WTV and/or DVR-MS files?
wtv is the file format for recorded files of the windows media center in Windows 7 and dvr-ms is the same for Windows Vista.
FFmpeg version SVN-r23012, Copyright (c) 2000-2010 the FFmpeg developers
built on May 3 2010 19:05:24 with gcc 3.4.5 (mingw-vista special r3)
erver --enable-memalign-hack --enable-libmp3lame --enable-w32threads --extra-ldf
lags=-L/static/lib --extra-cflags=-I/static/include
libavutil 50.15. 0 / 50.15. 0
libavcodec 52.66. 0 / 52.66. 0
libavformat 52.62. 0 / 52.62. 0
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.10. 0 / 0.10. 0
[mpeg2video @ 028f5fe0]interlaced frame in progressive sequence, ignoring
[mpeg2video @ 028f5fe0]invalid frame_pred_frame_dct
[mpeg2video @ 028f5fe0]slice below image (30 >= 30)
[asf @ 003fba10]max_analyze_duration reached
Seems stream 2 codec frame rate differs from container frame rate: 50.00 (50/1)
-> 25.00 (25/1)
Input #0, asf, from 'i:\tv-aufz-convert\afrika01.dvr-ms':
DVR Index Granularity: 500
WM/SubTitle : Safari und Savanne
WM/SubTitleDescription: Zweiteilige Dokumentation. Der erste Teil konzentrie
rt sich auf die Natursch+ñtze des Landes und seine Tourismusidustrie.
WM/Genre : Sonstiges;Dokumentation
WM/OriginalReleaseTime: 0
WM/Language :
WM/MediaCredits : ;;;
WM/MediaStationCallSign: ZDFinfokanal
WM/MediaStationName: ZDF Infokanal
WM/MediaNetworkAffiliation:
WM/MediaOriginalChannel: 50
WM/MediaOriginalChannelSubNumber: 0
WM/MediaOriginalBroadcastDateTime: 2010-06-14T22:00:00Z
WM/MediaOriginalRunTime: 1844674
WM/MediaIsStereo: 0
WM/MediaIsRepeat: 0
WM/MediaIsLive : 0
WM/MediaIsTape : 0
WM/MediaIsDelay : 0
WM/MediaIsSubtitled: 0
WM/MediaIsMovie : 0
WM/MediaIsPremiere: 0
WM/MediaIsFinale: 0
WM/MediaIsSAP : 0
WM/MediaIsSport : 0
WM/ParentalRating:
WM/ParentalRatingReason:
WM/Provider : MediaCenterDefault
WM/ProviderCopyright:
WM/ProviderRating:
WM/VideoClosedCaptioning: 0
WM/WMRVEncodeTime: 2021479
WM/WMRVSeriesUID: !GenericSeries!Afrikas Sch+ñtze
WM/WMRVServiceID: !Generated!72f7eb9a9d944f1b9ea22331cdbc9c99
WM/WMRVProgramID: !MCProgram!22860966
WM/WMRVRequestID: 0
WM/WMRVScheduleItemID: 0
WM/WMRVQuality : 3
WM/WMRVOriginalSoftPrePadding: 420
WM/WMRVOriginalSoftPostPadding: 180
WM/WMRVHardPrePadding: 184
WM/WMRVHardPostPadding: 0
WM/WMRVBrandingName:
WM/WMRVBrandingImageID:
WM/WMRVATSCContent: 0
WM/WMRVDTVContent: 1
WM/WMRVHDContent: 0
WM/WMRVEndTime : 1881098
WM/WMRVBitrate : 1844674
WM/WMRVKeepUntil: 184
WM/WMRVActualSoftPrePadding: 412
WM/WMRVActualSoftPostPadding: 180
WM/WMRVContentProtected: 0
WM/WMRVContentProtectedPercent: 0
WM/WMRVExpirationDate: 1844674
WM/WMRVExpirationSpan: 1844674
WM/WMRVInBandRatingSystem: 255
WM/WMRVInBandRatingLevel: 255
WM/WMRVInBandRatingAttributes: 0
