"Temporarily cannot acces server." When playing .mkv files?
2010-11-19 21:49:35,081 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2010-11-19 21:49:35,092 INFO [MediaServer] ------------------------------------------------------------------------
2010-11-19 21:49:35,092 INFO [MediaServer] Serviio DLNA media streaming server v 0.4.2 (rev. 683706a96104)
2010-11-19 21:49:35,092 INFO [MediaServer] Petr Nejedly 2009-2010
2010-11-19 21:49:35,092 INFO [MediaServer] http://www.serviio.org
2010-11-19 21:49:35,092 INFO [MediaServer] Java 1.6.0_22-Apple Inc.
2010-11-19 21:49:35,092 INFO [MediaServer] OS Mac OS X x86_64 10.6.5
2010-11-19 21:49:35,092 INFO [MediaServer] File encoding: UTF-8
2010-11-19 21:49:35,214 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2010-11-19 21:49:35,251 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2010-11-19 21:49:35,260 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2010-11-19 21:49:36,163 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2010-11-19 21:49:36,164 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2010-11-19 21:49:36,164 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2010-11-19 21:49:36,164 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2010-11-19 21:49:36,165 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2010-11-19 21:49:36,165 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2010-11-19 21:49:36,501 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2010-11-19 21:49:36,510 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2010-11-19 21:49:36,679 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2010-11-19 21:49:36,680 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2010-11-19 21:49:36,711 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2010-11-19 21:49:36,711 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2010-11-19 21:49:36,736 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2010-11-19 21:49:36,737 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2010-11-19 21:49:36,750 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2010-11-19 21:49:36,750 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2010-11-19 21:49:36,767 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2010-11-19 21:49:36,767 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2010-11-19 21:49:36,782 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2010-11-19 21:49:36,783 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2010-11-19 21:49:36,799 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2010-11-19 21:49:36,800 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2010-11-19 21:49:36,812 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2010-11-19 21:49:36,813 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2010-11-19 21:49:36,851 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2010-11-19 21:49:36,851 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2010-11-19 21:49:36,901 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2010-11-19 21:49:36,902 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg
2010-11-19 21:49:36,905 DEBUG [ProcessExecutor] Starting /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg
2010-11-19 21:49:37,051 INFO [VideoDeliveryEngine] Cleaning transcode engine and its data
2010-11-19 21:49:37,054 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2010-11-19 21:49:37,413 INFO [WebServer] WebServer starting on port 8895
2010-11-19 21:49:37,559 INFO [Device] Created UPnP Device with UUID: b8788ec1-4308-32fc-a48f-2532c9b147a9, bound address: 192.168.2.4
2010-11-19 21:49:37,877 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2010-11-19 21:49:37,910 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2010-11-19 21:49:37,912 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2010-11-19 21:49:37,912 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2010-11-19 21:49:37,913 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-11-19 21:49:37,913 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2010-11-19 21:49:37,914 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1290203377913, LastAccessTime = 1290203377913, getTimeToLiveSeconds() = -1, createTime = 1290203377913 ]
2010-11-19 21:49:37,915 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2010-11-19 21:49:37,926 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2010-11-19 21:49:37,926 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-11-19 21:49:37,926 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2010-11-19 21:49:37,926 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2010-11-19 21:49:37,926 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2010-11-19 21:49:37,926 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2010-11-19 21:49:37,926 INFO [CompositeCacheConfigurator] Finished configuration in 15 ms.
2010-11-19 21:49:37,927 DEBUG [DiscoveryManager] UPNP device b8788ec1-4308-32fc-a48f-2532c9b147a9 is available
2010-11-19 21:49:37,927 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2010-11-19 21:49:37,928 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface 192.168.2.4
2010-11-19 21:49:37,928 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2010-11-19 21:49:37,928 INFO [EventDispatcher] Starting EventDispatcher
2010-11-19 21:49:37,950 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface 192.168.2.4
2010-11-19 21:49:37,968 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b8788ec1-4308-32fc-a48f-2532c9b147a9
2010-11-19 21:49:37,970 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:14:17
2010-11-19 21:49:38,305 DEBUG [WebServer] Incoming connection from /192.168.2.5:49945
2010-11-19 21:49:38,308 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device b8788ec1-4308-32fc-a48f-2532c9b147a9 from UPnP/1.0
