Movie stutters when it gets " busy" on the screen
Powernout
Post Sun Oct 07, 2012 7:50 am
Hi Guys,
I have a Samsung UE55D6800. I've been using Serviio for almost 2 years now. I bought a new PC 4 months ago. My main reason to buy a new PC is because I suspected my previous PC (dualcore) did not have sufficient power to transcode my movies: they would often stutter. Whilst things have improved with this new computer (8-core AMD FX-8120), the disappointment is still there. The symptoms:
As soon as there is lots of action in the movie, or if there are many computerised images, the image will pause for a few seconds before it continues playing again. Within action scenes, it will quickly pauze again, as if it needs to buffer. A movie such as Cowboys & Aliens has both action as well as computerised images and is very unpleasant to watch.
I've set the Profile to Samsung C/D/E Series, I have 8 cores transcoding and am wired, not wireless. Anybody any ideas?
Post Sun Oct 07, 2012 12:06 pm
Re: Movie stutters when it gets " busy" on the screen
The Samsung profile hardly transcodes anything, so PC power doesn't come in play really. In the busy scenes it's probably down to the bitrate and the fact the TV has a processing limit. So very high bitrates would cause the TV stuttering.
Try this tool to inspect the bitrate: http://wiki.serviio.org/doku.php?id=vbitrate
If it's anywhere near 20mBit it would be it.
Powernout
Post Sun Oct 07, 2012 5:45 pm
Thanks for the swift response!
Check this out...
Looks like this says something. I never download extremely large files (usually +/- 8 gig). I always tried to get the bitrate as high as possible. So I am guessing I should focus on movies with a lower bitrate then?
Post Sun Oct 07, 2012 6:02 pm
what is your network type and speed?
Powernout
Post Sun Oct 07, 2012 8:37 pm
Hi Mark,
1gig wired. So bandwidth is not the issue!
Post Sun Oct 07, 2012 10:08 pm
As you see there is a lot of times it reaches 25 mbit and more, so at those times the TV will struggle
Powernout
Post Tue Oct 09, 2012 5:43 am
Thanks Petr,
Should I be focussing on geting lower bitrate movies instead?
slyguy42o
Post Sun Oct 28, 2012 4:40 pm
I had the same issue with my Philips TV, I was able to use the maxVBitrate variable int he rendering profile to limit the bit rate to this TV. It solved about 98% of the stuttering issues.
Powernout
Post Sun Nov 04, 2012 1:41 pm
slyguy42o wrote:I had the same issue with my Philips TV, I was able to use the maxVBitrate variable int he rendering profile to limit the bit rate to this TV. It solved about 98% of the stuttering issues.
Now that sounds like a solution! But I have no clue how to get this into the profile... can anybody help?
slyguy42o
Post Sat Nov 10, 2012 3:40 pm
open up config\profiles.xml
find the config section that applies to your TV
add the value
maxVBitrate="12000"
to the transcoding section
12000 is just the value I am testing at the moment.. I have been playing around with it as some videos still stutter, but overall a big improvement.
here is the full string so you can see how it's used.
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" maxVBitrate="12000">
Powernout
Post Thu Nov 15, 2012 10:06 pm
@ slyguy42o: thanks! I will certainly give it a try. I really appreciate your answer and apologise for not responding sooner. It amy take a little more time but I will let you know how this works put for me. I will start at 20.000 and see what that does for me
Powernout
Post Sat Dec 22, 2012 10:51 pm
@ slyguy42o
I finally got round to trying what you suggested, but I'm afraid it didn't work. The line you told me to edit was not identical, so I had problems trying to figure out what I should edit and where. Could I possibly email you my profile so you can tell me where to edit it? Or is there another way? I can post the entire profile here of course, but I think that will look a bit ugly... :shock:
Powernout
Post Sat Dec 22, 2012 11:02 pm
Ah. I see I can attach a file, so I've done that. I have a Samsung TV C/D/E Series. If you search for 20000 you will find what I edited (and obviously didn't do very well...)
profiles.xml
(68.21 KiB) Downloaded 818 times
slyguy42o
Post Sun Dec 30, 2012 6:06 pm
Looks like you got most of them, I edited a few that got missed.
Note that if you don't see any difference do a search and replace on the 20000 value. Try 10000 just to see if it makes a difference or not, if that solves the issue you can work up from there to find your ideal value.
profiles.xml
test samsung profile for stuttering in high action
(68.32 KiB) Downloaded 752 times
Powernout
Post Mon Dec 31, 2012 9:28 am
Thanks SlyGuy! Much appreciated! Will let you know!!! For now, be careful with fireworks tonight ;-)
Powernout
Post Fri Mar 01, 2013 4:40 pm
Hi Slyguy,
Still stuttering :-(
I'm at home recovering from an operation and thought this would be the perfect time to test this. Buy alas...
slyguy42o
Post Mon Mar 04, 2013 11:50 pm
what is the resolution of the files you are seeing this issue on? 1080? 720? 480?
I still see stuttering when I try to play a high action 1080.. but the same movie in 480 plays fine. I suspect this is due to my server having trouble keeping up with the transcode.
Powernout
Post Tue Mar 12, 2013 3:30 pm
Hi Slyguy,
I have it mostly with the 1080 movies, when they are large in size. If I get files under 3gig, I generally don't have a problem, but you also see considerably less quality. Shame the TV can't handle higher bitrates by itself. I also see it in 720 movies if they are of considerable size. I just checked The Hunger Games, which is a 10gig file. Lots of peaks at 30.000. I've just reinstalled my computer and now have a clean profile; I got the feeling my previous profile was a little screwed up anyway (didn't even mention the model of my TV). What were you using to edit your profile? I have the feeling I don't have the right program to edit XML.
If you wanna have another go: I've attached the clean profile :D
And thanks for being there.
grolschie
Post Wed Mar 13, 2013 6:05 am
I am wondering if the problematic files are ones that the renderer can play natively and are not being transcoded, therefore encountering the bitrate limitation? If so, maybe a possible feature request might be to implement a user-configurable bitrate value setting where any videos over this value are transcoded at an arbitrarily lower bitrate even if they are able to be played natively.
slyguy42o
Post Mon Mar 18, 2013 3:42 pm
isn't that what the abitrate variable kinda does?
