Re: Hulu (US only)
Something must have changed...
George_L wrote:Similar to a couple weeks ago before the Hulu plugin was updated, I have again suddenly lost all Hulu feeds after working yesterday. Anyone else noticing this?
Nixter wrote:Works for me too. Thanks Zip!![]()
Unfortunately, movies still stop playing after around 1 hr.
jctoad wrote:I have a lot of problems streaming things that need to be transcoded.Nixter wrote:Works for me too. Thanks Zip!![]()
An hour of Hulu will easily create a temp file over a gigabyte in size for transcoding. I wonder if your temp file gets too large and something crashes? Is there enough free drive space? Does it stop playing when the temp file reaches the same size every time with different files? I think some of the Hulu files are just bad. I've seen some that will die in the exact same place every time. Some might be 50 minutes in and others might be 3 min. after starting.
I can never resume, skip forward or backward in a Hulu file. It will cause it to hang every time and it has to restart. All I can do is pause it.
I seem to have problems with anything that needs to be transcoded. Is your problem just Hulu or do other sources that need to be transcoded have the same problem? I could give you more details, but this is already getting off topic for this thread. I've been trying to figure this out for about 10 months now.
