Samsung C/D/E television, are my movies being retranscoded?
philwire
Post Wed Sep 26, 2012 1:59 pm
I have a Samsung television and a few movies in a few different formats, from 480p to 1080p. Then I saw this line:
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" maxVBitrate="20000">
Now, I'm no big expert in all this, but does this mean my 1080p mkv movies are being retranscoded to something lighter, like 720p or 1080i? Because if they are, I will stop getting my files in 1080p and target a lighter format, and save bandwidth at the same time.
Thanks!
philwire
Post Wed Sep 26, 2012 2:56 pm
Re: Samsung C/D/E television, are my movies being retranscod
they are not, unless it's an unsuported format. MKVs pay natively unless the H264 profile/level is greater that 4.1, or use header compression.
philwire
Post Wed Sep 26, 2012 4:28 pm
alright, thankx!
crackedtooth
Post Tue Oct 02, 2012 1:46 pm
philwire wrote:alright, thankx!
Check this threaD:
viewtopic.php?f=7&t=7547
with the new servio the porofile is not good for the samsung tv and some mkv get transcoded needlessly.
Sorted on page 3 of that thread
Post Tue Oct 02, 2012 3:55 pm
That is incorrect. The profile conforms to the Samsung specs for their TV's, and just because this user believes he has 2 files that will play natively, is not a reason to alter it,
Post Tue Oct 02, 2012 4:26 pm
Depends on how Samsung work out the level - either header based (looks like not in this case) or ref frame based. Might have to add some switch for this in the future if we can build a reasonable set of files that will prove this.
Post Tue Oct 02, 2012 4:45 pm
I'll test it out and let you know.
