Access by serviio to remote folders in different subnetworks
ronberg
Post Sat Sep 22, 2012 6:09 pm
in principal I have similar proplems as Meelis posted in August here. But 1th I have the impression that the problems of Meelis could not be solved and 2nd my configuration is a bit different:
I am working on two sites (wich are about 700 kms distant): Both are equipped with AVM Fritz!Box Routers (7290 and 7330) with a standing VPN connection between them. This VPN works fine for example for Remote Desktop Connections under Windows between PCs in these two subnetworks without any problem. I's also not any problem to map any folder of any PC to an Pc of the other subnet, provided that the respective folder has got the nessary permissions.
In one site I have operating a server with Windows Home Server 2011(WHS). In this server I stored all my media files (following called site 1). I would like to access these files from the other site (followig called site 2) where I have DLNA client equipment like audio components. All PCs are not operating with a domain (WHS does not support domains).
I installed serviio on a PC at site 2 (operating under Windows 7 prof.). In both sites (in the relevant PC at site 2 and in the WHS at site 1) I created a new User Account called lets say "serviio" with the same passwords. I shared the relevant media folder in the WHS at site 1 with the newly created local account "serviio" giving the permission for reading and changing giving the name of the SharedFolder lets say again SERVIIO. In the properties of the serviio service in site 2 I changed the User Account to serviio and the relevant password, the service starts without any problems.
In the Serviio Console at site 2 I defined the library path to the WHS at site 1 in the form "\\<internal IP of the WHS>\<SERVIIO>\<folder>, where <folder> is a subfolder of the SharedFolder for audio files, and marked "audio files", but serviio cannot find any files in that directory. When I check the database with my phone (andoid app Media House) I get the serviio server, I get the name of the specified folder, I get the defined specifications (wich all are infomations from the local serviio server) and than: nothing, only the message: --End-- Found no more media for display.
In ServiiDroid, wich shows different to the Serviio Console the files added to the database since the last actualisation, I see: no files added.
The logfile shows only:
2012-09-22 18:57:32,949 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-09-22 18:57:32,989 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-09-22 18:57:33,089 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-09-22 18:57:33,091 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-09-22 19:04:17,952 WARN [EventDispatcher] Couldn't send event message for subscription 10ceb7ff-7397-4937-adc1-5698868c981f, will keep trying until subscription expires
2012-09-22 19:04:19,108 WARN [EventDispatcher] Couldn't send event message for subscription d5c015ae-5a68-487b-ab67-320918d731e2, will keep trying until subscription expires
2012-09-22 19:38:03,251 WARN [EventDispatcher] Couldn't send event message for subscription c9910faf-83e2-48c8-bfdb-ccfeb6d65e4c, will keep trying until subscription expires
2012-09-22 19:38:04,401 WARN [EventDispatcher] Couldn't send event message for subscription d670bde9-4854-43e6-b9df-6986274bb6c7, will keep trying until subscription expires
I tried nearly everything including stopping the firewall of the WHS, but nothing changes.
Could you give me any hint?
Many thanks in advance!
Post Sun Sep 23, 2012 7:01 am
Re: Access by serviio to remote folders in different subnetw
From what you have said, you should be on the right path and that should work. Can you post a full detailed log (see sig).
If you log into your windows 7 (site 2) pc as user 'serviio' can you map the network drive in explorer without supplying a password? If not (could try it anyway) http://windows.microsoft.com/en-GB/wind ... -passwords and save the details for \\IP-ADDRESS then try again.
ronberg
Post Sun Sep 23, 2012 3:44 pm
(262.24 KiB) Downloaded 514 times
Hi will, thank you for your support. I added a network account and password according to your proposal. I can map the target folder without giving the account name and password. Nevertheless, serviio seems to get somehow access to the target, but it does not really work: I got 2 entries in my library within the last five hours! Facing the amount of about 20,000 files I think I will never get a complete list, a transfer of the files themselve would be faster!
I changed the log settings to debug and deleted the old logfile. I attach the new debug log.
Users browsing this forum: Baidu [Spider] and 23 guests
