YouTube
Magnus
Post Mon Oct 01, 2012 9:17 pm
Re: YouTube
Xmantium wrote:
Magnus wrote:As far as i understand the Groovy plugin should be able to work in a QNAP NAS as well but i cannot find out how to actually copy the Groovy plugin to the correct folder on the NAS. To me it does not seem to be that easy compared to windows. Any kind of help would be much appreciated!
I have a QNAP NAS, to copy the groovy file you need to use a program called WinSCP
And copy all your groovy file to this location /share/MD0_DATA/.qpkg/Serviio/plugins/
That make sense! Thank you very much!
CorciPorci
Post Wed Oct 03, 2012 5:30 pm
Re: YouTube
Serviio does not retrieve more than 25 videos from Youtube although I select "unlimited" as the number of feeds to be retrieved, does anybody know how to fix this?
Regards
Erdem
Xmantium
Post Wed Oct 03, 2012 7:07 pm
Re: YouTube
CorciPorci wrote:Serviio does not retrieve more than 25 videos from Youtube although I select "unlimited" as the number of feeds to be retrieved, does anybody know how to fix this?
What URL are you using?
CorciPorci
Post Wed Oct 03, 2012 8:10 pm
Re: YouTube
My youtube favorites channel with the URL "http://gdata.youtube.com/feeds/api/users/MYUSERNAME/favorites?v=2"
Post Wed Oct 03, 2012 9:27 pm
Re: YouTube
CorciPorci
Post Fri Oct 05, 2012 7:28 pm
Re: YouTube
thank you jhb50, it worked
Xmantium
Post Fri Oct 12, 2012 3:31 pm
Re: YouTube
Hi guys, is it possible to play TV show playlist that start with EL, 4oD and Demand5 are putting their shows on YouTube
The original 4oD have started uploading the new show in a new codec which Serviio doesnt support yet
I know that Youtube 4oD videos work as this URL plays fine in Serviio (maybe UK Only)
https://gdata.youtube.com/feeds/api/users/4oDHomes/uploads
If i convert this url to the playlist api feed it doesnt have any value
http://www.youtube.com/playlist?list=ELrg99sKkoMMw
to
http://gdata.youtube.com/feeds/api/playlists/ELrg99sKkoMMw
Post Mon Oct 15, 2012 12:29 am
Re: YouTube
Hi all. Is there any way to perhaps tweak the URL so I only retrieve full length videos? I've set up Recent Movies & Comedies and a) I only get 20 titles, even though I set the console for unlimited, and b) almost all videos listed a short clips of 2 minutes or less.
I don't want a clip, I want the whole thing! If it's me doing something wrong, feel free to correct me! ;)
sheikh73
Post Wed Oct 17, 2012 1:37 am
Re: YouTube
You can go to this page use parameters and customize your search..... https://developers.google.com/youtube/2 ... -resultssp
Here is an example for only one program under a channel...
https://gdata.youtube.com/feeds/api/use ... results=50
channel Name is "geonews"
Program name is "apas ki baat"
Max results are 50 ---> can not be more than 50
I hope it will help...
Ned Flanders
Post Mon Oct 29, 2012 4:01 pm
Re: YouTube
first, Serviio and this plugin are wonderful. I am using them since months and it worked perfectly. Last week i formated my hard drive and switched from Windows 7 to Ubuntu Linux 12.10. I followed the wiki to install Serviio, the console is working, my Samsung TV detects serviio... However, the Youtube videos cannot be read, i've got the message "Format de fichier inconnu", which merely means "Unknown file format" in french. When I try to read those videos with my PS3, it announces a network error. Have you any ideas to help me ?
Thanks in advance.
Post Mon Oct 29, 2012 5:46 pm
Re: YouTube
I assume you have an old FFMpeg, or one without librtmp support. If you have still problems raise it in the Support forums.
rokator
Post Tue Nov 13, 2012 8:48 am
Re: YouTube
My new playlist is for example http://www.youtube.com/playlist?list=PL ... e=view_all
How can I get this playlist to Serviio? Thanks for the advice.
