ffmpeg high cpu usage
makmar11
Post Wed Sep 19, 2012 2:12 pm
Hi
i try to make a profile for my LG HLB54S bd player.
i manage to transcode some files and i have the following problems:
1 ffmpeg continue to run with high cpu usage after i stop the transconding video (i have to manual stop it from task manager) i run it in
windows 7 x64
2 transconding video has not the native video aspect ratio and when i try the dar=16:9 command in my profile instead to expand from left and right compressed from up and down and now i have black areas around of the video.
i reed in forum for a ffmpeg filters but i don't know how to apply them.
Satras
Post Wed Sep 26, 2012 7:50 am
Re: ffmpeg high cpu usage
I got the same on 1).
I guess this is because Serviio kicks in the transcoding process but does not know if someone is actually watching the stream.. would be cool if this would be fixed.
on 2) you might want to check this and supply some more details
viewtopic.php?f=5&t=4510
yaro
Post Sun Sep 30, 2012 4:46 am
makmar11 wrote:Hi
windows 7 x64 .
I think the developer has to revisit this problem. I believe it is a bug he has not figured out how to solve.
Post Sun Sep 30, 2012 11:55 am
yaro wrote:
makmar11 wrote:Hi
windows 7 x64 .
It is not a bug, but a feature. Discussed many times.
yaro
Post Sun Sep 30, 2012 12:57 pm
zip wrote:
yaro wrote:
makmar11 wrote:Hi
windows 7 x64 .
Is it alright for the transcoding to continue for 48 hours and indefinitely till I kill it?
Post Sun Sep 30, 2012 4:01 pm
48 hours? It'll only run until it finishes transcoding the video. Unless you are watching a live stream?
yaro
Post Sun Sep 30, 2012 5:44 pm
It happens after watching a live stream on a Philips TV.
Post Sun Sep 30, 2012 8:05 pm
Ok, Live streams should get killed when you stop watching them. Are you using a plugin or enter the stream URL directly to the console?
yaro
Post Sun Sep 30, 2012 9:25 pm
It is the ABC plugin.
Post Sun Sep 30, 2012 11:00 pm
It might be the plugin is not correctly marking live streams as live, causing Serviio not to kill the process when you stop watching it. Ask the plugin dev to check this.
yaro
Post Tue Oct 02, 2012 1:59 pm
it is the Livefeeds plugin. It has not been updated since July.
Post Tue Oct 02, 2012 2:04 pm
That one looks ok.... can you enable detailed log, play the stream, stop it, wait 2 minutes and then post the log here?
yaro
Post Tue Oct 02, 2012 7:13 pm
It has not happened since my last post, so it could be a random occurrence . I will post the console log when it happens.
Post Tue Oct 02, 2012 10:22 pm
thanks
yaro
Post Wed Oct 03, 2012 5:22 am
This thing is random . Here is a snippet of the log.
012-10-02 19:12:49,352 WARN [EventDispatcher] Couldn't send event message for subscription cd8fc46e-cccb-4dff-9cf5-716e49892ddd, will keep trying until subscription expires
2012-10-02 19:12:49,353 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 19:46:28,890 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 19:55:28,340 WARN [WebResourceParser] Plugin HaHaSport returned no value for resource item 'Tue 18:30-20:30 San Luis - Club America -Apertura de Mexico'
2012-10-02 19:55:28,943 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 20:10:34,223 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 20:40:34,657 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 20:46:39,780 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 21:10:45,328 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 21:41:56,029 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 21:46:56,136 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:00:21,720 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:01:34,423 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:01:44,834 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:01:47,868 WARN [ProcessExecutor] Process /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 1! This is a possible error.
2012-10-02 22:01:51,872 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:02:02,331 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:02:23,214 WARN [VideoDeliveryEngine] Cannot extract expired URL, using previous one which might not work
2012-10-02 22:02:24,717 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:02:25,414 WARN [ProcessExecutor] Process /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 1! This is a possible error.
2012-10-02 22:02:33,825 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:02:42,676 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:02:51,064 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:02:53,278 WARN [VideoDeliveryEngine] Cannot extract expired URL, using previous one which might not work
2012-10-02 22:03:01,498 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:03:08,776 WARN [VideoDeliveryEngine] Cannot extract expired URL, using previous one which might not work
2012-10-02 22:03:12,000 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:03:18,451 WARN [PipedOutputBytesReader] Error reading bytes stream from external process: Stream closed
2012-10-02 22:03:22,639 WARN [VideoDeliveryEngine] Cannot extract expired URL, using previous one which might not work
2012-10-02 22:03:24,710 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:03:25,336 WARN [ProcessExecutor] Process /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 137! This is a possible error.
2012-10-02 22:03:34,461 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:03:43,621 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:03:52,967 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:03:58,911 WARN [ProcessExecutor] Process /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 137! This is a possible error.
2012-10-02 22:04:01,629 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:04:08,659 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:04:19,449 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:04:29,640 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:04:33,576 WARN [ProcessExecutor] Process /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 137! This is a possible error.
2012-10-02 22:04:39,014 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:05:01,009 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:05:09,364 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:05:10,983 WARN [ProcessExecutor] Process /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 137! This is a possible error.
2012-10-02 22:05:16,881 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:05:24,299 WARN [PipedOutputBytesReader] Error reading bytes stream from external process: Stream closed
2012-10-02 22:05:41,134 WARN [ProcessExecutor] Process /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 1! This is a possible error.
2012-10-02 22:05:47,586 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:05:55,117 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:05:59,423 WARN [ProcessExecutor] Process /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 1! This is a possible error.
2012-10-02 22:06:02,645 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:06:15,672 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:06:25,230 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:06:29,101 INFO [RendererManager] Stored a new renderer: uuid='2b3144a6-d9d4-11e0-8e23-00e0a91e001a', name = 'NMR', ipAddress='192.168.1.73', profile = '20'
2012-10-02 22:06:49,300 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:07:19,322 WARN [ProcessExecutor] Process /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 137! This is a possible error.
2012-10-02 22:07:39,754 WARN [ProcessExecutor] Process /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 137! This is a possible error.
2012-10-02 22:07:44,059 WARN [ProcessExecutor] Process /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 137! This is a possible error.
2012-10-02 22:10:38,547 WARN [ProcessExecutor] Process /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 137! This is a possible error.
2012-10-02 22:11:16,911 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:11:22,087 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:16:26,913 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
2012-10-02 22:16:32,128 WARN [EventDispatcher] Couldn't send event message for subscription e82d9302-b11c-47c4-ac07-6c7afb82c0e3, will keep trying until subscription expires
javaApp.tiff
javaApp.tiff (133.42 KiB) Viewed 22275 times
Post Wed Oct 03, 2012 12:59 pm
I'll need detailed log of when you play the stream, then stop... it should log something about trying to kill ffmpeg after a minute or so.
yaro
Post Wed Oct 03, 2012 7:19 pm
This is the serviio log file. I do not find what you are looking for:
(306.49 KiB) Downloaded 614 times
Post Wed Oct 03, 2012 7:40 pm
I'll need detailed log (see my signature on how to enable it) .. there should be a lot of DEBUG entries in the log after that
yaro
Post Thu Oct 04, 2012 12:40 am
Here you go:
(491.84 KiB) Downloaded 668 times
Post Thu Oct 04, 2012 3:48 am
There is nothing in that log re playing a live stream. It only shows you transcoding and playing 3 mp4 files, and the ffmpeg process terminating when transcoding is complete..
