How do i enable flv transcoding for LG TV?
Spookyy
Post Mon Oct 01, 2012 7:40 am
Re: How do i enable flv transcoding for LG TV?
I downloaded the profiles.xml mentioned here viewtopic.php?f=12&t=5558&hilit=mkv+unsupported+audio#p40142
and then my .mkv files played okay, but not the renamed one.
Here is some info on the .webm file:
The Indoctrination Theory-A Documentary - Extended Cut-720p.webm.txt
(2.01 KiB) Downloaded 193 times
Post Mon Oct 01, 2012 8:10 am
Spookyy wrote:Here is some info on the .webm file:
Thanks, could you also provide the "ffmpeg -i <filepah>" result ?
Spookyy
Post Mon Oct 01, 2012 8:26 am
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Med ensamrätt.
c:\Program Files\Serviio\lib>ffmpeg -i "The Indoctrination Theory-A Documentary
- Extended Cut-720p.webm"
g-config
Input #0, matroska,webm, from 'The Indoctrination Theory-A Documentary - Extende
d Cut-720p.webm':
  Duration: 01:49:36.22, start: 0.000000, bitrate: 2362 kb/s
    Stream #0:0(eng): Video: vp8, yuv420p, 1280x720, SAR 1:1 DAR 16:9, 1k fps, 1
k tbr, 1k tbn, 1k tbc (default)
    Stream #0:1: Audio: vorbis, 44100 Hz, stereo, s16 (default)
Post Mon Oct 01, 2012 9:58 am
Spookyy wrote:Input #0, matroska,webm, from 'The Indoctrination Theory-A Documentary - Extended Cut-720p.webm':
Stream #0:0(eng): Video: vp8, yuv420p, 1280x720, SAR 1:1 DAR 16:9, 1k fps, 1k tbr, 1k tbn, 1k tbc (default)
Ok, so you confirm that this file format is not displayed (no video, no audio) with LG nor Generic Profile ?
Then you can insert this line in the second <video> element, save and restart serviio service.
<Matches container="matroska" vCodec="vp8" aCodec="vorbis" />
Spookyy
Post Mon Oct 01, 2012 1:15 pm
Yup, now i can play that renamed file. But i get really bad audio stuttering.
Post Mon Oct 01, 2012 2:35 pm
Spookyy wrote:Yup, now i can play that renamed file. But i get really bad audio stuttering.
Try to change targetACodec="ac3" by targetACodec="mp3"
Spookyy
Post Mon Oct 01, 2012 4:05 pm
Still the same sound stuttering.
Post Mon Oct 01, 2012 7:06 pm
Spookyy wrote:Still the same sound stuttering.
You can try to force the audio bitrate, add this aBitrate="384" for example.
or
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="256">
or
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="mp3" aBitrate="384">
Save and restart serviio service after each test...
Spookyy
Post Tue Oct 02, 2012 6:14 am
No, it still stutter =)
Post Tue Oct 02, 2012 7:07 am
and with targetACodec="lpcm" ?
Spookyy
Post Tue Oct 02, 2012 7:35 am
Getting "Unsupported Audio" with that one.
Post Tue Oct 02, 2012 10:07 am
Spookyy wrote:Getting "Unsupported Audio" with that one.
Sorry, no more ideas...
wulfrun
Post Wed Dec 05, 2012 6:41 pm
Just to return to the original question , i'm afraid i wouldn't have a clue as to how to edit the LG profile to make FLV files play on my TV. :? If i attempted messing about in profiles i'd be scared of Serviio not working at all. When i went to profiles i was expecting a text file , instead Internet Explorer opens. Bamboozling to a non expert like myself.
Fortunately , i also have a Sony Bluray player also connected to Serviio , and FLV files play fine on my LG through this route. I would prefer to be able to play them directly on the TV , but nevermind , Serviio is still a wonderful bit of software.
Post Thu Dec 06, 2012 11:07 pm
Did you try some of the other profiles?
wulfrun
Post Sat Dec 08, 2012 1:25 pm
Sorry for being dumb , but i don't understand the question. How do you try other Profiles ?
Post Wed Dec 12, 2012 12:41 pm
Change profile as per the image here: http://www.serviio.org/index.php?option ... ticle&id=5
Previous
Return to LG