2010-11-19 21:49:38,525 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV'
2010-11-19 21:49:38,604 DEBUG [WebServer] Incoming connection from /192.168.2.5:49946
2010-11-19 21:49:38,605 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2010-11-19 21:49:38,612 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2010-11-19 21:49:38,657 DEBUG [WebServer] Incoming connection from /192.168.2.5:49947
2010-11-19 21:49:38,660 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2010-11-19 21:49:38,673 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2010-11-19 21:49:38,757 DEBUG [WebServer] Incoming connection from /192.168.2.5:49948
2010-11-19 21:49:38,758 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from UPnP/1.0 DLNADOC/1.50:
2010-11-19 21:49:39,005 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-11-19 21:49:39,024 DEBUG [WebServer] Incoming connection from /192.168.2.5:49949
2010-11-19 21:49:39,025 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from UPnP/1.0 DLNADOC/1.50:
2010-11-19 21:49:39,030 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-11-19 21:49:39,436 DEBUG [WebServer] Incoming connection from /192.168.2.5:49950
2010-11-19 21:49:39,437 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon largeJPG
2010-11-19 21:49:39,526 DEBUG [WebServer] Incoming connection from /192.168.2.5:49951
2010-11-19 21:49:39,527 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon largeJPG
2010-11-19 21:49:39,649 DEBUG [WebServer] Incoming connection from /192.168.2.5:49952
2010-11-19 21:49:39,650 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon largeJPG
2010-11-19 21:49:41,323 INFO [UpdateChecker] Checking if a new version is available
2010-11-19 21:49:42,078 DEBUG [RepositoryDAOImpl] Reading all Repositories
2010-11-19 21:49:43,632 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2010-11-19 21:49:43,653 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2010-11-19 21:49:45,327 DEBUG [RepositoryDAOImpl] Reading all Repositories
2010-11-19 21:49:57,944 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files------------------------------------------------------------------
2010-11-19 21:50:22,896 DEBUG [WebServer] Incoming connection from /192.168.2.5:38159
2010-11-19 21:50:22,899 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1287/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1, Pragma: getIfoFileURI.dlna.org, transferMode.dlna.org: Streaming, X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40NX503";, X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40NX503"; mv="1.7";, Host: 192.168.2.4:8895, ]
2010-11-19 21:50:22,899 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.5, Profile=Sony Bravia TV'
2010-11-19 21:50:22,899 DEBUG [ResourceTransportRequestHandler] Request for resource 1287 and type 'MEDIA_ITEM' received
2010-11-19 21:50:22,899 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1287)
2010-11-19 21:50:22,900 DEBUG [VideoDAOImpl] Reading a Video (id = 1287)
2010-11-19 21:50:22,900 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1287, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV
2010-11-19 21:50:22,900 DEBUG [VideoDeliveryEngine] Getting media info for transcoded version of file Inception (2010) 1080P MKV AC3+DTS Eng-NLSubs-DMT.mkv
2010-11-19 21:50:22,900 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Inception (2010) 1080P MKV AC3+DTS Eng-NLSubs-DMT.mkv: AVC_TS_MP_HD_AC3_ISO
2010-11-19 21:50:22,901 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2010-11-19 21:50:22,901 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/mpeg, Date: Fri, 19 Nov 2010 21:50:22 GMT, Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_50_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-11-19 21:50:22,904 DEBUG [MediaItemDAOImpl] Getting file of media item 403
2010-11-19 21:50:22,904 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 403) and extractor EMBEDDED
2010-11-19 21:50:22,929 DEBUG [WebServer] Incoming connection from /192.168.2.5:38160
2010-11-19 21:50:22,934 DEBUG [ResourceTransportRequestHandler] GET /resource/1287/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-, getcontentFeatures.dlna.org: 1, Pragma: getIfoFileURI.dlna.org, transferMode.dlna.org: Streaming, X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40NX503";, X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40NX503"; mv="1.7";, Host: 192.168.2.4:8895, ]
2010-11-19 21:50:22,934 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.5, Profile=Sony Bravia TV'
2010-11-19 21:50:22,934 DEBUG [ResourceTransportRequestHandler] Request for resource 1287 and type 'MEDIA_ITEM' received
2010-11-19 21:50:22,934 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1287)
2010-11-19 21:50:22,934 DEBUG [VideoDAOImpl] Reading a Video (id = 1287)
2010-11-19 21:50:22,935 DEBUG [VideoDeliveryEngine] Delivering item '1287' for client 'IPAddress=/192.168.2.5, Profile=Sony Bravia TV'
2010-11-19 21:50:22,935 DEBUG [VideoDeliveryEngine] Delivering file 'Inception (2010) 1080P MKV AC3+DTS Eng-NLSubs-DMT.mkv' using transcoding
2010-11-19 21:50:22,935 DEBUG [VideoDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.2.5, Profile=Sony Bravia TV'
2010-11-19 21:50:22,935 DEBUG [MediaItemDAOImpl] Getting file of media item 1287
2010-11-19 21:50:22,936 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode file: /Users/kage_1/Downloads/Transmission Downloads/Inception (2010) 1080P MKV AC3+DTS Eng-NLSubs-DMT/Inception (2010) 1080P MKV AC3+DTS Eng-NLSubs-DMT.mkv
2010-11-19 21:50:22,936 DEBUG [ProcessExecutor] Starting /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg -i /Users/kage_1/Downloads/Transmission Downloads/Inception (2010) 1080P MKV AC3+DTS Eng-NLSubs-DMT/Inception (2010) 1080P MKV AC3+DTS Eng-NLSubs-DMT.mkv -y -vcodec copy -copyts -acodec ac3 -ab 192k -ac 2 -vbsf h264_mp4toannexb -sn -f mpegts /var/folders/tG/tGYomiu9GnGaCid5sJSkxk+++TI/-Tmp-/Serviio/transcoding-temp-1287-MPEG2TS.stf
