Can't open WMV-files with C-series TV
Tormio
Post Wed Sep 19, 2012 8:27 pm
I can't open .WMV -files with my C-series Samsung. Other files seem to open. Using Windows 7 64bit. Also using the "Samsung TV / Player (C/D-series) -profile.
I read something about chanching the profiles.xml, but could you explain what to edit/add/delete there. :roll:
Thanks in advance.
Post Wed Sep 19, 2012 10:21 pm
Re: Can't open WMV-files with C-series TV
Tormio
Post Sun Sep 23, 2012 10:55 am
Yea, i think you should make your software easier to use. It's 2012 and you make us change some code on some profiles.xml -file. Make some dropdown-menu options rather than make us learn how to code .xml -files.
