No thumbnails after updating
jfcg
Post Tue Sep 11, 2012 9:43 pm
Hello!
Recently, I update Serviio to 1.0.1 (from 0.6.2) and I can't see thumbnails as before :S I have a C-Series TV and everything seems to be ok on detailed log. I don't know if it's a corrupted library. What can I check to solve the problem?
Thanks in advance!
jfcg
Post Sat Sep 15, 2012 3:26 pm
Re: No thumbnails after updating
Ok, I delete my library and started from scratch: a clean installation. But it's the same. No thumbnails :S
No one can help me?
Post Sun Sep 16, 2012 12:03 am
Thumbnails for what? Music/Images/Video? Do you have online metadata on?
jfcg
Post Sun Sep 16, 2012 10:31 am
Thanks zip for your reply.
I meant video thumbnails. I don't want online metadata, so I have turned that option off. I just want a frame from the video as a thumbnail, as previously. In serviio 0.6.2 I had the same settings, and I got video thumbnails. Isn't there any option to get video thumbnails without online metadata turned on in Serviio 1.0?
Post Sun Sep 16, 2012 7:07 pm
Yes, make sure you select the option Generate thumbnails for local videos.
jfcg
Post Sun Sep 16, 2012 8:38 pm
Yes, I turned that option on. Anything more to check?
Post Sun Sep 16, 2012 11:16 pm
try to click on rescan video metadata - as shown on your screenshot.
You can try to enable detailed log to check ffmpeg is invoked to generate the thumbnail.
jfcg
Post Wed Sep 19, 2012 9:13 pm
Here is the beginning of the detailed log when I force to update metadata. I can't see anything wrong. Can you help me?
2012-09-19 23:00:05,446 DEBUG [ActionsServerResource] Action with name 'forceVideoFilesMetadataUpdate' was requested
2012-09-19 23:00:05,446 INFO  [LibraryManager] Forcing metadata update for 'VIDEO' media files
2012-09-19 23:00:05,446 DEBUG [MediaItemDAOImpl] Marking MediaItems (type = VIDEO) as dirty
2012-09-19 23:00:20,077 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-09-19 23:00:20,077 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-09-19 23:00:39,354 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.195, timeout = 0
2012-09-19 23:00:39,355 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device ffaf0b4b-a3be-3ed8-a235-a6ac83a874b6
2012-09-19 23:00:41,160 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:52
2012-09-19 23:01:20,078 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-09-19 23:01:20,078 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-09-19 23:01:33,409 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.195, timeout = 0
2012-09-19 23:01:33,410 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device ffaf0b4b-a3be-3ed8-a235-a6ac83a874b6
2012-09-19 23:01:35,212 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:55
2012-09-19 23:02:20,079 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-09-19 23:02:20,079 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-09-19 23:02:30,327 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.195, timeout = 0
2012-09-19 23:02:30,328 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device ffaf0b4b-a3be-3ed8-a235-a6ac83a874b6
2012-09-19 23:02:32,131 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:53
2012-09-19 23:03:20,080 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-09-19 23:03:20,080 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-09-19 23:03:25,219 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.195, timeout = 0
2012-09-19 23:03:25,220 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device ffaf0b4b-a3be-3ed8-a235-a6ac83a874b6
2012-09-19 23:03:27,086 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:38
2012-09-19 23:04:06,057 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.195, timeout = 0
2012-09-19 23:04:06,058 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device ffaf0b4b-a3be-3ed8-a235-a6ac83a874b6
2012-09-19 23:04:07,861 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:53
