File not playing on Sony Bravia 2012
shrirange
Post Tue Sep 18, 2012 3:41 pm
Output of ffmpeg
C:\Program Files\Serviio\lib>ffmpeg -i "E:\Hollywood\kids\National Geographic\national.geographic.earth.making.of.a.planet.hdtv.xvid-fqm.avi"
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='
-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --pkg-config=pk
g-config
Input #0, avi, from 'E:\Hollywood\kids\National Geographic\national.geographic.earth.making.of.a.planet.hdtv.xvid-fqm.avi':
encoder : transcode-1.0.4
Duration: 01:31:28.10, start: 0.000000, bitrate: 1071 kb/s
Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 624x352 [SAR 1:1 DAR 39:22], 29.97 tbr, 29.97 tbn, 29.97 tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16, 128 kb/s
Post Tue Sep 18, 2012 4:17 pm
Re: File not playing on Sony Bravia 2012
What is your model number ?
Could you also provide MediaInfo tool result (in text format) ?
NX3
Post Wed Sep 19, 2012 8:00 am
You file was made with "transcode-1.0.4", I've found anything made my transcode no matter what version doesn't play on Sony. You can either convert the file your self or select Sony 2010 profile so its transcoded by Serviio to mpeg2 and does play.
shrirange
Post Wed Sep 19, 2012 4:43 pm
Changing the profile to Sony 2010 worked. On a seperate note, great work by you all on serviio. Would like to know if i can enable subtitles for all containers on my Sony KDL-32NX650. Yeah this is a new model but same as the EX version. I tried to read the posts and all but i want it enabled somehow. This will make me buy WD Mybook live and install serviio on it. Will make my life better.I tried to add
<SubtitlesMimeType>text/srt</SubtitlesMimeType> in the Sony profile but it seems there is much more to it. You cannot believe my Sony TV does not support mkv and also subtitles on USB. Serviio does not support subtitles on streaming. I am actually gone down on this. Should i add this as a new post ?
Users browsing this forum: Baidu [Spider], Google [Bot] and 7 guests
