Cannot access the server
1frame
Post Sat Oct 06, 2012 2:46 pm
I'm a big fan of Serviio and have put it to good use so far. However, I constantly have a problem with my TV not being able to find the server. All the serviio icons are greyed out on my TV and when I click one I get, "Cannot access the server" after waiting a little while. When it's working, I know it's meant to be yellow, but the majority of the time it's greyed out. It seems like only a multiple reseting of the computer seems to sort this out - literally have to keep restarting my computer until it becomes yellow and works again.
What I'm using:
- MacBook Pro
- Sony Bravia TV
Everything's wireless. The Serviio console on my MacBook recognises the Sony Bravia TV. But, like I say, it seems to be so sporadic in one it shows as yellow on my TV.
Surely there's something I can do to make Serviio more stable? I've tried all the usual things like changing he "Bound IP address" to be whatever my MacBook is connecting to.
Any help would be much appreciated.
Kind regards,
Post Sun Oct 07, 2012 12:51 pm
Re: Cannot access the server
Set static IP addresses to your TV and the Mac.
1frame
Post Sun Oct 07, 2012 3:40 pm
zip wrote:Set static IP addresses to your TV and the Mac.
Thanks for the reply, but how would I do this?
Any tutorials?
Thanks,
Post Sun Oct 07, 2012 5:29 pm
try google. there should be something for your router model.
deadmonkey
Post Sat Apr 20, 2013 3:22 pm
I have this symptom with a BT homehub, a 2010 Bravia and Serviio 1.2.1.
I've set the PC and TV to static addresses, but the thing I do to get it visible again is to restart the serviio service, rather than restarting the whole machine.
slyguy42o
Post Mon Apr 22, 2013 4:33 pm
is your serviio server going into sleep mode at any point?
deadmonkey
Post Tue Apr 23, 2013 10:53 pm
It doesn't seem to be, the console shows it's running, as does the serviidroid app on my phone.
tkos
Post Wed Apr 24, 2013 7:26 pm
I have been having the same issue since upgrading Serviio to the latest. After awhile it just goes away. I was restarting my computer and it would pop right back up again.
deadmonkey
Post Tue Apr 30, 2013 11:34 pm
I checked my logs, did a search and turns out it's exactly this issue, which you've already got in hand :)
viewtopic.php?f=5&t=9909
Users browsing this forum: Google [Bot] and 35 guests
