Why does serviio take up over half gig memory ?
stevvie
Post Thu Sep 20, 2012 3:02 pm
I have an E6600 running at 3Ghz and see that sometimes serviio is sat at around 20-30% usage and 500-600 meg of memory for one task and about 50-100meg for the other task. This is without ANY media players playing anything ( My TV is OFF) Why so heavy on the memory ? and is there anything I can Do.
Post Thu Sep 20, 2012 4:26 pm
Re: Why does serviio take up over half gig memory ?
- Do you enable library automaic update ? -> you can disable it
- Do you use plugins with some online resources ? -> if online source is used, nothing we can do.
Post Thu Sep 20, 2012 10:17 pm
Serviio is allowed to take up to 512MB RAM. It's usually adding (large) images that take a lot of memory and Java will not return the memory back to the OS unless it's needed. Also depends on the Java you are using.
stevvie
Post Fri Sep 21, 2012 11:27 am
I have ONLY 1 source which at the moment has 6 files/movies in it.
So if you use online sources then serviio is always doing something when running and never stops or gets to the end of a proccess ?
Users browsing this forum: Google [Bot] and 18 guests