2010-11-19 21:50:30,439 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2010-11-19 21:50:30,485 DEBUG [MediaItemDAOImpl] Getting file of media item 478
2010-11-19 21:50:30,485 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 478) and extractor EMBEDDED
2010-11-19 21:50:30,586 DEBUG [MediaItemDAOImpl] Getting file of media item 479
2010-11-19 21:50:36,043 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 533) and extractor EMBEDDED
2010-11-19 21:50:36,085 DEBUG [WebServer] Incoming connection from /192.168.2.5:38161
2010-11-19 21:50:36,085 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from UPnP/1.0 DLNADOC/1.50:
2010-11-19 21:50:36,090 DEBUG [ContentDirectory] Browse() called for profile Sony Bravia TV with parameters: objectID = V_T, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2010-11-19 21:50:36,090 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2010-11-19 21:50:36,094 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-11-19 21:50:38,359 DEBUG [WebServer] Incoming connection from /192.168.2.5:38162
2010-11-19 21:50:38,360 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from UPnP/1.0 DLNADOC/1.50:
2010-11-19 21:50:38,364 DEBUG [ContentDirectory] Browse() called for profile Sony Bravia TV with parameters: objectID = V_T#INI_D, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2010-11-19 21:50:38,364 DEBUG [VideoDAOImpl] Retrieving list of videos with initial D (from=0, count=10)
2010-11-19 21:50:38,366 DEBUG [MediaItemDAOImpl] Getting file of media item 556
2010-11-19 21:50:38,366 DEBUG [GenreDAOImpl] Reading a Genre (id = 3)
2010-11-19 21:50:38,366 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 556) and extractor EMBEDDED
2010-11-19 21:50:38,367 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 290)
2010-11-19 21:50:38,367 DEBUG [MediaItemDAOImpl] Getting file of media item 290
2010-11-19 21:50:38,368 DEBUG [VideoDAOImpl] Reading a Video (id = 290)
2010-11-19 21:50:38,368 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 290 and profile Sony Bravia TV
2010-11-19 21:50:38,369 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file The.Dark.Knight.2008.BluRay.1080p.DTS.x264.dxva-EuReKA.mkv: AVC_TS_MP_HD_AC3_ISO
2010-11-19 21:50:38,369 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 289)
2010-11-19 21:50:38,422 DEBUG [VideoDAOImpl] Retrieving number of videos with initial D
2010-11-19 21:50:38,424 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2010-11-19 21:50:38,427 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-11-19 21:50:38,467 DEBUG [MediaItemDAOImpl] Getting file of media item 557
2010-11-19 21:50:38,468 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 557) and extractor EMBEDDED
2010-11-19 21:50:38,567 DEBUG [WebServer] Incoming connection from /192.168.2.5:38163
2010-11-19 21:50:38,568 DEBUG [MediaItemDAOImpl] Getting file of media item 558
2010-11-19 21:50:38,569 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 558) and extractor EMBEDDED
2010-11-19 21:50:38,571 DEBUG [ResourceTransportRequestHandler] GET /resource/289/COVER_IMAGE HTTP/1.1, headers = [transferMode.dlna.org: Interactive, X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40NX503";, X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40NX503"; mv="1.7";, Host: 192.168.2.4:8895, ]
2010-11-19 21:50:38,571 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.5, Profile=Sony Bravia TV'
2010-11-19 21:50:38,571 DEBUG [ResourceTransportRequestHandler] Request for resource 289 and type 'COVER_IMAGE' received
2010-11-19 21:50:38,572 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 289)
2010-11-19 21:50:38,573 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 289
2010-11-19 21:50:38,573 DEBUG [ResourceTransportRequestHandler] Entity will be consumed till the end
2010-11-19 21:50:38,573 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: -1
2010-11-19 21:50:38,573 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2010-11-19 21:50:38,573 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-11-19 21:50:38,573 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Date: Fri, 19 Nov 2010 21:50:38 GMT, Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, transferMode.dlna.org: Interactive, ]
2010-11-19 21:50:42,334 DEBUG [WebServer] Incoming connection from /192.168.2.5:38164
2010-11-19 21:50:42,334 DEBUG [ResourceTransportRequestHandler] HEAD /resource/290/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1, Pragma: getIfoFileURI.dlna.org, transferMode.dlna.org: Streaming, X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40NX503";, X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40NX503"; mv="1.7";, Host: 192.168.2.4:8895, ]
2010-11-19 21:50:42,335 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.5, Profile=Sony Bravia TV'
2010-11-19 21:50:42,335 DEBUG [ResourceTransportRequestHandler] Request for resource 290 and type 'MEDIA_ITEM' received
2010-11-19 21:50:42,335 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 290)
2010-11-19 21:50:42,335 DEBUG [VideoDAOImpl] Reading a Video (id = 290)
2010-11-19 21:50:42,335 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 290, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV
2010-11-19 21:50:42,335 DEBUG [VideoDeliveryEngine] Getting media info for transcoded version of file The.Dark.Knight.2008.BluRay.1080p.DTS.x264.dxva-EuReKA.mkv
2010-11-19 21:50:42,336 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file The.Dark.Knight.2008.BluRay.1080p.DTS.x264.dxva-EuReKA.mkv: AVC_TS_MP_HD_AC3_ISO
