Console does not open
• Page 1 of 1
When I try to run ServiioConsole, nothing opens. I had upgraded from 0.61 and I also tried doing a clean installation by removing the old serviio folder in Program Files. How can I go back to version 0.62?
Re: Console does not open
Looks like the server is binding to a virtual NIC 10.0.0.1.
Petr
Help translate Serviio
I see it binding to 10.0.0.10. Yes, this is a virtual machine, so the adapter will be virtual. No problems with it before.
Petr
It responds with the following XML:
media browser also loads just fine (don't have a password so I can't login)
dmarlow wrote:media browser also loads just fine (don't have a password so I can't login)
Password must be set on serviio console.
try to upgrade Java
Petr
Went to java 7, that didn't work. I guess it's not supported yet by serviio. I then removed java 6.20 and installed java 6.35 and it's now working.
Many thanks!
Many thanks!
• Page 1 of 1
