Youtube video transcode off but still on?
sharky1337
Post Fri Oct 05, 2012 5:57 pm
Hello serviio users,
I think I found one of the best dnla server for my small nas(ds212j). I disabled trancoding because my nas it tottally unpower for such things. Hd files plays very well no transcoding needed because I have a wdtv live. Today I checked out the impressive plugin feature. I checked out the youtube plugin. It took some time to setup but now I can receive the rss feeds vid dnla on my wdtv. But playback does not work properly. As I mentioned I have disabled transcoding ( via console) if I start a video, my nas starts a transcoding process for this video. Does it belongs to the youtube plugin? Should every youtube video needs to be transcoded?
regards, sebastian
Post Fri Oct 05, 2012 8:52 pm
Re: Youtube video transcode off but still on?
Depends what quality you have set in the console. Medium will give you an AVC/AAC.flv file that might play, and if you change the '4' in line 78 of the groovy to a '6' you will get an AVC/AAC.mp4 file that should play. Low will always need transcoding. The plugin should really let you choose the YT format that you prefer rather than limiting the choices to H/M/L.
sharky1337
Post Sat Oct 06, 2012 9:24 am
I changed the value from four to six and set the quallity to medium via console but serviio still wants to transcode. I have a 3party firmware on my wdtv and which have a youtube app built in. I don't want to use it because it is horrible to navigate without a keyboard, but I plays videos on yt without any probelms. I have attached my debuglog for troubleshooting.
2012-10-06 11:38:58,267 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-10-06 11:38:58,268 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Sat, 06 Oct 2012 09:38:58 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache
2012-10-06 11:38:58,278 DEBUG [WebServer] Incoming connection from /192.168.178.21:35880
2012-10-06 11:38:58,297 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.21
2012-10-06 11:38:58,299 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000050001/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.178.200:8895,Content-Length: 0,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DL
2012-10-06 11:38:58,300 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.21
2012-10-06 11:38:58,301 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.178.21, Profile=WDTV Live'
2012-10-06 11:38:58,302 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000050001 and type 'MEDIA_ITEM' received
2012-10-06 11:38:58,302 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000050001 (online)
2012-10-06 11:38:58,302 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 5)
2012-10-06 11:38:58,304 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 5)
2012-10-06 11:38:58,306 DEBUG [VideoDeliveryEngine] Delivering item '1000000000050001' for client 'IPAddress=/192.168.178.21, Profile=WDTV Live'
2012-10-06 11:38:58,306 DEBUG [VideoDeliveryEngine] Delivering file 'http://o-o---preferred---sn-4g57kner---v6---lscache7.c.youtube.com/videoplayback?upn=J4C64ImkB9w&sparams=cp%2Cgcr%2Cid%2Cip%2Cipbits%2Citag%2Cratebypass%2Csource%2Cupn%2Cexpire&fexp=919318
2012-10-06 11:38:58,307 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-1000000000050004-14-ORIGINAL.stf', will stop the job
2012-10-06 11:38:58,307 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-1000000000050004-14-ORIGINAL.stf'
2012-10-06 11:38:58,394 DEBUG [TranscodingJobListener] Deleted temp file '/volume1/@tmp/Serviio/transcoding-temp-1000000000050004-14-ORIGINAL.stf': true
2012-10-06 11:38:58,395 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.178.21, Profile=WDTV Live'
2012-10-06 11:38:58,396 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: http://o-o---preferred---sn-4g57kner---v6---lscache7.c.youtube.com/videoplayback?upn=J4C64ImkB9w&sparams=cp%2Cgcr%2Cid%2Cip%2Cipbits%2Citag%2Cratebypass%2Csource%2Cupn%2C
2012-10-06 11:38:58,397 DEBUG [ProcessExecutor] Starting /volume1/@appstore/Serviio/bin/ffmpeg -i http://o-o---preferred---sn-4g57kner---v6---lscache7.c.youtube.com/videoplayback?upn=J4C64ImkB9w&sparams=cp%2Cgcr%2Cid%2Cip%2Cipbits%2Citag%2Cratebypass%2Csour
2012-10-06 11:38:58,993 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:59
2012-10-06 11:39:01,453 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-10-06 11:39:01,455 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://o-o---preferred---sn-4g57kner---v6---lscache7.c.youtube.com/videoplayback?upn=J4C64ImkB9w&sparams=cp%2Cgcr%2Cid%2Cip%2Cipbits%2Citag%2Cratebypass%2Csource%2C
