Using ALBUMARTISTSORT instead of ALBUMARTIST?
• Page 1 of 1
Is it possible to use the ALBUMARTISTSORT tag from ID3 or Vorbis tags instead of ALBUMARTIST for the album artist? I think this would be much more useful. For example, 90% of the album artists under "T" start with "The". "Beatles, The" would appear under "B".
Re: Using ALBUMARTISTSORT instead of ALBUMARTIST?
It should already be doing that. I remove 'The' maually and store it in the DB as a sort name.
Petr
Help translate Serviio
Really? When selecting the album artist category in a DLNA client (BubbleUPnP) the "normal" album artist names are shown: e.g. "James Newton Howard" under "J" instead of "Howard, james Newton" under "H" (see attached screenshots).
I do not read the sort tag. I only use the main one and then apply some code to make it 'sortable', mainly by removing 'the' and 'a'
Petr
Ok, this thread should be then moved to the "Feature requests" sub-forum
• Page 1 of 1
Users browsing this forum: Bing [Bot] and 54 guests
