Stream to Android
hanzibanzi
Post Tue Jul 31, 2012 2:40 pm
Re: Stream to Android
No adjustments, just changed targetVCodec, should have same resolution, no idea why video stutters and lags with h264, its the same playing from sd card, works properly without sound tho, maybe sound puts itover the edge ;)
Anyhow, finally streaming to my Pad while lying in Bed, pure awesomeness.
Post Tue Jul 31, 2012 3:13 pm
Well if you use something like this in place of the commented out video section at the top of the ServiiGo profile, then you should be able to play back your mkvs with h264 and ac3 audio by converting just the audio.
<Video targetContainer="mpegts" targetACodec="aac">
         <Matches container="matroska" vCodec="h264" aCodec="ac3"/>
hanzibanzi
Post Tue Jul 31, 2012 3:22 pm
Yeah but then my video, for some reason, stutters and audio lags behind.
However when i use this "targetVCodec mpeg2video" everything plays fine. That should retain the resolution right?
Post Tue Jul 31, 2012 3:41 pm
Yes, unless you tell it to resize, it will keep the original resolution.
Post Tue Jul 31, 2012 4:10 pm
hanzibanzi wrote:Anyhow, finally streaming to my Pad while lying in Bed, pure awesomeness.
Great. Maybe you could update your ServiiGo rating now :twisted:
hanzibanzi
Post Tue Jul 31, 2012 10:23 pm
done
crackedtooth
Post Sun Oct 07, 2012 8:02 am
hanzibanzi wrote:Sorry for the late response.
I just installed latest ffmpeg and i can confirm it works now, video is still a bit stuttery but transcoding the video stream with targetVCodec mpeg2video works wonders, video looks a bit worse but streams perfectly.
Serviigo medium && low works now aswell.
Thank you all for your time and support, very much appreciated.
Is your profile for TF700 ?
If so.. could you post a summary of all items you sorted and changed to get a smooth experience?
just decided no ipad three... tf700 is the one to go for for, only drawback is no microusb port to charge without the dock
Previous