2012-09-19 23:04:20,081 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-09-19 23:04:20,081 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-09-19 23:04:20,097 DEBUG [PlaylistDAOImpl] Reading all Playlists
2012-09-19 23:04:23,945 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-09-19 23:04:23,946 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /home/usuario/Series
2012-09-19 23:04:23,946 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /home/usuario/Series/Fringe
2012-09-19 23:04:23,947 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT
2012-09-19 23:04:23,948 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fringe.S03E17.720p.HDTV.X264-DIMENSION.mkv', checking if it's already in the Library
2012-09-19 23:04:23,948 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fringe.S03E17.720p.HDTV.X264-DIMENSION.mkv
2012-09-19 23:04:23,948 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/Fringe.S03E17.720p.HDTV.X264-DIMENSION.mkv, ignore case: false
2012-09-19 23:04:23,948 DEBUG [MediaItemDAOImpl] Media item Fringe.S03E17.720p.HDTV.X264-DIMENSION.mkv already exists in DB
2012-09-19 23:04:23,948 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fringe.S03E19.720p.HDTV.X264-DIMENSION.mkv', checking if it's already in the Library
2012-09-19 23:04:23,949 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fringe.S03E19.720p.HDTV.X264-DIMENSION.mkv
2012-09-19 23:04:23,949 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/Fringe.S03E19.720p.HDTV.X264-DIMENSION.mkv, ignore case: false
2012-09-19 23:04:23,949 DEBUG [MediaItemDAOImpl] Media item Fringe.S03E19.720p.HDTV.X264-DIMENSION.mkv already exists in DB
2012-09-19 23:04:23,949 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fringe.S03E15.720p.HDTV.X264-DIMENSION.mkv', checking if it's already in the Library
2012-09-19 23:04:23,949 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fringe.S03E15.720p.HDTV.X264-DIMENSION.mkv
2012-09-19 23:04:23,949 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/Fringe.S03E15.720p.HDTV.X264-DIMENSION.mkv, ignore case: false
2012-09-19 23:04:23,950 DEBUG [MediaItemDAOImpl] Media item Fringe.S03E15.720p.HDTV.X264-DIMENSION.mkv already exists in DB
2012-09-19 23:04:23,950 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fringe.S03E16.720p.HDTV.X264-DIMENSION.mkv', checking if it's already in the Library
2012-09-19 23:04:23,950 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fringe.S03E16.720p.HDTV.X264-DIMENSION.mkv
2012-09-19 23:04:23,950 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/Fringe.S03E16.720p.HDTV.X264-DIMENSION.mkv, ignore case: false
2012-09-19 23:04:23,951 DEBUG [MediaItemDAOImpl] Media item Fringe.S03E16.720p.HDTV.X264-DIMENSION.mkv already exists in DB
2012-09-19 23:04:23,951 DEBUG [LibraryAdditionsCheckerThread] Found file 'fringe.s03e08.720p.hdtv.x264-ctu.mkv', checking if it's already in the Library
2012-09-19 23:04:23,951 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item fringe.s03e08.720p.hdtv.x264-ctu.mkv
2012-09-19 23:04:23,951 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/fringe.s03e08.720p.hdtv.x264-ctu.mkv, ignore case: false
2012-09-19 23:04:23,951 DEBUG [MediaItemDAOImpl] Media item fringe.s03e08.720p.hdtv.x264-ctu.mkv already exists in DB
2012-09-19 23:04:23,952 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fringe.S03E12.720p.HDTV.X264-DIMENSION.mkv', checking if it's already in the Library
2012-09-19 23:04:23,952 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fringe.S03E12.720p.HDTV.X264-DIMENSION.mkv
2012-09-19 23:04:23,952 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/Fringe.S03E12.720p.HDTV.X264-DIMENSION.mkv, ignore case: false
2012-09-19 23:04:23,952 DEBUG [MediaItemDAOImpl] Media item Fringe.S03E12.720p.HDTV.X264-DIMENSION.mkv already exists in DB
2012-09-19 23:04:23,952 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fringe.S03E06.720p.HDTV.X264-DIMENSION.mkv', checking if it's already in the Library