2010-11-19 21:50:42,336 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2010-11-19 21:50:42,336 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: video/mpeg, Date: Fri, 19 Nov 2010 21:50:42 GMT, Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/0.4.2, Cache-control: no-cache, contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_50_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000, transferMode.dlna.org: Streaming, ]
2010-11-19 21:50:42,354 DEBUG [WebServer] Incoming connection from /192.168.2.5:38165
2010-11-19 21:50:42,367 DEBUG [ResourceTransportRequestHandler] GET /resource/290/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-, getcontentFeatures.dlna.org: 1, Pragma: getIfoFileURI.dlna.org, transferMode.dlna.org: Streaming, X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40NX503";, X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40NX503"; mv="1.7";, Host: 192.168.2.4:8895, ]
2010-11-19 21:50:42,367 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.5, Profile=Sony Bravia TV'
2010-11-19 21:50:42,368 DEBUG [ResourceTransportRequestHandler] Request for resource 290 and type 'MEDIA_ITEM' received
2010-11-19 21:50:42,368 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 290)
2010-11-19 21:50:42,368 DEBUG [VideoDAOImpl] Reading a Video (id = 290)
2010-11-19 21:50:42,368 DEBUG [VideoDeliveryEngine] Delivering item '290' for client 'IPAddress=/192.168.2.5, Profile=Sony Bravia TV'
2010-11-19 21:50:42,368 DEBUG [VideoDeliveryEngine] Delivering file 'The.Dark.Knight.2008.BluRay.1080p.DTS.x264.dxva-EuReKA.mkv' using transcoding
2010-11-19 21:50:42,368 DEBUG [VideoDeliveryEngine] Stopping previous transcoding job of file '/var/folders/tG/tGYomiu9GnGaCid5sJSkxk+++TI/-Tmp-/Serviio/transcoding-temp-1287-MPEG2TS.stf'
2010-11-19 21:50:42,368 DEBUG [VideoDeliveryEngine] Deleted temp file '/var/folders/tG/tGYomiu9GnGaCid5sJSkxk+++TI/-Tmp-/Serviio/transcoding-temp-1287-MPEG2TS.stf': true
2010-11-19 21:50:42,369 DEBUG [VideoDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.2.5, Profile=Sony Bravia TV'
2010-11-19 21:50:42,369 DEBUG [MediaItemDAOImpl] Getting file of media item 290
2010-11-19 21:50:42,369 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode file: /Users/kage_1/Downloads/Transmission Downloads/The.Dark.Knight.BluRay.1080p.DTS.x264.dxva-EuReKA/1. Sample/The.Dark.Knight.2008.BluRay.1080p.DTS.x264.dxva-EuReKA.mkv
2010-11-19 21:50:42,369 DEBUG [ProcessExecutor] Starting /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg -i /Users/kage_1/Downloads/Transmission Downloads/The.Dark.Knight.BluRay.1080p.DTS.x264.dxva-EuReKA/1. Sample/The.Dark.Knight.2008.BluRay.1080p.DTS.x264.dxva-EuReKA.mkv -y -vcodec copy -copyts -acodec ac3 -ab 192k -ac 2 -vbsf h264_mp4toannexb -sn -f mpegts /var/folders/tG/tGYomiu9GnGaCid5sJSkxk+++TI/-Tmp-/Serviio/transcoding-temp-290-MPEG2TS.stf
2010-11-19 21:50:42,408 DEBUG [MediaItemDAOImpl] Getting file of media item 596
2010-11-19 21:50:42,409 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 596) and extractor EMBEDDED
2010-11-19 21:50:42,460 WARN [ProcessExecutor] Process /Applications/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg has a return code of 1! This is a possible error.
2010-11-19 21:50:42,460 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2010-11-19 21:50:49,872 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2010-11-19 21:50:49,885 DEBUG [MediaItemDAOImpl] Getting file of media item 670
2010-11-19 21:50:49,885 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 670) and extractor EMBEDDED
2010-11-19 21:50:49,986 DEBUG [MediaItemDAOImpl] Getting file of media item 671
2010-11-19 21:50:49,987 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 671) and extractor EMBEDDED
2010-11-19 21:50:50,087 DEBUG [MediaItemDAOImpl] Getting file of media item 672
2010-11-19 21:50:50,088 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 672) and extractor EMBEDDED
2010-11-19 21:50:50,188 DEBUG [MediaItemDAOImpl] Getting file of media item 673
2010-11-19 21:50:50,189 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 673) and extractor EMBEDDED
2010-11-19 21:50:50,289 DEBUG [MediaItemDAOImpl] Getting file of media item 674
2010-11-19 21:50:50,290 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 674) and extractor EMBEDDED
2010-11-19 21:50:50,390 DEBUG [MediaItemDAOImpl] Getting file of media item 675
2010-11-19 21:50:50,391 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 675) and extractor EMBEDDED
2010-11-19 21:50:50,491 DEBUG [MediaItemDAOImpl] Getting file of media item 676
2010-11-19 21:50:50,492 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 676) and extractor EMBEDDED
2010-11-19 21:50:50,592 DEBUG [MediaItemDAOImpl] Getting file of media item 677
2010-11-19 21:50:50,593 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 677) and extractor EMBEDDED
2010-11-19 21:50:50,693 DEBUG [MediaItemDAOImpl] Getting file of media item 678
2010-11-19 21:50:50,694 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 678) and extractor EMBEDDED
2010-11-19 21:50:50,794 DEBUG [MediaItemDAOImpl] Getting file of media item 679
2010-11-19 21:50:50,795 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 679) and extractor EMBEDDED
2010-11-19 21:50:50,895 DEBUG [MediaItemDAOImpl] Getting file of media item 680
2010-11-19 21:50:50,896 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 680) and extractor EMBEDDED
2010-11-19 21:50:50,996 DEBUG [MediaItemDAOImpl] Getting file of media item 681
2010-11-19 21:50:50,997 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 681) and extractor EMBEDDED
2010-11-19 21:50:51,097 DEBUG [MediaItemDAOImpl] Getting file of media item 682
2010-11-19 21:50:51,098 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 682) and extractor EMBEDDED
