Transcoded MKV, audio plays but video is black
koan00
Post Sun Sep 30, 2012 10:44 pm
Trying to play a MKV file using the Bravia 2011 US profile. I get audio at the TV, but not video.
Playback the transcoded video in VLC works but no audio.
Orginal Format:
Unique ID                                : 190773162927014519963950816445208304261 (0x8F85931FF9C66BB18EA69F5358C99A85)
Complete name                            : XXX.mkv
File size                                : 7.37 GiB
Duration                                 : 2h 22mn
Overall bit rate                         : 7 384 Kbps
Encoded date                             : UTC 2012-08-20 21:48:56
Writing application                      : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct  9 2011 11:55:43
Writing library                          : libebml v1.2.2 + libmatroska v1.3.0
Format profile                           : Main@L3.1
Format settings, GOP                     : M=1, N=3
Muxing mode                              : Header stripping
Duration                                 : 2h 22mn
Bit rate                                 : 6 000 Kbps
Frame rate mode                          : Variable
Bits/(Pixel*Frame)                       : 0.272
Stream size                              : 5.72 GiB (78%)
Writing library                          : x264 core 120
Encoding settings                        : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=abr / mbtree=1 / bitrate=6000 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Color primaries                          : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics                 : BT.709-5, BT.1361
Matrix coefficients                      : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Codec ID                                 : A_DTS
Duration                                 : 2h 22mn
Bit rate                                 : 1 510 Kbps
Bit depth                                : 24 bits
Stream size                              : 1.51 GiB (20%)
Forced                                   : Yes
FFMpeg command: ffmpeg -fflags +genpts -i XXX.mkv -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a ac3 -b:a 384k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-753-sony2011us-ORIGINAL.stf
Results in transcoded video format:
Complete name                            : Z:\video.mpg
Format                                   : MPEG-TS
File size                                : 6.79 GiB
Duration                                 : 2h 22mn
Overall bit rate                         : 6 805 Kbps
Menu ID                                  : 1 (0x1)
Codec ID                                 : 27
Duration                                 : 2h 22mn
Stream size                              : 6.07 GiB (89%)
Menu ID                                  : 1 (0x1)
Codec ID                                 : 129
Any ideas?
Post Mon Oct 01, 2012 7:25 am
Re: Transcoded MKV, audio plays but video is black
Problem is due to "header compression" not supported.
Suggest to read that: http://wiki.serviio.org/doku.php?id=header_com
koan00
Post Thu Oct 04, 2012 9:44 pm
Thanks for the reply. I remuxed following the instructions in the link you posted, but it still has the same problem playing back.
Unique ID                                : 229629481970749203660048262182517188138 (0xACC1079034BEC0398E6FC15178B5A62A)
Complete name                            : XXX2.mkv
Duration                                 : 2h 22mn
Overall bit rate                         : 7 387 Kbps
Encoded date                             : UTC 2012-10-01 22:16:48
Writing application                      : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep  2 2012 15:37:04
Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
Duration                                 : 2h 22mn
Format                                   : DTS
Codec ID                                 : A_DTS
Duration                                 : 2h 22mn
Bit depth                                : 24 bits
Forced                                   : Yes
Post Fri Oct 05, 2012 9:47 am
Frame rate : 23.976 fps
That could be due to variable frame rate, with the same tool try to fix the frame rate to 23.976 value (see track options tab)
