Web UI in PHP - support thread
Xmantium
Post Sat Sep 15, 2012 5:47 pm
Re: Web UI in PHP (revised)
Hi Mark, any progress news when new update will be arriving?
dukeplc
Post Mon Sep 17, 2012 1:28 am
anybody else having issues with HTTP 500 errors?
I've had the web ui working previously, and after I upgraded Serviio to the latest version I get the internal server error.
TIA.
npuser
Post Mon Sep 17, 2012 1:52 am
dukeplc wrote:anybody else having issues with HTTP 500 errors?
TIA.
Nope - its working great here. plz check permission to the folder.
NPuser
npuser
Post Mon Sep 17, 2012 2:03 am
Mark - is it possible to implement Mediabrowser link in remote.php to read pc5dczc_host variable instead? That way, we could run/install web console in separate web server and still be be able to launch mediabrowser from original serviio server.
I have my web console in NAS but my serviio instance is in Ubuntu headless.
remote.php
<div style="float: left;">
    <a href="http://<?php echo $pc5dczc_host;?>:23424/mediabrowser/" target="_blank">Open MediaBrowser</a>
</div>
NPuser
dukeplc
Post Mon Sep 17, 2012 3:22 pm
TIA.
NPuser
Don't believe that to be the issue. Here's what ls -al gives me on the /var/www directory.
total 16
drwxr-xr-x 3 root root 4096 Sep 16 20:02 .
drwxr-xr-x 13 root root 4096 Sep 7 21:32 ..
-rw-r--r-- 1 root root 177 Jul 20 17:20 index.html
drwxrwxrwx 12 www-data www-data 4096 Sep 16 20:12 serviioweb
Post Mon Sep 17, 2012 3:28 pm
Which webui version (should be 1.2)?
Please post a detailed log (see sig) from serviio of you doing something that causes the error.
Also edit /var/www/serviioweb/config.php to turn on its loggin to see if that shows anything that might help.
<?php
$language = "en";
$webUIver = "1.2";
$debugLevel = "debug"; // none, debug
$debugLoc = "screen"; // none, screen
$pc5dczc_host = "127.0.0.1";
$pc5dczc_port = "23423";
$version_req = "1.0.1";
mpemberton5
Post Mon Sep 17, 2012 3:35 pm
Pardon for the delay, the next couple of weeks are going to be tough for me. Finally going live on an 18-month project this coming weekend. Thanks for everyone's support with these issues.
dukeplc
Post Mon Sep 17, 2012 3:49 pm
will wrote:Which webui version (should be 1.2)?
<?php
$language = "en";
$webUIver = "1.2";
Looks like I'm getting somewhere. Thanks for the help.
BTW, I am running web ui ver 1.2 and serviio ver 1.0.1. I started having trouble when I moved to the latest versions. Android app works wonderful, btw....Kudos.
here's the browser message I get after changing log levels:
Fatal error: Call to undefined function curl_init() in /var/www/serviioweb/lib/RestRequest.inc.php on line 40
serviio.log is clean.
Post Mon Sep 17, 2012 3:59 pm
What operating system? If you are on Linux you might have to install php with curl.
Check curl for php is installed (sudo apt-get install php5-curl), if it is follow this http://kb.mediatemple.net/questions/764 ... page%3F#gs and that it is enabled
dukeplc
Post Mon Sep 17, 2012 4:05 pm
will wrote:Check curl for php is installed (sudo apt-get install php5-curl), if it is follow this http://kb.mediatemple.net/questions/764 ... page%3F#gs and that it is enabled
*slapping forehead*
That did it. Thanks. Sorry for the intrusion, but I'd searched for a day on this topic and I seemed to be the only one having this issue. Is curl a new requirement, because I swear I had this running with a previous version.
and thanks again for great product. Point me toward a donate page please.
Strupniveral
Post Wed Sep 19, 2012 6:20 am
I'm not sure if I'm the first one who didn't go PRO or I missed the proper post, but today my trial license expired this morning and I stated to get few "variable undefined" notifications on each webui page (messages refers to id, type, name, email, expiresInMinutes in lib/serviio.php file).
This is due to the fact such variables are initialized in the following "foreach" loop:
foreach ($xml->license as $licenseDetail) {
   $id = (string)$licenseDetail->id;
   $type = (string)$licenseDetail->type;
   $name = (string)$licenseDetail->name;
   $email = (string)$licenseDetail->email;
   $expiresInMinutes = (string)$licenseDetail->expiresInMinutes;
and, if no license is available, such variables are not initialized.