2010-11-19 21:50:51,198 DEBUG [MediaItemDAOImpl] Getting file of media item 683
2010-11-19 21:50:51,199 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 683) and extractor EMBEDDED
2010-11-19 21:50:51,299 DEBUG [MediaItemDAOImpl] Getting file of media item 684
2010-11-19 21:50:51,300 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 684) and extractor EMBEDDED
2010-11-19 21:50:51,400 DEBUG [MediaItemDAOImpl] Getting file of media item 685
2010-11-19 21:50:51,401 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 685) and extractor EMBEDDED
2010-11-19 21:50:51,501 DEBUG [MediaItemDAOImpl] Getting file of media item 686
2010-11-19 21:50:51,502 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 686) and extractor EMBEDDED
2010-11-19 21:50:51,602 DEBUG [MediaItemDAOImpl] Getting file of media item 687
2010-11-19 21:50:51,603 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 687) and extractor EMBEDDED
2010-11-19 21:50:51,703 DEBUG [MediaItemDAOImpl] Getting file of media item 688
2010-11-19 21:50:51,703 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 688) and extractor EMBEDDED
2010-11-19 21:50:51,804 DEBUG [MediaItemDAOImpl] Getting file of media item 689
2010-11-19 21:50:51,805 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 689) and extractor EMBEDDED
2010-11-19 21:50:51,905 DEBUG [MediaItemDAOImpl] Getting file of media item 690
2010-11-19 21:50:51,905 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 690) and extractor EMBEDDED
2010-11-19 21:50:52,006 DEBUG [MediaItemDAOImpl] Getting file of media item 691
2010-11-19 21:50:52,007 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 691) and extractor EMBEDDED
2010-11-19 21:50:52,107 DEBUG [MediaItemDAOImpl] Getting file of media item 692
2010-11-19 21:50:52,108 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 692) and extractor EMBEDDED
2010-11-19 21:50:52,208 DEBUG [MediaItemDAOImpl] Getting file of media item 693
2010-11-19 21:50:52,209 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 693) and extractor EMBEDDED
2010-11-19 21:50:52,309 DEBUG [MediaItemDAOImpl] Getting file of media item 694
2010-11-19 21:50:52,310 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 694) and extractor EMBEDDED
2010-11-19 21:50:52,410 DEBUG [MediaItemDAOImpl] Getting file of media item 695
2010-11-19 21:50:52,410 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 695) and extractor EMBEDDED
2010-11-19 21:50:52,511 DEBUG [MediaItemDAOImpl] Getting file of media item 696
2010-11-19 21:50:52,511 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 696) and extractor EMBEDDED
2010-11-19 21:50:52,612 DEBUG [MediaItemDAOImpl] Getting file of media item 697
2010-11-19 21:50:52,612 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 697) and extractor EMBEDDED
2010-11-19 21:50:52,713 DEBUG [MediaItemDAOImpl] Getting file of media item 698
2010-11-19 21:50:52,713 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 698) and extractor EMBEDDED
2010-11-19 21:50:52,814 DEBUG [MediaItemDAOImpl] Getting file of media item 699
2010-11-19 21:50:52,814 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 699) and extractor EMBEDDED
2010-11-19 21:50:52,915 DEBUG [MediaItemDAOImpl] Getting file of media item 700
2010-11-19 21:50:52,915 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 700) and extractor EMBEDDED
2010-11-19 21:50:53,016 DEBUG [MediaItemDAOImpl] Getting file of media item 701
2010-11-19 21:50:53,016 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 701) and extractor EMBEDDED
2010-11-19 21:50:53,117 DEBUG [MediaItemDAOImpl] Getting file of media item 702
2010-11-19 21:50:53,117 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 702) and extractor EMBEDDED
2010-11-19 21:50:53,218 DEBUG [MediaItemDAOImpl] Getting file of media item 703
2010-11-19 21:50:53,218 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 703) and extractor EMBEDDED
2010-11-19 21:50:53,319 DEBUG [MediaItemDAOImpl] Getting file of media item 704
2010-11-19 21:50:53,319 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 704) and extractor EMBEDDED
2010-11-19 21:50:53,420 DEBUG [MediaItemDAOImpl] Getting file of media item 705
2010-11-19 21:50:53,420 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 705) and extractor EMBEDDED
2010-11-19 21:50:53,521 DEBUG [MediaItemDAOImpl] Getting file of media item 706
2010-11-19 21:50:53,521 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 706) and extractor EMBEDDED
2010-11-19 21:50:53,622 DEBUG [MediaItemDAOImpl] Getting file of media item 707
2010-11-19 21:50:53,622 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 707) and extractor EMBEDDED
2010-11-19 21:50:53,723 DEBUG [MediaItemDAOImpl] Getting file of media item 708
2010-11-19 21:50:53,723 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 708) and extractor EMBEDDED
2010-11-19 21:50:53,824 DEBUG [MediaItemDAOImpl] Getting file of media item 709
2010-11-19 21:50:53,824 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 709) and extractor EMBEDDED
2010-11-19 21:50:53,925 DEBUG [MediaItemDAOImpl] Getting file of media item 710
2010-11-19 21:50:53,925 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 710) and extractor EMBEDDED
2010-11-19 21:50:54,026 DEBUG [MediaItemDAOImpl] Getting file of media item 711
2010-11-19 21:50:54,026 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 711) and extractor EMBEDDED
2010-11-19 21:50:54,127 DEBUG [MediaItemDAOImpl] Getting file of media item 712
2010-11-19 21:50:54,127 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 712) and extractor EMBEDDED
2010-11-19 21:50:54,228 DEBUG [MediaItemDAOImpl] Getting file of media item 713
2010-11-19 21:50:54,228 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 713) and extractor EMBEDDED
