UA55D7000 samsung 55 inch LED no Resume
Mikem
Post Tue Sep 11, 2012 4:21 am
Re: UA55D7000 samsung 55 inch LED no Resume
Is it the serviio log file you wanted, and how do i send ?
Mikem
Post Tue Sep 11, 2012 8:39 am
ok, take two. I read a few other threads and transcoding was mentioned. So i unticked transcoding and now it all works. Zipster i can confirm this as this time i made sure i disabled ALLSHARE and then un-installed it so i wouldn't make the same embarrassing mistake.
So turn off transcoding , restart serviio and then turn on the tv :) I can confirm that doing this fixed the problem. Thanks Zipp :)
Mikem
Post Thu Sep 13, 2012 12:14 am
This in conjunction to what Zip said regarding deleting those lines is a fix. Been going for a couple of days without dramas. Can we rename this post with a fixed on the end ?
Post Thu Sep 13, 2012 10:25 pm
can you post few MediaInfo results of the mkv files that didn't work and now do?
Previous
Users browsing this forum: No registered users and 58 guests
