.dir file in C:\ root
• Page 1 of 1
I noticed a .dir file with no filename kept popping up in the root of C:\, I used Process Monitor and noticed Serviio service was creating it. All the file contains is a timestamp and a big hash. Just curious what the purpose of this file is...I'm on Windows 8 but never noticed this on Windows 7.
Re: .dir file in C:\ root
Not sure. Might be created by libRTMP to cache security hashes (but normally is under user's tmp folder)
Petr
Help translate Serviio
zip wrote:Not sure. Might be created by libRTMP to cache security hashes (but normally is under user's tmp folder)
Interesting, not sure how that would get redirected to root of C:\, curious if other Windows 8 users see this.
seus wrote:zip wrote:Not sure. Might be created by libRTMP to cache security hashes (but normally is under user's tmp folder)
Running win7 home premium i have this file. I didnt know where it came from
It's there possibly because the user running the service doesn't have a 'home' directory?
Petr
zip wrote:It's there possibly because the user running the service doesn't have a 'home' directory?
It's running as SYSTEM under Windows so I guess that's possible, just not sure why I never saw it in the past.
I have this problem as well. There's a .dir file in C:\
When looking in the Serviio log I see this:
I assume it's going into C:\ because that's what the user home dir is? Is there a way to change the user home dir?
- Code:
2012-10-31 21:12:57,256 INFO [MediaServer] Serviio DLNA media streaming server v 1.0.1 (rev. 6dbf7c6e334f+)
2012-10-31 21:12:57,256 INFO [MediaServer] Petr Nejedly 2009-2012
2012-10-31 21:12:57,256 INFO [MediaServer] http://www.serviio.org
2012-10-31 21:12:57,256 INFO [MediaServer] Java 1.7.0_05-Oracle Corporation
2012-10-31 21:12:57,256 INFO [MediaServer] OS Windows 7 amd64 6.1
2012-10-31 21:12:57,256 INFO [MediaServer] File encoding: windows-1252
2012-10-31 21:12:57,256 INFO [MediaServer] Headless mode enabled: true
2012-10-31 21:12:57,256 INFO [MediaServer] User home dir: C:\
2012-10-31 21:12:57,256 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
Petr
zip wrote:try to set user.home system property
http://www.serviio.org/index.php?option ... e&id=21#q3
What should I set it to? Would my temp folder be an ok place?
set it to your user folder, i.e. /Users/username or Documents and Settings/username
Petr
Hi, I have also problem with dir file on my C drive. I tried edit ServiioService.exe.vmoptions and add there new line with /Users/username, but it not work for me
In my ServiioService.exe.vmoptions is this:
I also tried some modifications, for example "C:\Users\michpo", but also not work
Please can you help me?
NOt sure if the above helps, it might be internal to librtmp. Is that such a problem the file is there?
Petr
Why the dir file is in root of C drive? For what is this file?
I like tidy on my drives. In older versions of Serviio this file was not on root of C drive. Why now yes?
I think that it will be better if the file will be in Serviio folder.
Petr
Thanks for your reply. After this change I obtaining this error message: Cannot connect to Serviio server, it does not seem to be running. Exiting...
Serviio service not run, and if I want to start it, nothing happens
Petr
Still not working
When I try to run service from task manager, nothing happens. But if I try to run service from service window, then I obtain this error message: "Error 1067 : The Process terminated unexpectedly".
There is no information about this problem in serviio.log file.
Petr
Nice! It works
Thanks mate.
Thanks mate.
• Page 1 of 1
Users browsing this forum: Baidu [Spider], Google [Bot] and 47 guests