2012-10-06 11:39:01,456 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-10-06 11:39:01,456 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-06 11:39:01,456 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Sat, 06 Oct 2012 09:39:01 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache
2012-10-06 11:39:55,953 DEBUG [WebServer] Incoming connection from /192.168.178.21:35884
2012-10-06 11:39:55,956 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.21
2012-10-06 11:39:55,957 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000050001/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.178.200:8895,Content-Length: 0,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]
2012-10-06 11:39:55,958 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.21
2012-10-06 11:39:55,960 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.178.21, Profile=WDTV Live'
2012-10-06 11:39:55,960 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000050001 and type 'MEDIA_ITEM' received
2012-10-06 11:39:55,961 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000050001 (online)
2012-10-06 11:39:55,961 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 5)
2012-10-06 11:39:55,962 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 5)
2012-10-06 11:39:55,975 DEBUG [VideoDeliveryEngine] Delivering item '1000000000050001' for client 'IPAddress=/192.168.178.21, Profile=WDTV Live'
2012-10-06 11:39:55,975 DEBUG [VideoDeliveryEngine] Delivering file 'http://o-o---preferred---sn-4g57kner---v6---lscache7.c.youtube.com/videoplayback?upn=J4C64ImkB9w&sparams=cp%2Cgcr%2Cid%2Cip%2Cipbits%2Citag%2Cratebypass%2Csource%2Cupn%2Cexpire&fexp=919318
2012-10-06 11:39:55,976 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.178.21, Profile=WDTV Live'
2012-10-06 11:39:55,976 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-10-06 11:39:55,977 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://o-o---preferred---sn-4g57kner---v6---lscache7.c.youtube.com/videoplayback?upn=J4C64ImkB9w&sparams=cp%2Cgcr%2Cid%2Cip%2Cipbits%2Citag%2Cratebypass%2Csource%2C
2012-10-06 11:39:55,995 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-10-06 11:39:55,995 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-06 11:39:55,996 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Sat, 06 Oct 2012 09:39:55 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache
2012-10-06 11:39:56,966 DEBUG [WebServer] I/O error: Broken pipe
2012-10-06 11:39:57,103 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-10-06 11:39:57,103 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-10-06 11:39:57,106 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 4)
2012-10-06 11:39:57,237 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 5)
2012-10-06 11:39:57,288 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 6)
2012-10-06 11:39:58,994 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.178.200, timeout = 0
2012-10-06 11:39:58,996 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 52a7d863-addd-321f-90af-63372b1cdc67
2012-10-06 11:40:00,973 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:36
2012-10-06 11:40:37,714 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.178.200, timeout = 0
2012-10-06 11:40:37,716 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 52a7d863-addd-321f-90af-63372b1cdc67
2012-10-06 11:40:39,702 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:37
2012-10-06 11:40:43,032 DEBUG [RendererManager] Removing renderer bad97db2-0090-a973-f691-f1f363c02b59 from list of active renderers
2012-10-06 11:40:43,055 DEBUG [RendererManager] Adding renderer Renderer [uuid=bad97db2-0090-a973-f691-f1f363c02b59, ipAddress=192.168.178.21, name=WD TV HD Live, profileId=14, manuallyAdded=false, forcedProfile=false, enabled=true, accessGroupId=1] to list
2012-10-06 11:40:44,494 DEBUG [WebServer] I/O error: Connection reset           /by me no error!
regards, sebastian
Post Sat Oct 06, 2012 10:12 am
Online will always (unless it's mpegts) be transcoded, or at least remuxed, no matter what your settings. In your case the video is probably not H264 (VP8 possibly?), therefore it's transcoding it.
Post Sat Oct 06, 2012 12:37 pm
I assume you WD has enough power to remux the YT files to TS. The change to 6 will provide an AVC/AAC stream file that I also assume your TV can play without having to also transcode to MPEG2video which is what takes the power, but it still has to remux those streams from an MP4 container into an mpeg-ts container. Your log dump does not show the full ffmpeg command so the values showing the formats and the transcoding that is being done are missing so I cant verify what is actually happeniing.
Return to User experiences
