Problem with Sopcast source
BurnServ
Post Fri Jul 13, 2012 5:34 pm
Hello.
I've recently formatted my PC and since then i can't seem to access to a sopcast transmission using Serviio. Every time i enter on the Online folder in my LG SmartTV the sopcast icon that should appear in the folder isn't there, instead the folder is empty. I've confirmed the correct link on Serviio online source and using VLC to check if the link is working. Every other feature is working fine on the TV.
This option was working fine before i formatted my PC.
Anyone as any ideas on how to pt it to work again?
BurnServ
Post Fri Aug 03, 2012 6:18 pm
Re: Problem with Sopcast source
I'm having the same issue with the latest version (1.00).
In the console i checked the url and was OK according to the console. For some reason it doesn't appear in my TV.
BurnServ
Post Thu Sep 27, 2012 2:50 am
Still with the same issue with 1.0.1
Does anyone has any ideas how to fix this problem?
Xmantium
Post Sat Sep 29, 2012 9:14 pm
Theres now a plugin for sopcast to make it easier to stream with Serviio, found here -> viewtopic.php?f=20&t=7249
If theres any issues, post in that post ;)
Users browsing this forum: Bing [Bot] and 30 guests
