File not playing on PS3
Kamika007z
Post Tue Aug 28, 2012 2:34 am
To note:
I just installed 1.01 and registered it to the PRO version for support to the author, and while I'm able to see the MKV video listed on the XMB, as soon as I try to the play it on my PS3, it tries to load then erros out stating "unsupported file type" causing the image of the video title on the XMB menu to no longer display.
Post Tue Aug 28, 2012 10:52 pm
Re: Blocky image transcoding MKV for PS3
Kamika007z wrote:To note:
Make sure you have PS3 profile selected. If yes, post detailed log, possibly FFmpeg is failing.
Kamika007z
Post Tue Aug 28, 2012 11:23 pm
Hi zip,
Thank you for the prompt response.
The PS3 gets an IP via DHCP, so through DLNA serviio detects it appropriately and I do see it show up on serviio's main page with an orange dot next to it as well as the correct PS3 profile provisioned for it.
How do I go about posting the log here?
Finally, is there a preferred codec pack that I should be using? Currently I have the "Media Player Codec Pack" installed on my box which is running Win7 x64.
Thank you,
Kamika007z
Xmantium
Post Wed Aug 29, 2012 11:21 pm
To give info of a file that doesn't play, follow this - viewtopic.php?f=5&t=1123
And post you results here enclosed in Code forum format.
There's no codec pack needed for Serviio, it uses the powerful FFMPEG to stream your files to your PS3. The Windows build is already packaged with this.
Kamika007z
Post Fri Aug 31, 2012 3:37 am
Hi all,
Thank you for your help with this so far!
Here is the information that you have requested:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "d:\videos\temp_video.mkv"
g-config
Input #0, matroska,webm, from 'd:\videos\the avengers.mkv':
    creation_time   : 2012-08-21 21:00:18
  Duration: 02:22:54.90, start: 0.000000, bitrate: 7009 kb/s
    Chapter #0.0: start 0.000000, end 482.315000
      title           : 01. Arrival
    Chapter #0.1: start 482.315000, end 709.167000
      title           : 02. Lost
    Chapter #0.2: start 709.167000, end 918.751000
      title           : 03. Interrogation
    Chapter #0.3: start 918.751000, end 1233.482000
      title           : 04. Guy
    Chapter #0.4: start 1233.482000, end 1384.258000
      title           : 05. Time
    Chapter #0.5: start 1384.258000, end 1779.444000
      title           : 06. Spice
    Chapter #0.6: start 1779.444000, end 2243.992000
      title           : 07. Bargain
    Chapter #0.7: start 2243.992000, end 2567.982000
      title           : 08. Confrontation
    Chapter #0.8: start 2567.982000, end 3022.269000
      title           : 09. Battle
    Chapter #0.9: start 3022.269000, end 3664.661000
      title           : 10. Play?
    Chapter #0.10: start 3664.661000, end 4445.107000
      title           : 11. Rise
    Chapter #0.11: start 4445.107000, end 5281.234000
      title           : 12. Battle
    Chapter #0.12: start 5281.234000, end 5900.561000
      title           : 13. Down
    Chapter #0.13: start 5900.561000, end 6340.167000
      title           : 14. Begins
    Chapter #0.14: start 6340.167000, end 6675.085000
      title           : 15. War
    Chapter #0.15: start 6675.085000, end 7067.769000
      title           : 16. Together
    Chapter #0.16: start 7067.769000, end 7478.680000
      title           : 17. Lost
    Chapter #0.17: start 7478.680000, end 7779.397000
      title           : 18. Play
    Chapter #0.18: start 7779.397000, end 7990.691000
      title           : 19. Promise
    Chapter #0.19: start 7990.691000, end 8574.902000
      title           : 20. Credits
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9],
23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), s16, 1536 kb/s (def
ault)
    Stream #0:2(eng): Subtitle: text
    Stream #0:3(eng): Subtitle: text (default) (forced)
    Stream #0:4(eng): Subtitle: text
    Stream #0:5(est): Subtitle: text
    Stream #0:6(fin): Subtitle: text
    Stream #0:7(ice): Subtitle: text
    Stream #0:8(lav): Subtitle: text
    Stream #0:9(lit): Subtitle: text
    Stream #0:10(nor): Subtitle: text
    Stream #0:11(rus): Subtitle: text
      title           : u
    Stream #0:12(rus): Subtitle: text
    Stream #0:13(swe): Subtitle: text
    Stream #0:14(ukr): Subtitle: text
    Stream #0:15(ukr): Subtitle: text
To note, my machine is an Intel Q9450 system with 8GB of RAM running Windows 7 x64 with SP1 Ultimate.
Thanks again!
Kamika007z
Post Wed Sep 05, 2012 12:52 pm
Any ideas?
Post Thu Sep 06, 2012 11:58 am
I'm going to split this topic.
Attach detailed log of when you play the file.
Kamika007z
Post Thu Sep 06, 2012 1:05 pm
Re: File not playing on PS3
Hi zip,
Thank you. Should I keep posting on this thread?
How do I go about getting the log when I try to play it? Try to play it on the PS3 and then check the log that it automatically creates?
Please let me know.
Thank you!
chakdag
Post Sun Sep 09, 2012 8:02 am
Hi, i'm experiencing the same issue (blocking image) with an mkv file i'd like to play through the PS3.
However if i play it through my Toshiba Regza media player it works, which makes me think it is a transcoding issue with the PS3.
If i play other mkv files it works without issue on the PS3.
here is the ffmpeg info
Da-Good-Old-Chap:MacOS DaGoodOldChap$ ./ffmpeg -i ~/Movies/The.Avengers.2012.720p.BluRay.x264-NYDIC.mkv
built on Jul 10 2012 22:12:54 with gcc 4.0.1 (Apple Inc. build 5493)
configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include --extra-libs=-lpolarssl
Input #0, matroska,webm, from '/Users/DaGoodOldChap/Movies/The.Avengers.2012.720p.BluRay.x264-NYDIC.mkv':
creation_time : 2012-08-20 21:48:56
Duration: 02:22:54.90, start: 0.000000, bitrate: 7383 kb/s
Stream #0:0(eng): Video: h264 (Main), yuv420p, 1280x720, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 180k tbc (default)
Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), s16, 1536 kb/s (default) (forced)
i'm using serviio 1.0.1
a mac intel 2.4ghz / 4gb ram with mountain lion
renderers PS3 and Toshiba Regza
Thanks for helping
Chak
Kamika007z
Post Sun Sep 16, 2012 2:14 pm
Kamika007z wrote:Hi zip,
Please let me know.
Thank you!
zip,
You never wrote back.
How do go about getting the log file when I play it on the ps3?
Please respond.
Thank you.
Post Sun Sep 16, 2012 3:07 pm
Kamika007z wrote:How do go about getting the log file when I play it on the ps3?
Enable detailed logging (see signature link) : http://wiki.serviio.org/doku.php?id=detail_logging
To make a "clean" log file :
1- Stop serviio service
2- Delete serviio.log files
3- Restart serviio service
4- play the file.
5- post the serviio.log file
Users browsing this forum: Google [Bot] and 17 guests