2012-09-19 23:04:23,952 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fringe.S03E06.720p.HDTV.X264-DIMENSION.mkv
2012-09-19 23:04:23,953 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/Fringe.S03E06.720p.HDTV.X264-DIMENSION.mkv, ignore case: false
2012-09-19 23:04:23,953 DEBUG [MediaItemDAOImpl] Media item Fringe.S03E06.720p.HDTV.X264-DIMENSION.mkv already exists in DB
2012-09-19 23:04:23,953 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fringe.S03E22.720p.HDTV.X264-DIMENSION.mkv', checking if it's already in the Library
2012-09-19 23:04:23,953 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fringe.S03E22.720p.HDTV.X264-DIMENSION.mkv
2012-09-19 23:04:23,953 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/Fringe.S03E22.720p.HDTV.X264-DIMENSION.mkv, ignore case: false
2012-09-19 23:04:23,954 DEBUG [MediaItemDAOImpl] Media item Fringe.S03E22.720p.HDTV.X264-DIMENSION.mkv already exists in DB
2012-09-19 23:04:23,954 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fringe.S03E10.720p.HDTV.X264-DIMENSION.mkv', checking if it's already in the Library
2012-09-19 23:04:23,954 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fringe.S03E10.720p.HDTV.X264-DIMENSION.mkv
2012-09-19 23:04:23,954 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/Fringe.S03E10.720p.HDTV.X264-DIMENSION.mkv, ignore case: false
2012-09-19 23:04:23,954 DEBUG [MediaItemDAOImpl] Media item Fringe.S03E10.720p.HDTV.X264-DIMENSION.mkv already exists in DB
2012-09-19 23:04:23,955 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fringe.S03E14.720p.HDTV.X264-DIMENSION.mkv', checking if it's already in the Library
2012-09-19 23:04:23,955 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fringe.S03E14.720p.HDTV.X264-DIMENSION.mkv
2012-09-19 23:04:23,955 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/Fringe.S03E14.720p.HDTV.X264-DIMENSION.mkv, ignore case: false
2012-09-19 23:04:23,955 DEBUG [MediaItemDAOImpl] Media item Fringe.S03E14.720p.HDTV.X264-DIMENSION.mkv already exists in DB
2012-09-19 23:04:23,955 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fringe.S03E04.720p.HDTV.X264-DIMENSION.mkv', checking if it's already in the Library
2012-09-19 23:04:23,955 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fringe.S03E04.720p.HDTV.X264-DIMENSION.mkv
2012-09-19 23:04:23,955 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/Fringe.S03E04.720p.HDTV.X264-DIMENSION.mkv, ignore case: false
2012-09-19 23:04:23,956 DEBUG [MediaItemDAOImpl] Media item Fringe.S03E04.720p.HDTV.X264-DIMENSION.mkv already exists in DB
2012-09-19 23:04:23,956 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fringe.S03E21.720p.HDTV.X264-DIMENSION.mkv', checking if it's already in the Library
2012-09-19 23:04:23,956 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fringe.S03E21.720p.HDTV.X264-DIMENSION.mkv
2012-09-19 23:04:23,956 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/Fringe.S03E21.720p.HDTV.X264-DIMENSION.mkv, ignore case: false
2012-09-19 23:04:23,957 DEBUG [MediaItemDAOImpl] Media item Fringe.S03E21.720p.HDTV.X264-DIMENSION.mkv already exists in DB
2012-09-19 23:04:23,957 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fringe.S03E20.720p.HDTV.X264-DIMENSION.mkv', checking if it's already in the Library
2012-09-19 23:04:23,957 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fringe.S03E20.720p.HDTV.X264-DIMENSION.mkv
2012-09-19 23:04:23,957 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/Fringe.S03E20.720p.HDTV.X264-DIMENSION.mkv, ignore case: false
2012-09-19 23:04:23,957 DEBUG [MediaItemDAOImpl] Media item Fringe.S03E20.720p.HDTV.X264-DIMENSION.mkv already exists in DB
2012-09-19 23:04:23,958 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fringe.S03E13.720p.HDTV.X264-DIMENSION.mkv', checking if it's already in the Library
2012-09-19 23:04:23,958 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fringe.S03E13.720p.HDTV.X264-DIMENSION.mkv