2010-11-19 21:50:54,260 DEBUG [WebServer] Incoming connection from /192.168.2.5:38166
2010-11-19 21:50:54,275 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from UPnP/1.0 DLNADOC/1.50:
2010-11-19 21:50:54,280 DEBUG [ContentDirectory] Browse() called for profile Sony Bravia TV with parameters: objectID = V_T, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2010-11-19 21:50:54,280 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2010-11-19 21:50:54,284 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-11-19 21:50:54,329 DEBUG [MediaItemDAOImpl] Getting file of media item 714
2010-11-19 21:50:54,329 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 714) and extractor EMBEDDED
2010-11-19 21:50:54,429 DEBUG [MediaItemDAOImpl] Getting file of media item 715
2010-11-19 21:50:54,430 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 715) and extractor EMBEDDED
2010-11-19 21:50:54,530 DEBUG [MediaItemDAOImpl] Getting file of media item 716
2010-11-19 21:50:54,531 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 716) and extractor EMBEDDED
2010-11-19 21:50:54,631 DEBUG [MediaItemDAOImpl] Getting file of media item 717
2010-11-19 21:50:54,632 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 717) and extractor EMBEDDED
2010-11-19 21:50:54,695 DEBUG [WebServer] Incoming connection from /192.168.2.5:38167
2010-11-19 21:50:54,696 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from UPnP/1.0 DLNADOC/1.50:
2010-11-19 21:50:54,699 DEBUG [ContentDirectory] Browse() called for profile Sony Bravia TV with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2010-11-19 21:50:54,699 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2010-11-19 21:50:54,704 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-11-19 21:50:54,732 DEBUG [MediaItemDAOImpl] Getting file of media item 718
2010-11-19 21:50:54,733 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 718) and extractor EMBEDDED
2010-11-19 21:50:54,833 DEBUG [MediaItemDAOImpl] Getting file of media item 719
2010-11-19 21:50:54,834 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 719) and extractor EMBEDDED
2010-11-19 21:50:54,934 DEBUG [MediaItemDAOImpl] Getting file of media item 720
2010-11-19 21:50:54,935 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 720) and extractor EMBEDDED
2010-11-19 21:50:55,035 DEBUG [MediaItemDAOImpl] Getting file of media item 721
2010-11-19 21:50:55,036 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 721) and extractor EMBEDDED
2010-11-19 21:50:55,062 DEBUG [WebServer] Incoming connection from /192.168.2.5:38168
2010-11-19 21:50:55,062 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from UPnP/1.0 DLNADOC/1.50:
2010-11-19 21:50:55,066 DEBUG [ContentDirectory] Browse() called for profile Sony Bravia TV with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:class,res@resolution,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2010-11-19 21:50:55,066 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2010-11-19 21:50:55,068 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-11-19 21:50:55,136 DEBUG [MediaItemDAOImpl] Getting file of media item 722
2010-11-19 21:50:55,137 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 722) and extractor EMBEDDED
2010-11-19 21:50:55,237 DEBUG [MediaItemDAOImpl] Getting file of media item 723
2010-11-19 21:50:55,238 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 723) and extractor EMBEDDED
2010-11-19 21:50:55,338 DEBUG [MediaItemDAOImpl] Getting file of media item 724
2010-11-19 21:50:55,339 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 724) and extractor EMBEDDED
2010-11-19 21:50:55,439 DEBUG [MediaItemDAOImpl] Getting file of media item 725
2010-11-19 21:50:55,440 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 725) and extractor EMBEDDED
2010-11-19 21:50:55,540 DEBUG [MediaItemDAOImpl] Getting file of media item 726
2010-11-19 21:50:55,541 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 726) and extractor EMBEDDED
2010-11-19 21:50:55,641 DEBUG [MediaItemDAOImpl] Getting file of media item 727
2010-11-19 21:50:55,642 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 727) and extractor EMBEDDED
2010-11-19 21:50:55,742 DEBUG [MediaItemDAOImpl] Getting file of media item 728
2010-11-19 21:50:55,743 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 728) and extractor EMBEDDED
2010-11-19 21:50:55,843 DEBUG [MediaItemDAOImpl] Getting file of media item 729
2010-11-19 21:50:55,844 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 729) and extractor EMBEDDED
2010-11-19 21:50:55,944 DEBUG [MediaItemDAOImpl] Getting file of media item 730
2010-11-19 21:50:55,945 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 730) and extractor EMBEDDED
2010-11-19 21:50:56,045 DEBUG [MediaItemDAOImpl] Getting file of media item 731
2010-11-19 21:50:56,046 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 731) and extractor EMBEDDED
2010-11-19 21:50:56,146 DEBUG [MediaItemDAOImpl] Getting file of media item 732
2010-11-19 21:50:56,147 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 732) and extractor EMBEDDED
2010-11-19 21:50:56,247 DEBUG [MediaItemDAOImpl] Getting file of media item 733
2010-11-19 21:50:56,248 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 733) and extractor EMBEDDED
2010-11-19 21:50:56,348 DEBUG [MediaItemDAOImpl] Getting file of media item 734
2010-11-19 21:50:56,349 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 734) and extractor EMBEDDED
2010-11-19 21:50:56,449 DEBUG [MediaItemDAOImpl] Getting file of media item 735
2010-11-19 21:50:56,450 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 735) and extractor EMBEDDED
2010-11-19 21:50:56,550 DEBUG [MediaItemDAOImpl] Getting file of media item 736
2010-11-19 21:50:56,551 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 736) and extractor EMBEDDED