This can be solved initializing such variables with empty strings just before the mentioned loop, with something like:
$id = "";
$type = "";
$name = "";
$email = "";
$expiresInMinutes = "";
HTH,
Luca
mpemberton5
Post Thu Sep 20, 2012 12:40 am
Strupniveral wrote:I'm not sure if I'm the first one who didn't go PRO or I missed the proper post, but today my trial license expired this morning and I stated to get few "variable undefined" notifications on each webui page (messages refers to id, type, name, email, expiresInMinutes in lib/serviio.php file).
$id = "";
$type = "";
$name = "";
$email = "";
HTH,
Luca
:oops: Yikes, a bit embarrassed about that. Pretty obvious that wasn't in my testing plan. Thanks for the post. I'll update the code.
Blessings,
mpemberton5
Post Thu Sep 20, 2012 1:36 am
*slapping forehead*
Please head over to the wiki page and at the bottom there is a link to my personal website. There in the header is a Donation link (paypal). As always, thank you for expressing your appreciation.
Blessings,
Strupniveral
Post Tue Sep 25, 2012 6:27 am
It's not a bug, it's a feature: in this way, every time you open the console you get a reminder to go pro ;)
$id = "";
$type = "";
$name = "";
$email = "";
HTH,
Luca
Blessings,
jo343
Post Tue Sep 25, 2012 4:31 pm
I'm using Ubuntu 12.04, Serviio 1.0.1 and WebUI v1.2a.
When I add a folder using the "Add local..." or "Add path..." it is not added to serviio even though I click Save on the bottom of the screen and a message appear saying "Saved!". If I change tab and go back to my folders, the one I just added has disappeared.
I do not get any error message.
Strupniveral
Post Tue Sep 25, 2012 8:52 pm
I'm not sure if related to the message above, but I'm not able to remove an online resource from Serviio using the WebUI.
On Serviio log file, I got the following:
2012-09-25 22:46:44,767 WARN  [ServiioStatusService] ConversionException occured. Returning error code 500 to the REST layer. Message: Zero length string : Zero length string
---- Debugging information ----
message             : Zero length string
cause-exception     : java.lang.NumberFormatException
cause-message       : Zero length string
class               : java.lang.Long
required-type       : java.lang.Long
converter-type      : com.thoughtworks.xstream.converters.SingleValueConverterWrapper
wrapped-converter   : com.thoughtworks.xstream.converters.basic.LongConverter
path                : /repository/sharedFolders/sharedFolder/accessGroupIds/id
class[1]            : java.util.LinkedHashSet
converter-type[1]   : com.thoughtworks.xstream.converters.collections.CollectionConverter
class[2]            : org.serviio.ui.representation.SharedFolder
converter-type[2]   : com.thoughtworks.xstream.converters.reflection.ReflectionConverter
class[3]            : java.util.ArrayList
class[4]            : org.serviio.ui.representation.RepositoryRepresentation
version             : null
I managed serviio only using this interface and it worked fine - and other functionalities (such as forcing a Library rescan) work fine - and I don't remember any change to Serviio / system that might explain it.
Any idea on what can I check?
alfista
Post Wed Sep 26, 2012 10:25 am
I can only chime in to above posts. Thought I was going nuts when I updated some existing Online streams and they wouldn't work. After a while I found that my changes were never committed, the old URL remained unchanged. Tried adding new streams, they showed up in the list immediately but after swapping tabs back and forth they were gone. Had to get things fixed, pointed the Serviio Console on my Windows machine to the Linux server, so I didn't do any trouble shooting.
Post Wed Sep 26, 2012 12:52 pm
Are you guys using version 1.2a? I know the wiki says its dated aug 13, but it was updated on aug 23 to fix this save bug. viewtopic.php?f=17&t=5330&start=130#p51324
alfista
Post Wed Sep 26, 2012 11:13 pm
Seems I wasn't using 1.2a. The download didn't include the fix you linked to, but 1.2a behaved the same way, with fix or without. Online resources can not be added, removed or edited.
The odd thing though is that the Windows Serviio Console also has some problems. I can remove and edit as well as adding web resources, but I can not add live streams. When I have entered name and url in the dialogue and click the add button nothing is added to the list. Didn't try with RSS feeds. Don't know when this occurred, it's possible that I haven't added any new online resources after going to 1.0.x.
Maybe I've borked something by using various versions of webui, Serviidroid and the Windows console.
Maybe I should have gone for a clean install when going from 0.6.2 to 1.0.x.
