[SOLVED] Serviio Browser Authentication Glitch
Slow Rambler
Post Mon Sep 17, 2012 8:32 am
:? Hi everyone
Running Xp Sp3 and Serviio Pro
When I type my password into the dialogue box application refuses to launch.
Error message says....authentication problem'
I have tied changing the password several times still same problem.
Anyone in the forum seen this behaviour before and/or can suggest a fix ?
I hope so
Keith
Post Mon Sep 17, 2012 8:33 am
Re: Serviio Browser Authentication Glitch
Which browser?
Post a detailed log (see sig) of you loggin in.
Slow Rambler
Post Mon Sep 17, 2012 8:40 am
Thanks for prompt reply
Like you I thought it might be the browser
I am using the latest version of Internet Explorer but have tried to run the player in Firefox/Opera and Safari with exactly the same behaviour in all of them
Could it be my security settings ?
Thanks again for at least thinking about the issue
Keith
Post Mon Sep 17, 2012 8:54 am
will wrote:Post a detailed log (see sig) of you loggin in.
http://wiki.serviio.org/doku.php?id=detail_logging
Slow Rambler
Post Mon Sep 17, 2012 1:45 pm
Thank you for the prompt reply and instructions
I have an embarrassing question.
How do I access my config folder so I can tweak log4j.xml ?
:oops:
I am a novice anxious to learn which is a poor excuse for lack of competence
Keith
Post Mon Sep 17, 2012 1:47 pm
Look in C:\Program Files\Serviio\config and C:\Program Files\Serviio\log
Slow Rambler
Post Tue Sep 18, 2012 9:28 am
Thanks for instructions
I wish I had had the wit to think of that
Here are my logs
2011-09-23 18:22:05,015 INFO [ServiioConsole] Starting Serviio Console
2011-09-23 18:22:05,109 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-09-23 18:22:13,234 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-09-23 18:22:20,562 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-09-23 18:22:20,593 INFO [Messages] Loaded console message bundle for locale: en
2011-09-23 18:22:27,562 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-09-23 18:22:31,406 INFO [ServiioConsole] Leaving Serviio Console
2011-09-23 18:23:36,875 INFO [ServiioConsole] Starting Serviio Console
2011-09-23 18:23:36,953 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-09-23 18:23:44,781 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-09-23 18:23:52,328 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-09-23 18:23:52,359 INFO [Messages] Loaded console message bundle for locale: en
2011-09-23 18:23:59,875 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-09-23 18:24:02,265 INFO [ServiioConsole] Leaving Serviio Console
2011-09-23 15:18:15,265 INFO [ServiioConsole] Starting Serviio Console
2011-09-23 15:18:15,375 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-09-23 15:18:25,750 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2011-09-23 15:18:32,750 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-09-23 15:18:32,781 INFO [Messages] Loaded console message bundle for locale: en
2011-09-23 15:18:40,515 WARN [ServiioConsole] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-09-23 15:18:43,421 INFO [ServiioConsole] Leaving Serviio Console
Should I try uninstall/reinstall ?
The error message simply says....there was a problem with your authorisation.
I have tried to reset my password....nothing will pursuade the browser to launch.
Thank you for your patience
Keith
Post Tue Sep 18, 2012 3:54 pm
post your whole serviio.log
Slow Rambler
Post Tue Sep 18, 2012 6:36 pm
Hi Petr
Attached is a winzip copy of my log file.
I hope this is acceptable practice.
I have sent a further copy to your zip@serviio.org 'e'mail address
If you want me to try anything else please ask and continue to be patient
log.zip
(314.37 KiB) Downloaded 371 times
Keith
Post Tue Sep 18, 2012 6:49 pm
what is your IP address? open Command prompt and execute
ipconfig
and post the results. It looks like it was having problems with the network card. Did you manage to at least run the console and add some folders?
BTW, it looks like your evaluation license expired anyway and therefore you won't be able to use MediaBrowser unless you buy the Pro edition now.
Slow Rambler
Post Wed Sep 19, 2012 5:51 am
Good Morning Petr
I am confused now.
I have purchased the Pro version otherwise I would not be wasting your time.
Everything works just fine.
except
The browser will not launch !!!
The browser start page opens with active dialogue box asking for my password.
I type the password in and hit enter
Dialogue box clears and up comes error message......'problem with authentication check password'
I did..... tried resetting password and imputing new passwords......nothing works.
An interesting thing
In my hard drive program folders I have three versions of Serviio
C:\ProgramFiles\Seviio and Serviio(1) and Serviio (2)
That does not look right particularly as if I look at my program list in 'Control Panel' only one Serviio is shown
Will I get into trouble if I delete all the program folders ( Serviio/Serviio (1) and Serviio (2)) then conventional uninstall and reinstall ?
I think my licence key is still good
Dont give up on me Petr
Keith
Post Wed Sep 19, 2012 11:28 am
Do you use the "password" set on serviio console ?
Post Wed Sep 19, 2012 11:54 am
Did you upload the license key? The log reports you have FREE edition.
Also post result of the command I asked you before.
Slow Rambler
Post Wed Sep 19, 2012 1:42 pm
Hello Petr
Thank you for staying with this issue
I have uploaded my licence key (attachment to this post)
At my level I think the glitch might be caused by me having three versions ( Serviio / Serviio (1) /Serviio (2) in my hard drive program folder
The log file I sent you relates to Serviio which was the free version I had running before I upgraded to Pro and I reckon that is why you cannot see my licence
Here is the good news Petr
I am out of the UK for 10days so you are spared pulling your hair out over this for a couple of weeks
Here is the bad news Petr
I would like to continue to resolve the issue when I get back so would you keep the thread 'live' ?
I hope so.
For my part I wish to thank you and all at Serviio both for the server (which works really well) and for a first class example of good customer care over this issue.
Believe it or not I have learned from the experience and am glad I upgraded.
Regards
Keith
Keith
Post Wed Sep 19, 2012 1:47 pm
Please remove you license key from the attachment.
Edit: thanks.
Re your problem. Probably best to uninstall and remove all trace of the various serviio versions you have installed. Then re-install serviio and post a debug log of you trying to log in again.
Slow Rambler
Post Wed Sep 19, 2012 1:52 pm
Ok I have done that
Sorry for a newbie mistake.
I only sent it in because Petr asked for it
Keith
Post Wed Sep 19, 2012 1:56 pm
I think he ment did you upload it/apply it to serviio, which he probably asked because the log showed that you had the free version.
Have a go at the steps in my above post and we can will try and get to the bottom of the problem.
Slow Rambler
Post Wed Sep 19, 2012 2:24 pm
Thanks Will I completly understand
I will do as you direct as soon as I return to the UK in a little under two weeks.
Much appreciate all that has been done by Serviio to help me resolve the problem.
Serviio have a devoted user in me,
Stunningly good customer care
Keith
Slow Rambler
Post Tue Oct 02, 2012 5:57 pm
Hello Everyone
Back in the UK I am anxious to fire up my Serviio Media Browser
I have uninstalled , rebooted, and downloaded a clean version
My 'pro' licence link has expired ( Serviio_xxxxxxxxxxxxxxxxxx.lic )
Please send me an active link and I will upgrade and hope for the best.
If you need anything else from me please ask
Thank You
Keith
Post Tue Oct 02, 2012 6:41 pm
Send zip a pm with all your details. In future, keep a copy of the license file somewhere safe, the email link is only valid for a week.
Users browsing this forum: Baidu [Spider], Google [Bot] and 40 guests