2010-11-19 21:50:56,651 DEBUG [MediaItemDAOImpl] Getting file of media item 737
2010-11-19 21:50:56,652 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 737) and extractor EMBEDDED
2010-11-19 21:50:56,752 DEBUG [MediaItemDAOImpl] Getting file of media item 738
2010-11-19 21:50:56,753 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 738) and extractor EMBEDDED
2010-11-19 21:50:56,853 DEBUG [MediaItemDAOImpl] Getting file of media item 739
2010-11-19 21:50:56,854 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 739) and extractor EMBEDDED
2010-11-19 21:50:56,954 DEBUG [MediaItemDAOImpl] Getting file of media item 740
2010-11-19 21:50:56,955 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 740) and extractor EMBEDDED
2010-11-19 21:50:57,055 DEBUG [MediaItemDAOImpl] Getting file of media item 741
2010-11-19 21:50:57,056 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 741) and extractor EMBEDDED
2010-11-19 21:50:57,156 DEBUG [MediaItemDAOImpl] Getting file of media item 742
2010-11-19 21:50:57,157 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 742) and extractor EMBEDDED
2010-11-19 21:50:57,257 DEBUG [MediaItemDAOImpl] Getting file of media item 743
2010-11-19 21:50:57,258 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 743) and extractor EMBEDDED
2010-11-19 21:50:57,358 DEBUG [MediaItemDAOImpl] Getting file of media item 744
2010-11-19 21:50:57,358 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 744) and extractor EMBEDDED
2010-11-19 21:50:57,459 DEBUG [MediaItemDAOImpl] Getting file of media item 745
2010-11-19 21:50:57,459 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 745) and extractor EMBEDDED
2010-11-19 21:50:57,560 DEBUG [MediaItemDAOImpl] Getting file of media item 746
2010-11-19 21:50:57,560 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 746) and extractor EMBEDDED
2010-11-19 21:50:57,661 DEBUG [MediaItemDAOImpl] Getting file of media item 747
2010-11-19 21:50:57,661 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 747) and extractor EMBEDDED
2010-11-19 21:50:57,762 DEBUG [MediaItemDAOImpl] Getting file of media item 748
2010-11-19 21:50:57,762 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 748) and extractor EMBEDDED
2010-11-19 21:50:57,863 DEBUG [MediaItemDAOImpl] Getting file of media item 749
2010-11-19 21:50:57,863 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 749) and extractor EMBEDDED
2010-11-19 21:50:57,964 DEBUG [MediaItemDAOImpl] Getting file of media item 750
2010-11-19 21:50:57,964 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 750) and extractor EMBEDDED
2010-11-19 21:50:58,065 DEBUG [MediaItemDAOImpl] Getting file of media item 751
2010-11-19 21:50:58,065 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 751) and extractor EMBEDDED
2010-11-19 21:50:58,166 DEBUG [MediaItemDAOImpl] Getting file of media item 752
2010-11-19 21:50:58,166 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 752) and extractor EMBEDDED
2010-11-19 21:50:58,267 DEBUG [MediaItemDAOImpl] Getting file of media item 753
2010-11-19 21:50:58,267 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 753) and extractor EMBEDDED
2010-11-19 21:50:58,368 DEBUG [MediaItemDAOImpl] Getting file of media item 754
2010-11-19 21:50:58,368 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 754) and extractor EMBEDDED
2010-11-19 21:50:58,469 DEBUG [MediaItemDAOImpl] Getting file of media item 755
2010-11-19 21:50:58,469 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 755) and extractor EMBEDDED
2010-11-19 21:50:58,569 DEBUG [MediaItemDAOImpl] Getting file of media item 756
2010-11-19 21:50:58,570 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 756) and extractor EMBEDDED
2010-11-19 21:50:58,671 DEBUG [MediaItemDAOImpl] Getting file of media item 757
2010-11-19 21:50:58,671 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 757) and extractor EMBEDDED
2010-11-19 21:50:58,772 DEBUG [MediaItemDAOImpl] Getting file of media item 758
2010-11-19 21:50:58,772 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 758) and extractor EMBEDDED
2010-11-19 21:50:58,873 DEBUG [MediaItemDAOImpl] Getting file of media item 759
2010-11-19 21:50:58,873 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 759) and extractor EMBEDDED
2010-11-19 21:50:58,974 DEBUG [MediaItemDAOImpl] Getting file of media item 760
2010-11-19 21:50:58,974 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 760) and extractor EMBEDDED
2010-11-19 21:50:59,075 DEBUG [MediaItemDAOImpl] Getting file of media item 761
2010-11-19 21:50:59,075 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 761) and extractor EMBEDDED
2010-11-19 21:50:59,176 DEBUG [MediaItemDAOImpl] Getting file of media item 762
2010-11-19 21:50:59,176 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 762) and extractor EMBEDDED
2010-11-19 21:50:59,277 DEBUG [MediaItemDAOImpl] Getting file of media item 763
2010-11-19 21:50:59,277 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 763) and extractor EMBEDDED
2010-11-19 21:50:59,378 DEBUG [MediaItemDAOImpl] Getting file of media item 764
2010-11-19 21:50:59,378 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 764) and extractor EMBEDDED
2010-11-19 21:50:59,478 DEBUG [MediaItemDAOImpl] Getting file of media item 765
2010-11-19 21:50:59,479 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 765) and extractor EMBEDDED
2010-11-19 21:50:59,579 DEBUG [MediaItemDAOImpl] Getting file of media item 766
2010-11-19 21:50:59,580 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 766) and extractor EMBEDDED
2010-11-19 21:50:59,680 DEBUG [MediaItemDAOImpl] Getting file of media item 767
2010-11-19 21:50:59,681 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 767) and extractor EMBEDDED