Post Tue Nov 13, 2012 10:34 am
Re: YouTube
rokator wrote:My new playlist is for example http://www.youtube.com/playlist?list=PL ... e=view_all
viewtopic.php?f=23&t=3279
rokator
Post Tue Nov 13, 2012 12:50 pm
Re: YouTube
I have this URL http://www.youtube.com/playlist?list=PL15DEB75AE4AB6AAF
When I use this feed http://gdata.youtube.com/feeds/api/play ... 5AE4AB6AAF it is OK.
But if I have this URL http://www.youtube.com/playlist?list=PL ... e=view_all
and use this feed http://gdata.youtube.com/feeds/api/play ... HlKnpwhJyp it is wrong.
I must remove PL from original ID, but in second example is original ID longer. How can I get this second URL to Serviio.
PS: kdyby šlo nakopnout trochu česky, uvítal bych to, díky ;)
Post Tue Nov 13, 2012 2:51 pm
Re: YouTube
You didn't use the whle playlist ID in the URL.
http://gdata.youtube.com/feeds/api/play ... sY4lAnAJnq
rokator
Post Tue Nov 13, 2012 3:31 pm
Re: YouTube
zip wrote:You didn't use the whle playlist ID in the URL.
Thank you, I think ID is only 16 chars...
zolt
Post Wed Nov 14, 2012 4:33 pm
Re: YouTube
Hi I'm having problems with the youtube plugin. I'm using this URL for example: http://gdata.youtube.com/feeds/api/user ... results=50. No videos appear in the folder on my Samsung blu-ray player and the log file has a lot of entries like this one:
2012-11-14 17:17:23,949 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://o-o---preferred---sn-5uh5o-f5fe---v14---lscache5.c.youtube.com/videoplayback?upn=W-wwKqgFjAA&sparams=cp%2Cgcr%2Cid%2Cip%2Cipbits%2Citag%2Cratebypass%2Csource%2Cupn%2Cexpire&fexp=927103%2C906357%2C919318%2C922401%2C920704%2C912806%2C927201%2C922403%2C925003%2C913546%2C913556%2C916805%2C920201%2C901451&ms=au&expire=1352935152&itag=22&ipbits=8&gcr=pl&sver=3&ratebypass=yes&mt=1352909772&ip=91.90.160.232&mv=m&source=youtube&key=yt1&cp=U0hUR1lOU19KTENONF9RSFdCOkhyYXhzVjluUG44&id=7ca23eb833a508c9&newshard=yes&signature=1E00FB85815BA42992DD6FE930C609883E8D49F8.AA7944F28EF01F0D50684BC6985A0175C1AF1DBC. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:291)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:382)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:86)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:124)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:268)
   ... 2 more
I'm using the latest ffmpeg, and when I run ffmpeg -i for the link "http://o-o---preferred---sn-5uh [...]" I'm getting a 403 error.
Post Wed Nov 14, 2012 10:29 pm
Re: YouTube
Works for me. Did you add it as an RSS-atom?
Post Thu Nov 15, 2012 9:49 am
Re: YouTube
And if you are on Linux, do you have the latest FFmpeg, with librtmp ?
Baumi
Post Thu Nov 15, 2012 11:02 am
Re: YouTube
Hi I'm also having some problems with the Youtube plugin. I have Serviio installed on Synology NAS and music and loval videos works perfectly. When I have added the online souces with proper RSS-atom. Using my LG Home Cinema (BH6520TN) I can see only you tube video, there is no sound! Using Playstation 3 there is nothing. I have tried to play with changing the profile but it didn't help. Maybe I should play with profiles xml file and add some online transcoding info but I have no idea which ones :P Turning on / off transcodig also didn't help.
I would like to use my LG to play it (the one I have only video, no sound) so the problem with PS3 is not so important. Thanks :)
Return to Available plugins
Users browsing this forum: No registered users and 79 guests
