Veetle.com
JerseyJoe123
Post Mon Sep 17, 2012 2:59 am
Re: Veetle.com
zip wrote:the plugins work on a different level than directly manipulating the streams, so the proxy cannot be incorporated into a plugin
Are there any other suggestions you can think of to deal with this issue? I agree that modifying ffmpeg to deal with it isn't the best approach.
trigu75
Post Mon Sep 17, 2012 3:21 pm
Re: Veetle.com
well ..
my idea was actually to provide the python script as it is , all you have to do is on each system to configure the right IP (inside the script) , install python , and execute it
and have the veetle plugin also modified to make the TV requests from the modified address we pass with the proxy .. , I know what is done inside the python script , can be translated to a java solution (for serviio) , just another jar ..
trigu75
Post Mon Sep 17, 2012 3:53 pm
Re: Veetle.com
example ...
take unzip the zip file , insert the right IP address (your machine IP instead of 192.168.0.15)
install python , and run it (python akamaiSecureHD.py )
then , take the veetle.groovy I provided , and also there , put your IP instead of 192.168.0.15
it works like a charm ... and can be used if in the future they change GGG to something elses ...
osx has python already , and so linux systems , on windows is a small install ..
Veetle.groovy
(4.94 KiB) Downloaded 914 times
veetle.zip
(52.92 KiB) Downloaded 875 times
JerseyJoe123
Post Tue Sep 18, 2012 12:59 am
Re: Veetle.com
It works like a charm! I have the proxy configured to run as a daemon process on startup under Ubuntu. So far, the Veetle channels are all playing just fine.
Thanks a bunch. Great work!
George_L
Post Tue Sep 18, 2012 5:41 pm
Re: Veetle.com
trigu75 wrote:example ...
To make it clearer for those of us new to some of this terminology, I need to clarify:
Your machine IP is your PC IP correct? (Not the TV set IP its hooked too)
What is python? where do I get it (for Windows 7 64)? I did find something with a search (but it's not a small file) and want to clarify its correct.
I see where to edit both Veetle.groovy and akamaisecureHD.py to change IP. Where do you install the Vettle.zip file after its unzipped?
Because I don't know what python is, what are you doing when you run (python akamaiSecureHD.py). What is this doing to the file?
Once I get this clarified, I too hope to get this working
trigu75
Post Tue Sep 18, 2012 6:24 pm
Re: Veetle.com
http://www.python.org/ftp/python/2.7.3/ ... .amd64.msi
This should be python for 64 bit windows
Yes the ip is the system the proxy is running
Python is a programming language , the proxy is written
Usin python
All the contents in the zip file must be extracted to any folder you like
Say.c:\vetproxy
Then from cmd window go to that folder and type python and the py file
Or just double click the file should do the same
Since the beginning the plugin was based on the Xbmc plugin
Translated to groovy from python .. But the proxy can't be used as plugin but separate addon
Kind of plugin for the plugin
i4play
Post Sat Oct 06, 2012 11:15 pm
Re: Veetle.com
Nevermind, figured it out. My bad, and thanks.
seaman
Post Mon Oct 08, 2012 6:07 pm
Re: Veetle.com
JerseyJoe123 wrote:Since I use Ubuntu, I patched the line described in the thread:
"if (d[0] == 'F' && d[1] == 'L' && d[2] == 'V' && d[3] < 5 ..."
and replaced it with:
"if ( (d[0] == 'F' || d[0] == 'G' || d[0] == 'H') && d[3] < 5 ..."
in the flvdec.c source file and recompiled ffmpeg. It is working OK so far for all the Veetle streams I've tried.
Works in Ubuntu 12.10. Now Veetle and Veetles folder are populated as before... Thanks.
sjsu
Post Sun Jul 07, 2013 5:10 am
Re: Veetle.com
trigu75 wrote:http://www.python.org/ftp/python/2.7.3/python-2.7.3.amd64.msi
Usin python
Say.c:\vetproxy
i must say it did populate lot of veetle folders but it is buffering a lot. my connection is pretty good 25MBPS too, dint had any prblm with any other video. i am using serviio 1.1.
any advise why it is buffering so much on any veetle movie?
thanks
funguide
Post Wed Jan 01, 2014 9:09 pm
Re: Veetle.com
Works great but some streams come on both HD and SD, and it shows only the SD version. It seems the preferred quality argument is not yet implemented in the plugin.
Previous
Return to Available plugins
Users browsing this forum: No registered users and 122 guests
