte
Post Mon Feb 25, 2013 2:39 am
Illico wrote:Do you enable on Sony Bravia option :
Where do you find this option?!?
I don't have a Bravia EX520, but I've the same issue with the PS3.
Don't find anything like this is the config/xml files. Are there a whole bunch of settings I've missed?
Post Mon Feb 25, 2013 8:06 am
Nutte wrote:Where do you find this option?!?
On my Sony Bravia menu...
I don't know PS3 options...
Nutte wrote:I don't have a Bravia EX520, but I've the same issue with the PS3.
config/xml files ??!
We are talking about Sony devices menu options.
Nutte
Post Tue Feb 26, 2013 5:41 am
Re: [SOLVED]How to make video playlist work on Sony Bravia E
Thanks for confirming that.
I've never seen such option on any of my Sony devices, so I kind of assumed it was on the server side...
Will post the same question about PS3 in a new thread.
