Aspect ratio problem with online source
• Page 1 of 1
How can I force an aspect ratio for an individual live online source? My LG shows IPTV 16:9 streams with 4:3 aspect ratio. sorry , can't post links as they would not work for you anyway. The links were extracted from an xspf playlist I downloaded from provider (could not find a way to feed the entire list to Serviio). The xspf file contains aspect ratios for individual channels, but I can't specify this info for online source links in Serviio Console. Any ideas? I thought that maybe tweaking profiles xml would help?
Re: Aspect ratio problem with online source
post ffmpeg -i "stream_url"
Petr
Help translate Serviio
zip wrote:post ffmpeg -i "stream_url"
i have the same problem.
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-li
brtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-
prefix=i686-w64-mingw32- --pkg-config=pkg-config
[mpeg2video @ 02B700C0] mpeg_decode_postinit() failure
Last message repeated 10 times
[mpegts @ 015BC3E0] max_analyze_duration 5000000 reached at 5016000
[mpegts @ 015BC3E0] Estimating duration from bitrate, this may be inaccurate
Input #0, mpegts, from 'http://8****************************************':
Duration: N/A, start: 82572.653078, bitrate: 15192 kb/s
Program 1
Stream #0:0[0x44](rus): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16, 192 kb/s
Stream #0:1[0x45]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p, 704x576 [SAR 16:11 DAR 16:9], 15000 kb/s, 26.96 fps, 25 tbr, 90k tbn, 50 tbc
I have streams in 16:9 and in 4:3. All my sources added manually in online source / live stream ->url : .......
My TV: 37LV5500
The problem come from SAR 16:11, relative to this issue: https://bitbucket.org/xnejp03/serviio/i ... d-displays
Illico wrote:The problem come from SAR 16:11, relative to this issue: https://bitbucket.org/xnejp03/serviio/i ... d-displays
This is only related to FLV transcoding, ie MediaBrowser. He has problems on the TV AFAIK.
levitmic: Can you post detailed log of when playing the stream?
Petr
This is not SAP link.
zip wrote:levitmic: Can you post detailed log of when playing the stream?
zip wrote:This is only related to FLV transcoding, ie MediaBrowser. He has problems on the TV AFAIK.
Yes, on log :
This link is delivered in native format, but it seems that the device close the connection
2012-09-14 07:55:52,772 DEBUG [VideoDeliveryEngine] Delivering file 'http://87.239.31.209:7001/?sid=b1bedcb431e445bf72e50c706dd048be' in native format
2012-09-14 07:55:52,772 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-09-14 07:55:52,772 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-09-14 07:55:52,772 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Fri, 14 Sep 2012 04:55:52 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-09-14 07:55:52,772 DEBUG [OnlineInputStream] Reading 1512000 bytes starting at 0
2012-09-14 07:55:52,878 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2012-09-14 07:55:52,878 DEBUG [OnlineInputStream] Closing stream
2012-09-14 07:55:53,376 DEBUG [OnlineInputStream] Byte range not supported for http://87.239.31.209:7001/?sid=b1bedcb4 ... 706dd048be, returning the whole stream
Could you provide ffmpeg -i "http://87.239.31.209:7001/?sid=b1bedcb431e445bf72e50c706dd048be" result ?
Illico wrote:Could you provide ffmpeg -i "http://87.239.31.209:7001/?sid=b1bedcb431e445bf72e50c706dd048be" result ?
C:\Program Files (x86)\Serviio\lib>ffmpeg -i "http://87.239.31.209:7001/?sid=b1bedcb431e445bf72e50c706dd048be"
[mpeg2video @ 02CC0000] mpeg_decode_postinit() failure
Last message repeated 22 times
[mpegts @ 0138C3C0] max_analyze_duration 5000000 reached at 5016000
[mpegts @ 0138C3C0] Estimating duration from bitrate, this may be inaccurate
Input #0, mpegts, from 'http://87.239.31.209:7001/?sid=b1bedcb431e445bf72e50c706dd048be':
Duration: N/A, start: 54642.426989, bitrate: 15192 kb/s
Program 1
Stream #0:1[0x45]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p, 704x576 [SAR 16:11 DAR 16:9], 15000 kb/s, 30.10 fps, 25 tbr, 90k tbn, 50 tbc
The file is not transcoded, therefore up to the player to properly display the DAR.
You could set up transcodng of (online) mpegts streams and force DAR="16:9", but I'm not sure how well the LG behaves with transcoded streams.
Petr
I am a newbie using Serviio, I use a LG 42LW650S and have a similar aspect ratio issue to the one described in this topic...
I have managed to see on my TV SopCast streams using the SopCast groovy, they always play at full screen on my TV (I believe is 16:9).
I have managed to see AceStreams using the method described in http://forum.serviio.org/viewtopic.php?f=20&t=15372 the problem is that AceStreams play in 4:3 on my TV, I can see the ACE player plays at the correct ratio on my PC running Serviio, so seems to be the TV not doing a great job.
I have tried modifying the transcoding options but and broke it a couple of times
so not sure what else to try, this is what my profiles.xml looks like now:
<Profile id="8" name="LG TV / player" extendsProfileId="1">
<Detection>
<HttpHeaders>
<friendlyName.dlna.org>LG.*</friendlyName.dlna.org>
</HttpHeaders>
</Detection>
<ResourceTransportProtocolHandler>org.serviio.upnp.protocol.http.transport.LGProtocolHandler</ResourceTransportProtocolHandler>
<MediaFormatProfiles>
<MediaFormatProfile mime-type="video/mp4" name="">AVI</MediaFormatProfile>
</MediaFormatProfiles>
Transcoding doesn't seem to work and some files can be played natively:
viewtopic.php?f=12&t=3914#p26273-->
<Video targetContainer="mpegts" targetACodec="ac3" DAR="16:9" >
<Video targetContainer="mpegts" targetVCodec="mpeg2video" DAR="16:9" targetACodec="ac3" >
<Matches container="flv" />
<Matches container="asf" vCodec="wmv2"/>
<Matches container="rm" />
<Matches container="wtv" />
<OnlineTranscoding>
<Video targetContainer="mpegts" targetACodec="ac3" DAR="16:9">
<Matches container="applehttp" vCodec="h264" />
<Matches container="asf"/>
<Matches container="rtp"/>
<Matches container="rtsp"/>
</OnlineTranscoding>
<HardSubsTranscoding>
<Video targetContainer="mpegts" targetVCodec="mpeg2video" DAR="16:9" targetACodec="ac3" />
</HardSubsTranscoding>
<Subtitles>
<SoftSubs mime-type="text/srt" />
</Subtitles>
Thanks in advance.
<Detection>
<HttpHeaders>
</HttpHeaders>
</Detection>
<OnlineTranscoding>
<Subtitles>
</Subtitles>
Thanks in advance.
• Page 1 of 1
