Re: SOPCAST VIDEO WEB RESOURCE
Chris
jhb50 wrote:Did you read and follow the first post? Obviously if the stream does not exist then Serviio cannot display it.
jhb50 wrote:You will need to set your log for debug, then refresh the feed and post the log for that period so we can see why.
WildRushSykes wrote:According to the log you are running version 2 of the plugin so you might want to update it and try again
2012-10-03 12:28:47,809 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 10)
2012-10-03 12:28:47,810 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-10-03 12:28:47,816 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000010001 and profile LG TV / player
2012-10-03 12:28:47,818 ERROR [ContainerNode] Cannot retrieve results of action command: Cannot execute library command for list: null
org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: null
jhb50 wrote:Actually Version 3 has been posted since Sept 13. Retry with it.
That said the log shows that the SOPCAST items have been set up correctly but when Serviio goes to display them it gets a 500 error that the list is null. I have gotten this error as well and have yet to figure out why. I got it to go away but I can't recall how. I think I cleared the cache. Try restarting Serviio.
Maybe there is a bug in the plugin.
- Code:
The link in the first post is wrong... It's the link for the V2. Maybe you uploaded the wrong file?
2012-10-09 02:30:52,002 DEBUG [ActionsServerResource] Action with name 'forceLibraryRefresh' was requested
2012-10-09 02:30:52,002 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-10-09 02:30:52,002 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-10-09 02:30:52,005 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-10-09 02:30:52,006 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-10-09 02:30:52,006 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-10-09 02:30:52,007 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-10-09 02:31:09,561 DEBUG [PlaylistDAOImpl] Reading all Playlists
2012-10-09 02:31:21,128 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-10-09 02:31:21,128 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-10-09 02:31:21,130 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2012-10-09 02:31:21,131 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2012-10-09 02:54:05,202 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2012-10-09 02:54:05,203 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2012-10-09 02:54:05,205 DEBUG [VideoDeliveryEngine] Delivering item '1000000000020001' for client 'IPAddress=/10.0.0.5, Profile=Playstation 3'
2012-10-09 02:54:05,205 DEBUG [VideoDeliveryEngine] Delivering file 'http://localhost:8902' using transcoding
2012-10-09 02:54:05,206 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/10.0.0.5, Profile=Playstation 3'
2012-10-09 02:54:05,206 DEBUG [VideoDeliveryEngine] Extracting new URL for the expired feed item
2012-10-09 02:54:05,206 DEBUG [FeedItemUrlExtractor] Sopcast: Starting extraction of url for item: Sopcast #1
2012-10-09 02:54:05,216 DEBUG [FeedItemUrlExtractor] Sopcast: refeshing Sopcast #1
2012-10-09 02:54:05,216 DEBUG [FeedItemUrlExtractor] Sopcast: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=http://localhost:8902, thumbnailUrl=https://sites.google.com/site/serviiorss/sopcast.jpg, expiresImmediately=true, cacheKey=sopcast890222495734, live=true, ]
2012-10-09 02:54:05,216 DEBUG [VideoDeliveryEngine] Successfully set new URL for the feed item
2012-10-09 02:54:05,217 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: http://localhost:8902
2012-10-09 02:54:05,217 DEBUG [ProcessExecutor] Starting "C:\Program Files\Serviio\lib\ffmpeg.bat" -i http://localhost:8902 -y -threads 1 -copyts -c:v mpeg2video -sameq -r 25 -g 15 -c:a ac3 -b:a 384k -ac 2 -map 0:1 -map 0:0 -sn -f mpegts pipe:
2012-10-09 02:54:10,717 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://localhost:8902: MPEG_TS_SD_EU_ISO
2012-10-09 02:54:10,717 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://localhost:8902: MPEG_TS_SD_NA_ISO
2012-10-09 02:54:10,717 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://localhost:8902: MPEG_TS_SD_KO_ISO
2012-10-09 02:54:10,717 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-10-09 02:54:10,717 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-09 02:58:29,366 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2012-10-09 02:58:29,367 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000020001, format AVC_TS_HP_SD_MPEG1_L2_ISO and profile Playstation 3
2012-10-09 02:58:29,367 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-10-09 02:58:29,368 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Tue, 09 Oct 2012 00:58:29 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-10-09 02:58:29,380 DEBUG [WebServer] Incoming connection from /10.0.0.5:64128
2012-10-09 02:58:29,380 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.5
2012-10-09 02:58:29,381 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000020001/MEDIA_ITEM/AVC_TS_HP_SD_MPEG1_L2_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 10.0.0.2:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming]]
2012-10-09 02:58:29,381 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.5
2012-10-09 02:58:29,382 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/10.0.0.5, Profile=Playstation 3'
2012-10-09 02:58:29,383 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000020001 and type 'MEDIA_ITEM' received
2012-10-09 02:58:29,383 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000020001 (online)
2012-10-09 02:58:29,383 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2012-10-09 02:58:29,384 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2012-10-09 02:58:29,385 DEBUG [VideoDeliveryEngine] Delivering item '1000000000020001' for client 'IPAddress=/10.0.0.5, Profile=Playstation 3'
2012-10-09 02:58:29,385 DEBUG [VideoDeliveryEngine] Delivering file 'http://localhost:8902' in native format
2012-10-09 02:58:29,386 DEBUG [VideoDeliveryEngine] Extracting new URL for the expired feed item
2012-10-09 02:58:29,386 DEBUG [FeedItemUrlExtractor] Sopcast: Starting extraction of url for item: Sopcast #1
2012-10-09 02:58:29,400 DEBUG [FeedItemUrlExtractor] Sopcast: refeshing Sopcast #1
2012-10-09 02:58:29,401 DEBUG [FeedItemUrlExtractor] Sopcast: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=http://localhost:8902, thumbnailUrl=https://sites.google.com/site/serviiorss/sopcast.jpg, expiresImmediately=true, cacheKey=sopcast890222495738, live=true, ]
2012-10-09 02:58:29,401 DEBUG [VideoDeliveryEngine] Successfully set new URL for the feed item
2012-10-09 02:58:29,401 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
