Bug movie filename
thingy
Post Mon Sep 17, 2012 12:59 pm
Bug movie filename
I have a movie that has a year in the title (Fetih 1453).
The filename is: Fetih.1453.2012.720p.dts.mkv
This will not be parsed by tmdb since Serviio sends 1453 as production year...
Any workaround? Or is this possible to fix without a really ugly hack that checks validity of production year.
Actually serviio treat this file as a tv show and tries season 14 episode 53, which is even worse than I first thought.
Post Mon Sep 17, 2012 1:18 pm
Re: Bug movie filename
Not sure if this will work, but try Fetih 1453 (2012).mkv
Post Mon Sep 17, 2012 1:21 pm
http://www.serviio.org/index.php?option ... icle&id=12
In a case there are other movies with the same title, but different release years, you can include the year in the title of the video (or the parent folder), e.g. 'My movie (2005)'.
thingy
Post Mon Sep 17, 2012 1:36 pm
will wrote:Not sure if this will work, but try Fetih 1453 (2012).mkv
Tried it, did not work.
And to Illico: That's what I do for all movies, I think you didn't read my problem correctly.
I ended up removing the 1453 part, now the filename reads: Fetih.2012.720p.dts.mkv
It succesfully retrieved the right movie name now, but I don't like this workaround a lot. It would be better if the filename parser would not consider four consecutive numbers be season/episode information, never seen that format anywhere.
I know this is a very hard problem, it's AI hard trying to parse context out of filenames.
Post Mon Sep 17, 2012 1:43 pm
Less ideal but call it Fetih (2012).mkv, and then I guess put it in a directory called Fetih 1453 for organisational purposes.
Its an edge case but maybe file a ticket to support using name="NAME DATE1" and year=DATE2 in the case of finding NAME DATE1 (DATE2)
thingy
Post Mon Sep 17, 2012 1:46 pm
will wrote:Less ideal but call it Fetih (2012).mkv, and then I guess put it in a directory called Fetih 1453 for organisational purposes.
Thanks for the quick response, I was editing my response as you answered it...
Return to Feature requests