WM/WMRVWatched : 0
WM/MediaThumbType: 3
WM/MediaThumbWidth: 352
WM/MediaThumbHeight: 281
WM/MediaThumbStride: 105
WM/MediaThumbRet: 0
WM/MediaThumbRatingSystem: 255
WM/MediaThumbRatingLevel: 255
WM/MediaThumbRatingAttributes: 0
WM/MediaThumbAspectRatioX: 16
WM/MediaThumbAspectRatioY: 9
WM/MediaThumbTimeStamp: 1844674
WMFSDKVersion : 12.0.7600.16385
WMFSDKNeeded : 0.0.0.0000
VBR Peak : 159
IsVBR : 1
title : Afrikas Sch+ñtze
author :
copyright :
comment :
Duration: 00:49:51.70, start: 0.000000, bitrate: 7427 kb/s
Stream #0.0(ger): Audio: mp2, 48000 Hz, 2 channels, s16, 255 kb/s
Stream #0.1(ger): Invalid Codec type -1
Stream #0.2(ger): Video: mpeg2video, yuv420p, 704x480 [PAR 64:45 DAR 1408:67
5], 15000 kb/s, 25.28 fps, 25 tbr, 1k tbn, 50 tbc
[NULL @ 00feba10]Format detected only with low score of 25, misdetection possibl
e!
[mp3 @ 00fedc80]Header missing
Last message repeated 41 times
[mp3 @ 00feba10]max_analyze_duration reached
[mp3 @ 00feba10]Estimating duration from bitrate, this may be inaccurate
Input #0, mp3, from 'i:\tv-aufz-convert\weltspiegel.wtv':
Duration: 23:20:25.34, start: 0.000000, bitrate: 256 kb/s
Stream #0.0: Audio: mp3, 48000 Hz, 2 channels, s16, 256 kb/s
C:\Program Files\Serviio\lib>ffmpeg -i "D:\Recorded TV\$..! My Dad Says_WGCLDT_2
010_10_21_20_31_00.wtv"
FFmpeg version SVN-r26400, Copyright (c) 2000-2011 the FFmpeg developers
built on Jan 18 2011 04:07:05 with gcc 4.4.2
configuration: --enable-gpl --enable-version3 --enable-libgsm --enable-libvorb
is --enable-libtheora --enable-libspeex --enable-libmp3lame --enable-libopenjpeg
--enable-libschroedinger --enable-libopencore_amrwb --enable-libopencore_amrnb
--enable-libvpx --disable-decoder=libvpx --arch=x86 --enable-runtime-cpudetect -
-enable-libxvid --enable-libx264 --enable-librtmp --extra-libs='-lrtmp -lpolarss
l -lws2_32 -lwinmm' --target-os=mingw32 --enable-avisynth --enable-w32threads --
cross-prefix=i686-mingw32- --cc='ccache i686-mingw32-gcc' --enable-memalign-hack
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 1 / 0.16. 1
libavformat 52.93. 0 / 52.93. 0
libavfilter 1.74. 0 / 1.74. 0
libswscale 0.12. 0 / 0.12. 0
[mpeg2video @ 02852770] mpeg_decode_postinit() failure
Last message repeated 11 times
[wtv @ 003fbd40] Estimating duration from bitrate, this may be inaccurate
Input #0, wtv, from 'D:\Recorded TV\$..! My Dad Says_WGCLDT_2010_10_21_20_31_00.
wtv':
Duration: 00:07:28.23, start: 1.917454, bitrate: 65394 kb/s
Stream #0.0[0x20](eng): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Stream #0.1[0x21]: Video: mpeg2video, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9],
65000 kb/s, 57.22 fps, 29.97 tbr, 10000k tbn, 59.94 tbc
Stream #0.2[0x22]: Subtitle: [0][0][0][0] / 0x0000