2012-09-19 23:04:23,958 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/Fringe.S03E13.720p.HDTV.X264-DIMENSION.mkv, ignore case: false
2012-09-19 23:04:23,958 DEBUG [MediaItemDAOImpl] Media item Fringe.S03E13.720p.HDTV.X264-DIMENSION.mkv already exists in DB
2012-09-19 23:04:23,958 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/NFOs
2012-09-19 23:04:23,959 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fringe.S03E09.720p.HDTV.X264-DIMENSION.mkv', checking if it's already in the Library
2012-09-19 23:04:23,960 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fringe.S03E09.720p.HDTV.X264-DIMENSION.mkv
2012-09-19 23:04:23,960 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/Fringe.S03E09.720p.HDTV.X264-DIMENSION.mkv, ignore case: false
2012-09-19 23:04:23,960 DEBUG [MediaItemDAOImpl] Media item Fringe.S03E09.720p.HDTV.X264-DIMENSION.mkv already exists in DB
2012-09-19 23:04:23,961 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fringe.S03E07.720p.HDTV.X264-DIMENSION.mkv', checking if it's already in the Library
2012-09-19 23:04:23,961 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fringe.S03E07.720p.HDTV.X264-DIMENSION.mkv
2012-09-19 23:04:23,961 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/Fringe.S03E07.720p.HDTV.X264-DIMENSION.mkv, ignore case: false
2012-09-19 23:04:23,961 DEBUG [MediaItemDAOImpl] Media item Fringe.S03E07.720p.HDTV.X264-DIMENSION.mkv already exists in DB
2012-09-19 23:04:23,962 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fringe.S03E03.720p.HDTV.X264-DIMENSION.mkv', checking if it's already in the Library
2012-09-19 23:04:23,962 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fringe.S03E03.720p.HDTV.X264-DIMENSION.mkv
2012-09-19 23:04:23,962 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/usuario/Series/Fringe/Fringe.S03.720p.HDTV.X264-TvT/Fringe.S03E03.720p.HDTV.X264-DIMENSION.mkv, ignore case: false
2012-09-19 23:04:23,962 DEBUG [MediaItemDAOImpl] Media item Fringe.S03E03.720p.HDTV.X264-DIMENSION.mkv already exists in DB
2012-09-19 23:04:23,963 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fringe.S03E01.720p.HDTV.X264-DIMENSION.mkv', checking if it's already in the Library
Post Wed Sep 19, 2012 10:20 pm
Do you have the RED checkbox selected as shown here? http://wiki.serviio.org/doku.php?id=ser ... _explained
Or there may be more in the log further down.
jfcg
Post Wed Sep 19, 2012 10:40 pm
Sure. Here it is:
Please find attached the complete log. I click on "Force refresh" at 23.00.
Thanks for your interest!
serviio.zip
(98.81 KiB) Downloaded 579 times
Post Fri Sep 21, 2012 12:48 pm
I will need you to click on Rescan Video metadata on the Metadata tab. Then Force refresh. Then post the log again please.
jfcg
Post Mon Sep 24, 2012 8:34 am
Here it is.
I click on Rescan Video at 8:09. Then, I click on Force Refresh at 8:22.
log.zip
(158.13 KiB) Downloaded 555 times
Post Mon Sep 24, 2012 4:38 pm
Ok, it ran the ffmpeg commands to retrieve thumbnails.
Can you run AV MediaController from Intel tools (see my signature) and browse to a video 9eg a Simsons episode), click Properties and check the Resources it has - one of them should be thumbnail (you can try to open the resource Url in a browser and you should see the image)
jfcg
Post Mon Sep 24, 2012 9:27 pm
Any similar tool for linux? I don't use windows... :S
Post Tue Sep 25, 2012 12:56 pm
Not sure, try VLC, use the UPnP client functionality (see our Wiki), I'm not sure but it might support thumbnails, or at least give some info if the server has them.
Also can you post detailed log of browsing to a video folder as it is now?
jfcg
Post Fri Nov 23, 2012 10:26 pm
It is solved now! The issue was because I was using an old ffmpeg version (0.6.6):
Unrecognized option 'frames:v'
I updated ffmpeg to 0.10.6 and it works great.
Thanks for this great app!
Users browsing this forum: No registered users and 65 guests
