server menubar item
xgc3xhw
Post Tue Oct 02, 2012 9:26 pm
server menubar item
I have the mac version of 1.0.1, I know there are some other posts about a quit 'feature' but I didn't find one that really matches mine. So sorry if I re-enlight an already covered issue, but pls bare with me...
Once I have the Serviio server running, I need to use the console to quit the server: by using the menu bar item. It appears that the Serviio-console application adds the item to the menu bar, also allowing a few other actions. Would it be possible to have this menu bar item when the server launches instead? This way, I can start the Serviio-console more easily and also quit the server without the starting the console first.
I'm aware the alternative is to just start the console and sort of click it away, but I think having it this way is more userfriendly.
thanks for considering
Post Tue Oct 02, 2012 10:22 pm
Re: server menubar item
The server doesn't have any user interface - te fact it has an icon on a Mac is just a coincidence. Console it the UI bit. You can always just right-click on the server icon and Force quit it.
Return to Feature requests
