error 200 no stream
theprisoner
Post Sun Sep 09, 2012 8:12 am
error 200 no stream
I get this error when trying to play a video.
This happens on Ubunty where I also uninstalled and reinstalled flash.
On Lubuntu laptop
and also on a Windows laptop with the latest flash.
Any ideas how I can fix it?
Uploaded with ImageShack.us
Post Sun Sep 09, 2012 8:37 am
Re: error 200 no stream
Post a detailed log of you playing a video (see my sig) and confirm which version of ffmpeg you have for Linux
theprisoner
Post Sun Sep 09, 2012 8:50 am
will wrote:Post a detailed log of you playing a video (see my sig) and confirm which version of ffmpeg you have for Linux
j-media-centre@jmediacentre-A880G:~/.serviio/log$ ffmpeg
ffmpeg version 0.8.3-4:0.8.3-0ubuntu0.12.04.1, Copyright (c) 2000-2012 the Libav developers
built on Jun 12 2012 16:37:58 with gcc 4.6.3
Use -h to get full help or, even better, run 'man ffmpeg'
(308.22 KiB) Downloaded 616 times
Post Sun Sep 09, 2012 9:59 am
That version of ffmpeg is far too old. See the wiki for how to compile a newer version.
theprisoner
Post Sun Sep 09, 2012 9:44 pm
followed all that.
BTW, this command in your wiki:
sudo apt-get remove ffmpeg x264 libx264-dev libvpx-dev librtmp0 librtmp-dev
actually removes a whole bunch of software from Ubuntu...not ideal!
Anyway, now on loading a video it works. However, full screen quqality is not very good, it has to be viewed in the samll size window to be dec3ent.
It appears a bit pixelated on fullscreen.
Post Sun Sep 09, 2012 10:06 pm
Change the quality from Medium to Original if you have enough upstream bandwidth.
theprisoner
Post Mon Sep 10, 2012 8:34 am
will wrote:Change the quality from Medium to Original if you have enough upstream bandwidth.
already did that and it's running on another computer on a LAN so bandwidth should be v high
theprisoner
Post Tue Sep 11, 2012 6:30 pm
any ideas?
Post Tue Sep 11, 2012 6:36 pm
what is your ffmpeg version now? Post detailed log of when playing the file and also ffmpeg -i of the file.
theprisoner
Post Tue Sep 11, 2012 7:51 pm
j-media-centre@jmediacentre-A880G:~$ ffmpeg
ffmpeg version git-2012-09-09-2474ca1 Copyright (c) 2000-2012 the FFmpeg developers
built on Sep 9 2012 22:37:04 with gcc 4.6 (Ubuntu/Linaro 4.6.3-1ubuntu5)
configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid
libavutil 51. 72.100 / 51. 72.100
libavcodec 54. 55.100 / 54. 55.100
libavformat 54. 25.105 / 54. 25.105
libavdevice 54. 2.100 / 54. 2.100
libavfilter 3. 16.101 / 3. 16.101
libswscale 2. 1.101 / 2. 1.101
j-media-centre@jmediacentre-A880G:~$ ^C
(382.93 KiB) Downloaded 553 times
Post Tue Sep 11, 2012 8:09 pm
That looks ok. Looks like you first tried MEDIUM quality and then ORIGINAL. The latter should give you the same quality as the source. If not, it might be down to your flash player..?
theprisoner
Post Wed Sep 26, 2012 5:55 pm
any ideas what the problem could be?