2010-11-19 21:50:59,781 DEBUG [MediaItemDAOImpl] Getting file of media item 768
2010-11-19 21:50:59,782 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 768) and extractor EMBEDDED
2010-11-19 21:50:59,883 DEBUG [MediaItemDAOImpl] Getting file of media item 769
2010-11-19 21:50:59,883 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 769) and extractor EMBEDDED
2010-11-19 21:50:59,984 DEBUG [MediaItemDAOImpl] Getting file of media item 770
2010-11-19 21:50:59,984 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 770) and extractor EMBEDDED
2010-11-19 21:51:00,085 DEBUG [MediaItemDAOImpl] Getting file of media item 771
2010-11-19 21:51:00,085 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 771) and extractor EMBEDDED
2010-11-19 21:51:00,186 DEBUG [MediaItemDAOImpl] Getting file of media item 772
2010-11-19 21:51:00,186 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 772) and extractor EMBEDDED
2010-11-19 21:51:00,286 DEBUG [MediaItemDAOImpl] Getting file of media item 773
2010-11-19 21:51:00,287 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 773) and extractor EMBEDDED
2010-11-19 21:51:00,387 DEBUG [MediaItemDAOImpl] Getting file of media item 774
2010-11-19 21:51:00,388 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 774) and extractor EMBEDDED
2010-11-19 21:51:00,488 DEBUG [MediaItemDAOImpl] Getting file of media item 775
2010-11-19 21:51:00,489 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 775) and extractor EMBEDDED
2010-11-19 21:51:00,589 DEBUG [MediaItemDAOImpl] Getting file of media item 776
2010-11-19 21:51:00,590 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 776) and extractor EMBEDDED
2010-11-19 21:51:00,690 DEBUG [MediaItemDAOImpl] Getting file of media item 777
2010-11-19 21:51:00,691 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 777) and extractor EMBEDDED
2010-11-19 21:51:00,791 DEBUG [MediaItemDAOImpl] Getting file of media item 778
2010-11-19 21:51:00,792 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 778) and extractor EMBEDDED
2010-11-19 21:51:00,892 DEBUG [MediaItemDAOImpl] Getting file of media item 779
2010-11-19 21:51:00,893 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 779) and extractor EMBEDDED
2010-11-19 21:51:00,994 DEBUG [MediaItemDAOImpl] Getting file of media item 780
2010-11-19 21:51:00,994 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 780) and extractor EMBEDDED
2010-11-19 21:51:01,095 DEBUG [MediaItemDAOImpl] Getting file of media item 781
2010-11-19 21:51:01,095 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 781) and extractor EMBEDDED
2010-11-19 21:51:01,196 DEBUG [MediaItemDAOImpl] Getting file of media item 782
2010-11-19 21:51:01,196 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 782) and extractor EMBEDDED
2010-11-19 21:51:01,297 DEBUG [MediaItemDAOImpl] Getting file of media item 783
2010-11-19 21:51:01,297 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 783) and extractor EMBEDDED
2010-11-19 21:51:01,398 DEBUG [MediaItemDAOImpl] Getting file of media item 784
2010-11-19 21:51:01,398 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 784) and extractor EMBEDDED
2010-11-19 21:51:01,499 DEBUG [MediaItemDAOImpl] Getting file of media item 785
2010-11-19 21:51:01,499 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 785) and extractor EMBEDDED
2010-11-19 21:51:01,600 DEBUG [MediaItemDAOImpl] Getting file of media item 786
2010-11-19 21:51:01,600 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 786) and extractor EMBEDDED
2010-11-19 21:51:01,701 DEBUG [MediaItemDAOImpl] Getting file of media item 787
2010-11-19 21:51:01,701 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 787) and extractor EMBEDDED
2010-11-19 21:51:01,802 DEBUG [MediaItemDAOImpl] Getting file of media item 788
2010-11-19 21:51:01,802 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 788) and extractor EMBEDDED
2010-11-19 21:51:01,903 DEBUG [MediaItemDAOImpl] Getting file of media item 789
2010-11-19 21:51:01,903 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 789) and extractor EMBEDDED
2010-11-19 21:51:01,904 DEBUG [ActionsServerResource] Action with name 'exitServiio' was requested
2010-11-19 21:51:01,913 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2010-11-19 21:51:02,004 DEBUG [MediaItemDAOImpl] Getting file of media item 790
2010-11-19 21:51:02,005 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 790) and extractor EMBEDDED
2010-11-19 21:51:02,105 DEBUG [WebServer] Socket closed
2010-11-19 21:51:02,105 DEBUG [DiscoveryManager] UPNP device b8788ec1-4308-32fc-a48f-2532c9b147a9 is unavailable
2010-11-19 21:51:02,105 INFO [WebServer] WebServer shutting down
2010-11-19 21:51:02,105 INFO [EventDispatcher] Leaving EventDispatcher
2010-11-19 21:51:02,105 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2010-11-19 21:51:02,105 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2010-11-19 21:51:02,105 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface 192.168.2.4
2010-11-19 21:51:02,106 INFO [DatabaseManager] Shutting down database
2010-11-19 21:51:02,106 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2010-11-19 21:51:02,107 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2010-11-19 21:51:02,143 DEBUG [DatabaseManager] DB shutdown returned: Derby system shutdown.
2010-11-19 21:51:02,143 INFO [VideoDeliveryEngine] Cleaning transcode engine and its data
2010-11-19 21:51:02,143 DEBUG [VideoDeliveryEngine] Deleting temporary transcoded files from: /var/folders/tG/tGYomiu9GnGaCid5sJSkxk+++TI/-Tmp-/Serviio
2010-11-19 21:51:02,144 DEBUG [VideoDeliveryEngine] Deleted file /var/folders/tG/tGYomiu9GnGaCid5sJSkxk+++TI/-Tmp-/Serviio/transcoding-temp-290-MPEG2TS.stf: true
